    slow fan
    585
      How do you have it configured?
      Mentaluproarundefined 1 Reply Last reply Reply Quote 0
      • Mentaluproarundefined
        Mentaluproar @Phaedrux
        @phaedrux
        M950 F0 C"fan1" Q500                                                        ; create fan 0 on pin fan1 and set its frequency
        M106 P0 C"part cooler" S0 H-1                                               ; set fan 0 name and value. Thermostatic control is turned off
        M950 F1 C"duex.fan5" Q500                                                   ; create fan 1 on pin duex.fan5 and set its frequency
        M106 P1 C"hotend" S0 H1:2 T60                                               ; set fan 1 name and value. Thermostatic control is turned on
        M950 F2 C"duex.fan6" Q500                                                   ; create fan 2 on pin duex.fan6 and set its frequency
        M106 P2 C"lighting" S1 H-1                                                  ; set fan 2 name and value. Thermostatic control is turned off
          Try changing the S0 to S1. When the temp is reached, you want it to turn on (S1), not off (S0).
            @phaedrux Thanks, but that doesn't solve the issue of fan speed. its still much slower than a direct connection to the power supply.
              I wonder if it's the mosfet on the Duex. The other fan headers on the duex work fine?
                @phaedrux It's the strangest thing, but all of them do this. It's a consistent behavior.
                  droftarts administrators @Mentaluproar
                  @mentaluproar can you show your full config.g?
                    Also please post the results of M122 and M98 P"config.g"
                      Config.g
                      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri May 14 2021 22:58:27 GMT-0400 (EDT)
                      G90        ; send absolute coordinates...
                      M83        ; ...but relative extruder moves
                      M550 P"foamboard forge"                                                     ; set printer name
                      M552 S1        ; enable network
                      M586 P0 S1        ; enable HTTP
                      M586 P1 S0        ; disable FTP
                      M586 P2 S0        ; disable Telnet
                      M569 P0 S1        ; physical drive 0 goes forwards
                      M569 P1 S1        ; physical drive 1 goes forwards
                      M569 P2 S0        ; physical drive 2 goes backwards
                      M569 P5 S1        ; physical drive 5 goes forwards
                      M584 X0 Y1 Z2 E5                                                            ; set drive mapping
                      M350 X16 Y16 Z16 E16 I1                                                     ; configure microstepping with interpolation
                      M92 X80.00 Y80.00 Z400.00 E686.66                                           ; set steps per mm
                      M566 X900.00 Y900.00 Z12.00 E120.00                                         ; set maximum instantaneous speed changes (mm/min)
                      M203 X6000.00 Y6000.00 Z1800.00 E1200.00                                    ; set maximum speeds (mm/min)
                      M201 X500.00 Y500.00 Z20.00 E250.00                                         ; set accelerations (mm/s^2)
                      M906 X800 Y800 Z800 E350 I30                                                ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30        ; Set idle timeout
                      M208 X0 Y0 Z0 S1                                                            ; set axis minima
                      M208 X300 Y300 Z350 S0                                                      ; set axis maxima
                      M574 X1 S1 P"xstop"                                                         ; configure active-high endstop for low end on X via pin xstop
                      M574 Y1 S1 P"ystop"                                                         ; configure active-high endstop for low end on Y via pin ystop
                      M574 Z1 S2        ; configure Z-probe endstop for low end on Z
                      M950 S0 C"duex.pwm3"                                                      ; create servo pin 0 for BLTouch
                      M558 P9 C"^zprobe.in" H5 F120 T6000                                        ; set Z probe type to bltouch and the dive height + speeds
                      G31 P500 X27 Y14.2 Z4.122                                                   ; set Z probe trigger value, offset and trigger height
                      M557 X10:290 Y10:290 S20                                                    ; define mesh grid
                      M308 S0 P"e0temp" Y"thermistor" T100000 B4138                              ; configure sensor 0 as thermistor on pin bedtemp
                      M950 H0 C"e1heat" T0                                                        ; create bed heater output on e0heat and map it to sensor 0
                      M307 H0 B0 S1.00                                                            ; disable bang-bang mode for the bed heater and set PWM limit
                      M140 H0        ; map heated bed to heater 0
                      M143 H0 S120        ; set temperature limit for heater 0 to 120C
                      M308 S1 P"duex.e2temp" Y"thermistor" T100000 B4138                          ; configure sensor 1 as thermistor on pin duex.e2temp
                      M950 H1 C"duex.e2heat" T1                                                   ; create nozzle heater output on duex.e2heat and map it to sensor 1
                      M307 H1 B0 S1.00                                                            ; disable bang-bang mode for heater  and set PWM limit
                      M143 H1 S280        ; set temperature limit for heater 1 to 280C
                      M950 F1 C"duex.fan5" Q31600                                                   ; create fan 1 on pin duex.fan5 and set its frequency
                      M563 P0 S"hotend" D0 H1 F0                                                  ; define tool 0
                      G10 P0 X0 Y0 Z0                                                             ; set tool 0 axis offsets
                      G10 P0 R0 S0        ; set initial tool 0 active and standby temperatures to 0C
                      ; Custom settings
                      M308 S2 P"duex.e3temp" Y"thermistor" A"chamber temp" T100000 B3988 C0 R2200 ; chamber temperature sensor
                      M307 H0 A77.5 C296.9 D3.8 C24.1 B0                                 ; calibrate bed heater
                      M307 H1 A348.9 C165.7 D3.7 C24.2 B0                                ; calibrate hotend heater
                      ; TODO
                      ; When a seperate lighting control method is found, break lighting out from fan controls
                      M122
                      M122
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later + DueX2
                      Board ID: 08DDM-9FAM2-LW4SD-6J9F4-3S46Q-92XHW
                      Used output buffers: 3 of 24 (10 max)
                      Static ram: 23460
                      Dynamic ram: 73880 of which 24 recycled
                      Never used RAM 14716, free system stack 189 words
                      Tasks: NETWORK(ready,169) HEAT(blocked,308) DUEX(blocked,31) MAIN(running,449) IDLE(ready,20)
                      Owned mutexes: WiFi(NETWORK)
                      Last reset 00:02:12 ago, cause: power up
                      Last software reset at 2021-05-15 00:11, reason: User, GCodes spinning, available RAM 14716, slot 0
                      Error status: 0x00
                      Aux0 errors 0,0,0
                      MCU temperature: min 21.1, current 27.7, max 28.5
                      Supply voltage: min 24.1, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 0: position 0, standstill, SG min/max not available
                      Driver 1: position 0, standstill, SG min/max not available
                      Driver 2: position 0, standstill, SG min/max not available
                      Driver 3: position 0, standstill, SG min/max not available
                      Driver 4: position 0, standstill, SG min/max not available
                      Driver 5: position 0, standstill, SG min/max not available
                      Driver 6: position 0, standstill, SG min/max not available
                      Driver 7: position 0
                      Driver 8: position 0
                      Driver 9: position 0
                      Driver 10: position 0
                      Driver 11: position 0
                      Date/time: 2021-05-17 22:44:34
                      Cache data hit count 159721035
                      Slowest loop: 8.67ms; fastest: 0.21ms
                      === Storage ===
                      Free file entries: 10
                      SD card longest read time 3.9ms, write time 0.0ms, max retries 0
                      === MainDDARing ===
                      === AuxDDARing ===
                      Segments left: 0
                      Movement lock held by null
                      HTTP is idle in state(s) 0
                      Telnet is idle in state(s) 0
                      File is idle in state(s) 0
                      USB is idle in state(s) 0
                      Aux is idle in state(s) 0
                      Trigger is idle in state(s) 0
                      Queue is idle in state(s) 0
                      LCD is idle in state(s) 0
                      Daemon is idle in state(s) 0
                      Code queue is empty.
                      === Network ===
                      Slowest loop: 15.65ms; fastest: 0.00ms
                      HTTP sessions: 1 of 8
                      - WiFi -
                      Network state is active
                      WiFi firmware version 1.25
                      WiFi MAC address 60:01:94:34:39:67
                      WiFi Vcc 3.40, reset reason Turned on by main processor
                      WiFi flash size 4194304, free heap 26176
                      WiFi IP address 10.0.0.17
                      WiFi signal strength -47dBm, mode 802.11n, reconnections 0, sleep mode modem
                      Clock register 00002002
                      === DueX ===
                      Read count 1, 0.45 reads/min
                      M98
                      M98 P"config.g"
                      HTTP is enabled on port 80
                      FTP is disabled
                      TELNET is disabled
                        What position is the voltage select jumper in? Vin, 12v, or 5v?
                        Does disconnecting the LEDs make a difference?
                        Does changing the PWM frequency make a difference?
                        Mentaluproarundefined 1 Reply Last reply Reply Quote 1
                          @phaedrux It's at 12v....because the LEDs are 12v, but the rest of the system is 24v! Of course!
                          I'll try fixing this tomorrow but I seem to remember there was some reason I had it wired up this way.
                          EDIT: I remember, I blew some of the mosfets on the duet over the years so the duet fan headers don't work right, hence I used the deus. I really should fix this things properly someday
