    Designing a PWM to Analog mini board for fans
    139
    12.3k
    • NexxCatundefined
      NexxCat @Egon.Net
      @egon-net Out of interest. What would the cost be per board, delivered to the UK? Do you think they could be assembled with a fine tipped soldering iron, or only hot air?
      Egon.Netundefined zaptaundefined 2 Replies Last reply Reply Quote 0
      • Egon.Netundefined
        Egon.Net @NexxCat
        @nexxcat said in Designing a PWM to Analog mini board for fans:
        Regarding cost, this is what I thought:
        • Just a bare board: 4€/piece
        • DIY kit (without headers/jumpers): 8€/kit
        • Fully assembled and tested (with optional headers/jumpers): 15€/piece
        • Shipping costs to UK: 5€
        Regarding building the board with a fine soldering iron... It could be done since every part has its legs exposed and parts are not that small (SOIC8 & 0805 SMD), but it would be much more difficult.
        NexxCatundefined 1 Reply Last reply Reply Quote 0
        • NexxCatundefined
          NexxCat @Egon.Net
          @egon-net Thanks 🙂 I'll hold off for now then, but great work on the product!
          Egon.Netundefined 1 Reply Last reply Reply Quote 0
          • Egon.Netundefined
            Egon.Net @Egon.Net
            This is the new board:
            It's a bit bigger so now the capacitor is included and the diode and the led are in top side. Also a bit more of space surrounding the in/out connectors.
            BTW, I think it's the last board I make with Ultiboard. I have tested Kicad and its support for footprints is way better (I can directly import them from Mouser!)
            • Egon.Netundefined
              Egon.Net @NexxCat
              Thanks!
              • zaptaundefined
                zapta @NexxCat
                You can practice with one of those Aliexpress kits https://www.aliexpress.com/item/1005002070994262.html . It's not that difficult once you get used to it, especially SOIC and 0805 packages which are relatively on the large side.
                • zaptaundefined
                  zapta @Egon.Net
                  @egon-net said in Designing a PWM to Analog mini board for fans:
                  Most likely Kicad will give you nicer 3D renderings. 😉
                  Sometime people also post hard to find models on sites such as grabcad or gitbub.
                  • Egon.Netundefined
                    Egon.Net @zapta
                    @zapta said in Designing a PWM to Analog mini board for fans:
                    In fact, Ultiboard renders are VERY ugly xDD. In 1998, when I started using it, it was like "wooha!". But now it's 2021, and it's the very same render 😆
                    It's just that I can go from Multisim to Ultiboard comfortably, and Multisim has a powerful analog spice simulator which I use a lot. I'm trying to transition to TINA TI + KiCad. I wish KiCad had a good spice simulator!
                    • zaptaundefined
                      zapta @Egon.Net
                      If paying for a subscription is an option for you, take a look at https://www.circuitlab.com/ . It has a more modern front end, works in a browser and has a cleaner user interface, and has nice feature such as sharing your schematic and simulation with others.
                      Most of my projects are digital so in the rare cases I need a simulator I use https://en.wikipedia.org/wiki/LTspice (free, powerful, dated user interface like most circuit simulators).
                      • Egon.Netundefined
                        Egon.Net @zapta
                        I'm trying to get used to TINA TI because it has most of TI spice models and it's fairly accurate (I do a lot of analog designs). Its transient analysis is the most accurate I've found to date. But thanks for the suggestions! I'll have a look 🙂
                        • Egon.Netundefined
                          Egon.Net @Egon.Net
                          25 board batch on its way!
                          • Parts ordered to Mouser ✔
                          • Boards ordered to JLCPCB ✔
                          Waiting...
                          Egon.Netundefined 1 Reply Last reply Reply Quote 1
                          • zaptaundefined
                            zapta
                            Do fan manufacturer provide graphs of CFM vs voltage? Is this something that can easily be measured?
                            Now that you have good control of the fan, would be interesting to know for example what 50% voltage means in cooling terms.
                            • Egon.Netundefined
                              Egon.Net @zapta
                              I don't even thing that the manufacturer expects you to run the fan at other voltage than nominal... If I had some way to measure air flow I could perform some measurements, something like displacement of a suspended weight or the like.
                              • Egon.Netundefined
                                Egon.Net @Egon.Net
                                • Parts arrived from Mouser ✔
                                • Boards in their way from JLCPCB ✔
                                Waiting...
                                Egon.Netundefined 1 Reply Last reply Reply Quote 2
                                • Egon.Netundefined
                                  Egon.Net @Egon.Net
                                  Waiting...
                                  • Boards arrived from JLCPCB ✔
                                  It all seems ok, so I will build the boards and send them as soon as posible 🙂
                                  • Egon.Netundefined
                                    Egon.Net @Egon.Net
                                    First board assembled and tested!
                                    You can see the new integrated electrolytic capacitor, smd diode and led. I'll try to assemble/pack all boards this weekend, and send them early next week.
                                    zaptaundefined 1 Reply Last reply Reply Quote 2
                                    • zaptaundefined
                                      zapta @Egon.Net
                                      Looks very nice. Now when somebody will complain that fan X doesn't work with PWM we can point them here. 😉
                                      • S1lencerundefined
                                        S1lencer
                                        If there are any Boards left, icould use 4 of the.
                                        • Egon.Netundefined
                                          Egon.Net @zapta
                                          Thanks @zapta 🙂
                                          • Egon.Netundefined
                                            Egon.Net @S1lencer
                                            @s1lencer said in Designing a PWM to Analog mini board for fans:
                                            I've just reserved the last board 😞
                                            I still have 5 spare pcb boards, but not all the components: I have the resistors/capacitors/opamp, but I don't have the electrolytic capacitor, diode and led. Could that suit you?
                                            I usually put orders to mouser every other month or so, so if u can wait maybe I'll can add the parts in my next order. Or if there are more people interested, I can run another batch.
