BLTouch always reports same value
First of all, I found someone with the same issue here, but it's a bit old post and unsolved...
So, as the title says, my probe always reports -5.0mm, I beleive it is the same value I have as the dive height on the M558 command. If I change it to -4, it always reports -4
I have seen a couple of times different values reported through the many tests I made, but unfortunately I can't replicate it right now, so I think it is not a hardware issue (I haven't changed any of the connections)
When I do a G30 S-1 test I always get -5.0, even if I put a thick cardboard between the bed and the probe and repeat the test.
The BLTouch is original and it actually triggers, I think it just reports the wrong value.
Also, quite strange, but isn't the G30 S-1 supposed to not change the Z value? to me it subtracts 5mm... so if I have it set to 0.0 and do a G30 S-1, it is changed to -5.0mm which I don't understand
This is my config.g
; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Apr 24 2021 19:02:10 GMT+0200 (hora de verano de Europa central) ; General preferences M111 S0 ; debug off G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"3d printer" ; set printer name M669 K1 ; select CoreXY mode ; Network M540 PBE:73:31:34:53:3E ; set custom MAC address M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet G4 S1 ; wait for expansion boards to initialize ; Drives M569 P0.0 S1 D3 ; physical drive 0.0 goes forwards M569 P0.1 S1 D3 ; physical drive 0.1 goes forwards M569 P1.0 S1 D3 ; physical drive 1.0 goes forwards M569 P1.1 S1 D3 ; physical drive 1.1 goes forwards M569 P1.2 S1 D3 ; physical drive 1.2 goes forwards M569 P0.2 S0 ; physical drive 0.2 goes backwards M584 X0.0 Y0.1 Z1.0:1.1:1.2 E0.2 ; set drive mapping, three Z motors connected to driver outputs 0, 1 and 2 of expansion board M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X200.00 Y200.00 Z400.00 E420.00 ; set steps per mm M566 X900.00 Y900.00 Z24.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z400.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z100.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z1200 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X-25:328 Y0:300 Z0:286 S1 ; set axis min:max ; Endstops ; no puedo usar io0.in para esto puesto que va con el PanelDue ; Las entradas de final de carrera tienen un pull-up interno de 27kOhm ; Cuando se presiona el final de carrera, este cortocircuita la línea y pasa a 0 M574 X1 S1 P"io1.in" ; configure active-high endstop for low end on X via pin io1.in M574 Y1 S1 P"io2.in" ; configure active-high endstop for low end on Y via pin io2.in M574 Z2 S1 P"1.io0.in+1.io1.in+1.io2.in" ; configure active-high endstop for high end on Z via pins 1.io0.in+1.io1.in+1.io2.in ; Z-Probe ;M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed ;M557 X15:215 Y15:195 S20 ; define mesh grid M950 S0 C"io7.out" ; create servo pin 0 for BLTouch M558 P9 C"io7.in" H5 R0.2 F100 T6000 A5 ; set Z probe type to bltouch and the dive height + speeds G31 P25 X0 Y20 Z0.000 ; set Z probe trigger value, offset and trigger height M557 X20:280 Y20:280 P4 ; define mesh grid ; Z-axis leadscrews positions M671 X-75:150:375 Y10:380:10 S6.0 ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 R0.241 C467.8 D3.07 S1.00 V24.2 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"spi.cs0" Y"rtd-max31865" ; configure sensor 1 as PT100 via CS pin spi.cs0 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 R2.137 C196.5:184.7 D5.46 S1.00 V24.3; tuning parameters M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency M106 P0 C"Heatbreak Fan" S0 L1.0 X1.0 H1 T45 ; set fan 0 value. Thermostatic control is turned on M950 F1 C"out8" Q15000 ; create fan 1 on pin out8 and set its frequency M106 P1 C"Nozzle Fan" B0.5 S0 H-1 ; set fan 1 value. Thermostatic control is turned off ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue
and homez.g:
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Apr 24 2021 19:02:10 GMT+0200 (hora de verano de Europa central) G91 ; relative positioning G1 H2 Z5 ; lift Z relative to current position G90 ; absolute positioning G1 X15.0 Y20.0 F6000 ; go to first probe point G30 ; home Z by probing the bed
Edit: by the way, I did do the calibration of the z probe but my G31 command has Z as 0.0 as I was doing several tests... the result is the same if I input my Z value (which also now I don't know if I can trust)
Thanks! -
@ballanux Where and how do you see the reported value ?
Through a notification in the DWC when I do the G30 command
@ballanux
Mine is like this.
M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H3 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-25 Y0 Z4.75 ; set Z probe trigger value, offset and trigger height
M557 X10:340 Y10:330 S200 ; define mesh gridWhen I send G30 command the reported value is always 4.75.
@hiroaki said in BLTouch always reports same value:
Even if you purposedly change the distance? shouldn't you read a different value if for example put a piece of paper in between? If it always reads the same value... how are you supposed to do the calibration procedure? Or do I have to read the value in a different way?
@ballanux In my code 4.75 is the difference of the sensing point(level) of BL touch and top of the nozzle. So even if I put a paper on it the reported value will be the same.
So if you put a paper T=0.1 and send G30, the height of the nozzle will be also a 0.1mm higher. -
So if you put a paper T=0.1 and send G30, the height of the nozzle will be also a 0.1mm higher.mmm you are correct, as the bed is moving it will not matter if I put anything in between, a bit of a brain fart on my part....
I tried to find the root cause of my problem, which is that I haven't been able to do an automatic bed leveling yet... but in doing so I asked the wrong question
I think is better that I keep digging and do another post when I have more concrete information then
Thanks, it has been quite helpfull as I was stuck thinking it was the sensor's fault
@ballanux Regarding the calibration. For eg.
Accroding to my code G31 ....Z4.75.
The send G30 or 31 command then you get the report of 4.75.
The you start printing.
The machine move the nozzle down to certain value 0.1(eg).
This nozzle location is 4.65mm down from the point the BL touch sensed.
So in this case if you feel the nozzle has to be 0.2 mm higher, the you need to change the value 4.75 to 4.55.
of if you have a thickness gauge maybe you can measure the height and adjust like above. -
@ballanux When I first put BL touch, I thought the same way!
Here is my eg for you.
Mine has four lead screws and automatically level the bed !
It's very convenient!
Cheers.
M557 X10:340 Y10:330 S200 ; define mesh grid;leadscrews location
M671 X410:410:-65:-65 Y35:305:305:35 S10 ; leadscrews at rear left, front left, front right, and rear rightAnd the following is the code of deployprobe.g
; deployprobe.g
; called to deploy a physical Z probe
; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Aug 04 2020 21:15:41 GMT+0900 (日本標準時)
M280 P7 S10 ; deploy BLTouchAnd following is retractprobe.g
; retractprobe.g
; called to retract a physical Z probe
M280 P7 S90 ; retract BLTouch
