    step/mm depend on microsteps ?
    • Pseud3mysundefined
      Pseud3mys
      Hi !
      I use BMG x2 extruder and the fabricant say: "E-step value 415" but when I put in config:
      M92 E415.00:415.00
      The feed amout is not accurate (under the real lenght). The Estep value 415 can't be wrong so what I need to change for the M92 command ?
      Thank you !
      Alexandre
      PS: The gear ratio is 3:1 and the controller microstep is 32.
        jay_s_uk @Pseud3mys
        @pseud3mys that 415mm value is based on 16 steps, so for 32 steps you need 830.
        But in any case, that value is only a guide and extruder calibration should be carried out https://teachingtechyt.github.io/calibration.html#esteps
        Pseud3mysundefined 1 Reply Last reply Reply Quote 0
          Pseud3mys @jay_s_uk
          @jay_s_uk okay thank you !
