    Z-axis up without homing macro
    2.2k
    • silver1882undefined
      silver1882 @silver1882
      I tested it and that works great thanks.
        silver1882 @fcwilt
        If I am away from my house and I have to cancel the print because of a problem my printer is no longer homed. I just wanted to be able to raise the head so it doesn't cool down setting on the part.
        • fcwiltundefined
          fcwilt @silver1882
          @silver1882 said in Z-axis up without homing macro:
          Why do you think canceling a print un-homes the printer?
            It would depend on what you have in cancel.g I think.
            • fcwiltundefined
              fcwilt @Phaedrux
              @phaedrux said in Z-axis up without homing macro:
              Well yes that certainly could happen.
              Though why there would be something in the file to do that escapes me at the moment. I haven't found any reason to date to do something that would un-home the printer.
              Curious.
                For instance in my cancel.g I home XY and then turn the motors off.
                • fcwiltundefined
                  fcwilt @Phaedrux
                  Why do you turn the motors off?
                  For me most times a canceled print is quickly followed by another attempt after an appropriate change or two.
                    I suppose just for noise. To start another print it would be re-homing anyway, and depending on why and when it was canceled it might be awhile before another attempt is made.
                    • fcwiltundefined
                      fcwilt @Phaedrux
                      Noise?
                      Do your steppers make noise when not moving?
                        Yeah there's a slight hum/whine when energized. Nothing too offensive. When I was setting up the macros I figured why not power them off?
                        • fcwiltundefined
                          fcwilt @Phaedrux
                          Evidence that great minds don't always think alike.
                            Phaedrux Moderator @fcwilt
                            @fcwilt
                            ; cancel.g
                            ; Run when the print is paused, and then canceled.
                            G10 P0 R0 S0		; Set hotend temp to 0
                            M140 S0			; Set bed temp to 0
                            M106 S255 		; Fan at 100 to cool nozzle and bed
                            M220 S100		; Set speed factor back to 100% in case it was changed
                            M221 S100		; Set extrusion factor back to 100% in case it was changed
                            M290 R0 S0 ; clear babystepping
                            M204 P1000 T4000	; Set printing and travel accelerations
                            M566 X900 Y900 Z30 	; Set maximum instantaneous speed changes (mm/min) (Jerk)
                            G28 XY			; home XY
                            M98 P"0:/sys/CurrentsNormal.g" ; return motor currents to normal
                            M98 P"0:/sys/ZSpeedsNormal.g" ; return Z axis speeds to normal
                            M84			; turn off steppers
                            G4 S60			; wait 1 minute for nozzle to cool
                            M107			; turn off the fan
                            M98 P"0:/macros/Musical Tunes/TwoBits.g" ; play a tune
                            I suppose now with conditional gcode the homing at the start of a print could easily be made optional, so the logic of turning off the motors since I need to re-home anyway isn't as valid.
