Firmware 1.19+1 bug fix
Firmware installation
2.1k
    I have put pre-release 1.19 bugfix firmware versions for Duet WiFi, Duet Ethernet and Duet 06/085 at https://www.dropbox.com/sh/wq0u70kpapqc3is/AAC6I8TS5Lbwuziq_r3M15Qea?dl=0. The fixes to 1.19 are:
    • M669 should report current kinematics, but doesn't for delta (also check Cartesian and CoreXY etc.)
    • SCARA kinematics doesn't apply Z limits or limits to U, V etc. Delta kinematics doesn't apply limits to U, V etc.
    • SCARA forward kinematics are wrong
    • SCARA minimum radius limit is wrong
    • SCARA: allow S and T parameters to be changed on the fly i.e. don't require re-homing when they are changed
    • M140 S0 and M104 S0 at the end of a print file don't turn off the heaters if used at the end of a gcode file with >8 following M300 commands
    • Bed adjusting wizard: leave one of the screws alone when suggesting corrections
    • This problem: https://www.duet3d.com/forum/thread.php?pid=22326
    • When a heater was named in a M305 command, the memory allocated was overflowed by 1 byte
    If you are affected by any of these issues or you are declaring named heaters in M305 commands, please try this version.
      lolorc
      I've just upgraded from 1.18 to the whole 1.19 package + this bug fix.
      I can't find a way to delete/rename/etc files from the web gui (macros, sys, …) There's a check box in front of the files, but there're no associated action.
      (I've observed this with firefox & chromium)
        Dougal1957
        @lolorc:
        Right click the file name and a drop down appears
          lolorc
          Thanks
            frafa
            Hi
            Scara begins to really work well!
            a big thank-you 🙂
            Scara with DuetWifi => Scarlette3D
            https://youtu.be/mBF5cO8vGhI
              Thanks for the feedback, and for choosing the Duet despite the initial incomplete SCARA support.
                Jarery
                Applied the patch.
                Still have difficult time connecting via wifi. Router is reset to channel 6, no joy.
                I have a dedicated laptop parked 3 ft away, Whats recommended method to have a wired connection., USB cable ?
                  @jarery, is it not connected ting at all, or connecting but timing out, or something else?
                    ESTIMULO
                    same problem, it get connected but in a few seconds connection timeout, connection reset, etc. if i do ping continually some are lost. That not happend on 1.18. Something with wifi is not as good as previous version.
                      Jarery
                      It does connect, but times out a lot.
                      I created a macro that turns the wifi module off/on just to help in reconnecting.
                      Once connected it stays connected for the most part, until I begin a print. Then it usually times out after a 10-20 min into a print.
                      Getting it to reconnect after the print is just a hit/miss process of restarting the wifi, hitting connect repeatedly, rebooting, etc. I log into my routers page and see the IP assigned, it just has a hard time opening in a web page (safari).
                      I have a main router in the room behind, about 10' away, and a second router as an access point half a house away. Both use same name/ssid and pass.
                        When it is connected, if you run M122 what RSSI does it report?
                          Jarery
                          Heres the network section
                          Network state is running
                          WiFi firmware version 1.19
                          WiFi MAC address 5c:cf:7f:a4:a1:64
                          WiFi Vcc 3.12, reset reason Turned on by main processor
                          WiFi flash size 4194304, free heap 39168
                          WiFi IP address 192.168.2.53
                          WiFi signal strength -35dBm
                          HTTP sessions: 2 of 8
                          Socket states: 2 0 0 0 0 0 0 0
                          Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                            You have a very strong signal! I don't think I have seen a RSSI as high as -35 before.
                            You appear to have 2 active http sessions, which I think means you have connected from 2 different IP addresses. Is that correct?
                              Jarery
                              at times I've connected from a second laptop yes. But that is not always the case.
                              Much of the time I am only connected via the one laptop.
                              1 out of 14
