    BLTouch Always reports -3.00mm
    • Kiomatriundefined
      Kiomatri
      Hello All,
      I have the following hardware:
      • Genuine BLTouch v3.1
      • Duet3 6HC
      • Duet3 ex 3HC
      • Z Axis with 3 steppers
      When executing the steps written in Test and calibrate the Z probe, I always get the message back "Probe stopped at -3.00mm" whatever I do.
      Homing however, is no problem.
      • I increased / decreased the distance of the BLTouch with washers
        (Between 10 to 6 mm from bottom of BLTouch to end of printhead)
      • I tried playing around with the Z trigger height
      • Checked the wiring of course
      What am I doing wrong? I'm lost...
      The following is my config.g:
      (The {1}'s seem to be added by this site, I don't know where they are coming from...)
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Jul 29 2020 22:00:06 GMT+0200 (Midden-Europese zomertijd)
      M83                                               ; ...but relative extruder moves
      M550 P"Monstro"                       ; set printer name
      M551 P"******"
      M552 P0.0.0.0 S1
      M586 P0 S1
      M586 P1 S0
      M586 P2 S0
      M569 P0.0 S1
      M569 P0.1 S0
      M569 P0.2 S0
      M569 P0.3 S1
      M569 P0.4 S1
      M569 P0.5 S1
      M569 P1.0 S0
      M569 P1.1 S0
      M569 P1.2 S0
      ; set drive mapping
      M584 X0.0:0.1 Y0.2:0.3 Z1.0:1.1:1.2 E0.4:0.5
      ; configure microstepping with interpolation
      M350 X16:16 Y16:16 Z16:16:16 E16:16 I1
      ; set steps per mm
      M92 X160.00 Y160.00 Z1600.00 E420.00:420.00
      ; set maximum instantaneous speed changes (mm/min)
      M566 X900.00 Y900.00 Z200.00 E120.00
      ; set maximum speeds (mm/min)
      M203 X6000.00 Y6000.00 Z800.00 E1200.00
      ; set accelerations (mm/s^2)
      M201 X500.00 Y500.00 Z20.00 E250.00
      ; set motor currents (mA) and motor idle factor in per cent
      M906 X1200 Y1200 Z1600 E1200 I30
      ; Set idle timeout
      M84 S30
      M208 X0 Y0 Z0 S1
      M208 X550 Y500 Z740 S0
      M574 X1 S1 P"!io0.in"
      M574 Y1 S1 P"!io1.in"
      M574 Z1 S2
      M950 S0 C"io7.out"
      M558 P9 C"^io7.in" H4 F120 T6000 R0.5
      G31 P500 X-40 Y-10 Z1
      M557 X15:545 Y5:495 P4
      M308 S0 P"temp0" Y"thermistor" T100000 B4138
      M950 H0 C"out1" T0
      M307 H0 B0 S1.00
      M308 S1 P"temp1" Y"thermistor" T100000 B4138
      M950 H1 C"out2" T1
      M307 H1 B0 S1.00
      M950 F0 C"out4" Q500
      M106 P0 S1 H1 T45
      M950 F1 C"out5" Q500
      M106 P1 S1 H1 T45
      M563 P0 S"ext1" D0 H0 F0
      G10 P0 X0 Y0 Z0
      G10 P0 R0 S0
      M563 P1 S"ext2" D1 H1 F0
      G10 P1 X0 Y31.3 Z0
      G10 P1 R0 S0
      ; NeoPixels
      M150 X1
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
      droftartsundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @Kiomatri
        @Kiomatri said in BLTouch Always reports -3.00mm:
        The io7.in pin shouldn’t need to be inverted pulled up. Your probe is probably reading 1000, ie already triggered. Remove the ‘^’. See https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3
        1. The Z probe input pin will be zprobe.in on a Duet 2, or one of io4.in, io5.in or io7.in on a Duet 3. If using zprobe.in, you need to enable the pullup resistor using the ^ character in front of the pin name.
        Kiomatriundefined 1 Reply Last reply Reply Quote 0
        • Kiomatriundefined
          Kiomatri @droftarts
          @droftarts Hey Ian, Thanks for your reply.
          Sadly, that doesn't seem to fix the -3.00mm I get from performing the G30 S-1 command 😞
          (Also, I'm not constantly seeing 1000, that seems to do what it should)
          Vetiundefined 1 Reply Last reply Reply Quote 0
          • Thaliosundefined
            Thalios
            in your home (either homeall or homez) macro, do you have a g92? I had that for Z for some reason and it reset its position and I could not figure it out.
            Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
            Heavily modified Ender 3 Pro (Duet 3 6HC)
            Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
            CR-10S Pro V2 (Duet 3 Mini 5+)
            and a bunch of SLA printers..
            • Vetiundefined
              Veti @Kiomatri
              that is correct for the bltouch, it only triggers for a split second, you might never see it triggered in the web ui.
                Phaedrux Moderator @Kiomatri
                A negative number here sounds very wrong and also very weird that it's exactly 3. How exactly are you doing the steps described to test the trigger height?
