    setting Retraction after restart
    286
    • bastienundefined
      bastien
      hi, after restarting my printer i lost the retraction setting
      however I have M207 S4.0 F5000 Z0.5 in config.g and also in filament config,
      but after a restart I have 2mm retraction at 16mm / s
      what did I miss?
      • SIamundefined
        SIam
        please post your config.g file
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        • bastienundefined
          bastien
           Configuration file for Duet WiFi (firmware version 3)
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Aug 27 2020 18:42:39 GMT+0200 (heure d’été d’Europe centrale)
          G90                                            ; send absolute coordinates...
          M83                                            ; ...but relative extruder moves
          M550 P"Predator"                               ; set printer name
          M665 L440.000 R226 B185.0 H456                       ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0 Y0 Z0 A0.00 B0.00                                  ; put your endstop adjustments here, or let auto calibration find them
          M552 S1                                        ; enable network
          M586 P0 S1                                     ; enable HTTP
          M586 P1 S1                                     ; disable FTP
          M586 P2 S0                                     ; disable Telnet
          M569 P0 S0                                     ; physical drive 0 goes forwards
          M569 P1 S0                                     ; physical drive 1 goes forwards
          M569 P2 S0                                     ; physical drive 2 goes forwards
          M569 P3 S1                                     ; physical drive 3 goes forwards
          M584 X0 Y1 Z2 E3                               ; set drive mapping
          M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
          M92 X80 Y80 Z80 E498.8; set steps per mm
          M566 X1000 Y1000 Z1000 E1000       ; set maximum instantaneous speed changes (mm/min)
          M203 X12000 Y12000 Z12000 E1200    ; set maximum speeds (mm/min)
          M201 X3000 Y3000 Z3000 E3000       ; set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1000 E1000 I30                ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                        ; Set idle timeout
          ; Retraction
          M208 Z0 S1                                     ; set minimum Z
          M574 X2 S1 P"xstop"                            ; configure active-high endstop for high end on X via pin xstop
          M574 Y2 S1 P"ystop"                            ; configure active-high endstop for high end on Y via pin ystop
          M574 Z2 S1 P"zstop"                            ; configure active-high endstop for high end on Z via pin zstop
          M558 P5 C"e0stop" H8 F120 T6000            ; set Z probe type to switch and the dive height + speeds
          M558 H10                                       ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
          G31 P500 X0 Y0 Z17.0                         ; set Z probe trigger value, offset and trigger height
          M557 R175 S20                               				; Define mesh grid
          G29 S1
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4300 ; configure sensor 0 as thermistor on pin bedtemp
          M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
          M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                        ; map heated bed to heater 0
          M143 H0 S80                                    ; set temperature limit for heater 0 to 80C
          M308 S1 P"e0temp" Y"thermistor" T100000 B4300  ; configure sensor 1 as thermistor on pin e0temp
          M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
          M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
          M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
          M563 P0 D0 H1 F0                               ; define tool 0
          G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
          G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
          M572 D0 S0.1												; Pressure Advance
          ;M591 D0 P2 C"e1stop" S0											; Activate filament sensor
          M404 N1.75 													; Set for print monitor
          M592 D0 A0.07772 B-0.00029 		; Nonlinear extrusion. Set parameters for extruder drive 0
          M575 P1 S1 B57600                              ; enable support for PanelDue
          M501
          SIamundefined 1 Reply Last reply Reply Quote 0
          • SIamundefined
            SIam @bastien
            @bastien said in setting Retraction after restart:
            would say you should define your tool first and then add the retract settings add :
            after the tool definition
            • bastienundefined
              bastien
              I will test, but normally the setting of the filament config will have to be taken care of on T0 then that the filament is loaded
              • bastienundefined
                bastien
                Even with T0 before, the settings are not loaded, I also tested to keep only the filament config, same result after a restart,
                while waiting to find a solution, I will put it in my macro, start print, so as not to forget
                • SIamundefined
                  SIam @bastien
                  @bastien You misunderstood me. You have defined the settings for the retract in your configuration in line 33. Your tool is first defined from line 68 onwards so put your M207 after line 71
                  bastienundefined 1 Reply Last reply Reply Quote 1
                  • bastienundefined
                    bastien @SIam
                    @siam it works, in config after line 68, thanks
