    noob help dule z setup
    2.4k
    • Mobietecundefined
      Mobietec @Phaedrux
      @phaedrux
      @phaedrux my updated config file
      i cant get the bltouch to deply now grrr i am trying to look for answers befor i post first i have the bl on io3 now their are two grounds form touch that are wired together sence on io out and triger on ioin
      i have checked for contunety lol i cant spell today and i have also tried 3.3 and 5v lines and i have tried diffrent probs still get same
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed May 19 2021 20:59:11 GMT+0100 (British Summer Time)
      M550 P"Raptor CoreXY" ; set printer name
      M669 K1 ; select CoreXY mode
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0.2 S0 ; physical drive 0.2 goes forwards
      M569 P0.4 S0 ; physical drive 0.4 goes forwards
      M584 X0.0 Y0.1 Z0.2 E0.3:0.4 ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E440.00:400.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00:60.00
      M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1 ; set maximum instantaneous speed changes (mm/min)
      ;M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      ;M208 X-5:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:180.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-165 Y-165 Z0 S1 ; set axis minima
      M208 X165 Y165 Z400 S0 ; set axis maxima
      M574 X1 S1 P"io1.in" ; configure active-high endstop for low end on X via pin io1.in
      M574 Y1 S1 P"io2.in" ; configure active-high endstop for low end on Y via pin io2.in
      M574 Z2 S2 C"io4.in" ; configure Z-probe endstop for low end on Z
      M950 S0 C"io4.out" ; create servo pin 0 for BLTouch
      M558 P9 C"io4.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-30 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X-155:130 Y-155:155 P5 ; define mesh grid
      ;M558 A10 S0.003 B0 R0.2 ; BLTouch extra settings from Phaedrux
      G31 P500 X-37.6 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M307 H0 R0.612 C635.3 D7.63 S1.00 V24.4 ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M307 H1 R3.322 C149.5 D6.72 S1.00 V24.3 ; disable bang-bang mode for heater and set PWM limit
      M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
      M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
      M950 F2 C"out6" Q500 ; create fan 2 on pin out6 and set its frequency
      M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
      M950 F3 C"out7" Q500 ; create fan 3 on pin out7 and set its frequency
      M106 P3 S1 H1 T45 ; set fan 3 value. Thermostatic control is turned on
      M950 F4 C"out8" Q500 ; create fan 4 on pin out8 and set its frequency
      M106 P4 S1 H1 T45 ; set fan 4 value. Thermostatic control is turned on
      Phaedruxundefined 2 Replies Last reply Reply Quote 0
        Does M401 and M402 work?
        Does M280 P0 S10 or M280 P0 S90 work?
        What do you have in your deploy and retract macros?
        Are those deploy and retract macros located in your /sys/ folder?
        Mobietecundefined 1 Reply Last reply Reply Quote 0
        • Mobietecundefined
          Mobietec
          @phaedrux no im trying a clean install see if that helps
          • Mobietecundefined
            Mobietec @Phaedrux
            @phaedrux said in noob help dule z setup:
            no
            no
            ; deployprobe.g
            ; called to deploy a physical Z probe
            ; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu May 20 2021 20:02:55 GMT+0100 (British Summer Time)
            M280 P0 S10 ; deploy BLTouch
            ; retractprobe.g
            ; called to retract a physical Z probe
            M280 P0 S90 ; retract BLTouch
            yes
              99.9% of the time it's wiring.
              • Mobietecundefined
                Mobietec @Phaedrux
                @phaedrux i fully understand that i have checked and rechecked im using duet 3
                bl conected to io3
                5volt to 5volt in bl
                io out to sig
                both grounds from bl to gnd
                and out(z) to io3 in
                rom socket to bl no broken conections and correct readings ie cable conected ok
                hope this helps
                  Phaedrux Moderator @Mobietec
                  @mobietec said in noob help dule z setup:
                  bl conected to io3
                  io out to sig
                  Are you using io3 or io4?
                  • Mobietecundefined
                    Mobietec @Phaedrux
                    @phaedrux io3
                      If you are connected to io3.... and your config is using io4....
                      • Mobietecundefined
                        Mobietec @Phaedrux
                        @phaedrux i changed it just in case that was a problem port made no diffreance im pulling my hair out i have tested both bl in a marlin boards and work as they should just will not work in here
                        i have also reflashed board to 3.2 no luck i was on 3.3 so im going to put that back on
                          Ok, so your config is using io3 now as well?
                          when you tested on the marlin boards did you use the same cable harness?
                          Can you show a photo of your BLtouch connection at the duet board io3 connection?
                          • Mobietecundefined
                            Mobietec @Phaedrux
                            @phaedrux yes same harness i have to change pins over so 5v n sig were correct
                            Mobietecundefined 3 Replies Last reply Reply Quote 0
                            • Mobietecundefined
                              Mobietec @Mobietec
                              This post is deleted!
                              • Mobietecundefined
                                Mobietec @Mobietec
                                • Mobietecundefined
                                  Mobietec @Mobietec
                                  @mobietec alt text
                                  links to photos i hope
                                    droftarts administrators @Mobietec
                                    @mobietec Yellow pin crimp looks like it's up, not in the crimp shell properly. May not be making contact. Better to use the supplied Duet crimps and housings, rather than Molex Dupont connectors.
                                    Mobietecundefined 1 Reply Last reply Reply Quote 1
                                    • Mobietecundefined
                                      Mobietec @droftarts
                                      @droftarts i can promice you its making good contection the dupont socket is just temp and i did push it down fully after pic and check it still not working i do have another bl with duet socket still same problem
                                        @mobietec Sorry, should have remembered this before; see https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Duet_Num_3
                                        Connect the BLTouch to IO_7 ... It's also possible to use IO_4 or IO_5 instead of IO_7.
                                        (Edit: I've updated the text on the wiki to make it clearer.)
                                        You can't use IO_3!
                                        Only IO_4, IO_5 and IO_7 are PWM capable, so able to control a servo (like the BLTouch). See table here for IO pin capability: https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_IO.
                                        Use one of IO_4, IO_5 or IO_7 instead. So, with the BLTouch connected to IO_4, your config.g should be (which is what you had earlier):
                                        Also, this line is incorrect, and may be interfering:
                                        Are you wanting to use the endstop on the high end (as in where Z value is 'high', with the bed furthest from nozzle, so bed at the bottom of travel)? That's what 'Z2' means. Though 'S2' means probe not endstop, and the 'C' parameter is wrong (should be P). To set it up correctly, see https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3. For now, change it to:
                                        M574 Z0 ; No Z endstop
                                        Make these changes, test and post your config.g.
                                        • Mobietecundefined
                                          Mobietec
                                          yipeee got the bl working
                                          now got to work on bedsize and bed mesh because it probs outside
                                          of bed aeira
                                            Phaedrux Moderator @droftarts
                                            @droftarts said in noob help dule z setup:
                                            You can't use IO_3!
                                            Oof! that was on the tip of my brain yesterday. 😖
