    Software package 3.3-rc2 released
    Beta Firmware
    8
    28
    2.0k
      dc42 administrators @SIam
      @siam said in Software package 3.3-rc2 released:
      M955 P0 C"spi.cs3+spi.cs4" S4800 Q10000000 R12 I20
      You are right, the code doesn't allow Q10000000 but does allow Q9999999. I will fix this in 3.3 stable.
        dc42 administrators @MartinNYHC
        @martinnyhc said in Software package 3.3-rc2 released:
        Is that something to address?
        May 16 10:49:24 Cube DuetControlServer[197]: [warn] IPC#16: Client with outdated protocol version connected (got 7, want 11)
        We need to update the Go and Python client APIs that can be used on the Pi. Are you using one of those?
        MartinNYHCundefined 1 Reply Last reply Reply Quote 0
        • MartinNYHCundefined
          MartinNYHC @dc42
          @dc42 Yes, the Python API.
            dc42 administrators @EducatingSavvas
            @educatingsavvas said in Software package 3.3-rc2 released:
            @dc42 said in Software package 3.3-rc2 released:
            be working well and we hope to release 3.3 stable next week. So you have only a few days left to report issues in firmware 3.3RC2 that were not present in the last stable release (3.2.2).
            Hiya - I've updated to RRF 3.3RC2 and having trouble turning the router spindle on/off. I've amended the following in my config.g file.
            M453						; Set to CNC mode
            M950 R0 C"e1heat+e0heat" L0:24000 Q300		; Select Spindle On/Off,RPM & Direction
            M563 P1 S"Spindle" R0				; Define Tool
            If I try to turn the spindle on with RPM speed of 5000, using an M3 S5000 I get this error:
            Warning: M3: No spindle selected via P and no active tool with spindle
            If I send M3 S5000 P1 I get the following error:
            Error: M3: internal error at file../src/GCodes/GCodeBuffer/StringParser.cpp(1362)
            I confirm this is a bug. Please try the new binary at https://www.dropbox.com/sh/zbqzr0g7h4x0jqt/AADYby53148rqmRx9UdCPrBxa?dl=0 and let us know whether it behaves as you expect.
            EDIT: I have just updated those binaries to fix M4 as well.
            EducatingSavvasundefined 1 Reply Last reply Reply Quote 1
            • EducatingSavvasundefined
              EducatingSavvas @dc42
              That seems to work now - although I'm not aware of any CNC platforms using g-code in that way. Normally the tool is specified with T followed by the number in the software's tool database. I am planning to have three tools on my CNC machine - one router spindle, a diode laser and a tangential knife. Are there any particular advantages for the change?
              • BoAundefined
                BoA
                I noticed a strange behavior after I updated from 3.2.2 to 3.3RC2.
                I have a filament presence switch that I use for triggering filament load macro.
                After I updated to 3.3RC2 it seems to be a lot of false triggers.
                Powering up printed, it does nothing for about 3 minutes and suddenly starts triggering and display messages:
                Error: Attempting to extrude with no tool selected.
                I do not need to start print or do anything. Just power on printer and wait.
                Duet3 standalone setup.
                My config files:
                trigger3.g
                config.g
                fs_enable.g
                fs_disable.g
                fs_config.g
                dc42undefined 2 Replies Last reply Reply Quote 0
                • oozeBotundefined
                  oozeBot
                  We need to report a significant issue in 3.3-rc2 when using a 6HC with attached SBC.
                  When canceling a print, "stop.g" is called, not "cancel.g" like in previous versions of the firmware. This was validated by putting M291 P"Stop" at the top of stop.g and M291 P"Cancel" at the top of cancel.g.
                    dc42 administrators @BoA
                    @boa said in Software package 3.3-rc2 released:
                    My config files:
                    trigger3.g
                    config.g
                    fs_enable.g
                    fs_disable.g
                    fs_config.g
                    I doubt that this has anything to do with firmware changes. I think your filament out switch is getting triggered, or picking up interference, or has a bad connection. You enable it in config.g but your trigger3.g file doesn't check whether there is a current tool, or that a file is being printed and has not been paused.
                    BoAundefined 1 Reply Last reply Reply Quote 0
                      dc42 administrators @oozeBot
                      @oozebot said in Software package 3.3-rc2 released:
                      Thanks, I've asked @chrishamm to take a look.
                      • BoAundefined
                        BoA @dc42
                        @dc42 I would think that is the case if such behavior was also on 3.2.2, but with 3.2.2 it works just fine without false triggers.
                          Have you tried switching between 3.2.2 and 3.3RC2 more than once? It wouldn't be the first time that the first appearance of a problem caused by a bad connection happened to coincide with a firmware update.
                          • BoAundefined
                            BoA @dc42
                            @dc42 Yes. Reverting to 3.2.2 fixes that strange behavior. I tried 3 times. I did not try intermediate versions to identify which one introduces that.
                            Edit: This behavior is in 3.3beta1
                            • chrishammundefined
                              chrishamm administrators
                              Thanks for your report, I've got a fix ready for this.
                              Duet software engineer
                                @boa I am trying to reproduce your issue. So far the trigger hasn't gone off; but I have nothing connected to IO8_IN. What type of filament switch is it? Is is closed when filament is present, and open when it is not; or the other way round? Do you have filament in in when this issue occurs?
                                dc42undefined Serbitarundefined 3 Replies Last reply Reply Quote 0
                                  dc42 administrators @dc42
                                  For those testing with 3.3RC3 the latest firmware binaries are at https://www.dropbox.com/sh/duc057ejldxhl48/AADiuF-oiz9EmkFX6HCeodxTa?dl=0. The change list since the 3.3RC2 release is https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta-&-RC#reprapfirmware-33-post-rc2.
                                    My test system has been sitting for almost 9 hours, and still no false triggers.
                                    • Serbitarundefined
                                      Serbitar @dc42
                                      @dc42 will these soon be pushed to the apt repos?
                                      • BoAundefined
                                        BoA @dc42
                                        @dc42 This is just a transoptor (Prusa MK3S filament sensor). I just disabled it for now. Not essential feature as I am using magnetic filament monitors. It was used only for loading filament. I have filament loaded when I can see false triggers - no light is going through sensor, so output is in low state.
                                          Thanks. I'll re-run my test with io8.in connected to ground.
                                            @boa, I left my machine on for 9 hours with io3.in connected to ground, and I didn't see any false triggers. So I am fairly sure that the issues you are seeing are caused by noise pickup or that the sensor is generally producing spurious triggers. It may be that RRF 3.3 response to noise pulses faster than previous versions, because the loop that polls the triggers is no longer responsible for managing motion, so it may execute faster.
                                            If the sensor cable run close to a stepper motor cable, and the false triggers only occur when that stepper motor is energised, then it may be that the sensor cable is picking up inductive interference from the stepper motor cable.
