    Z-axis up without homing macro
    2.2k
      Don't feel bad, I have to open the wiki almost every time just to double check. I've started to remember by thinking that absolute starts with A, so it comes before relative, so it's G90. 😀
      • mrehorstdmdundefined
        mrehorstdmd @Phaedrux
        @phaedrux I do feel bad- I was looking at the wiki when I wrote it. The error just didn't register...
        • silver1882undefined
          silver1882 @Phaedrux
          Ok thanks I will give it a try as soon as my printer is done printing.
          fcwiltundefined silver1882undefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @silver1882
            @silver1882 said in Z-axis up without homing macro:
            Why do you have the M564 commands?
            If you are doing this during a print the printer must already be homed.
            silver1882undefined 1 Reply Last reply Reply Quote 0
              silver1882 @silver1882
              I tested it and that works great thanks.
                silver1882 @fcwilt
                If I am away from my house and I have to cancel the print because of a problem my printer is no longer homed. I just wanted to be able to raise the head so it doesn't cool down setting on the part.
                • fcwiltundefined
                  fcwilt @silver1882
                  Why do you think canceling a print un-homes the printer?
                    It would depend on what you have in cancel.g I think.
                    • fcwiltundefined
                      fcwilt @Phaedrux
                      @phaedrux said in Z-axis up without homing macro:
                      Well yes that certainly could happen.
                      Though why there would be something in the file to do that escapes me at the moment. I haven't found any reason to date to do something that would un-home the printer.
                      Curious.
                        For instance in my cancel.g I home XY and then turn the motors off.
                        • fcwiltundefined
                          fcwilt @Phaedrux
                          Why do you turn the motors off?
                          For me most times a canceled print is quickly followed by another attempt after an appropriate change or two.
                            I suppose just for noise. To start another print it would be re-homing anyway, and depending on why and when it was canceled it might be awhile before another attempt is made.
                            • fcwiltundefined
                              fcwilt @Phaedrux
                              Noise?
                              Do your steppers make noise when not moving?
                                Yeah there's a slight hum/whine when energized. Nothing too offensive. When I was setting up the macros I figured why not power them off?
                                • fcwiltundefined
                                  fcwilt @Phaedrux
                                  Evidence that great minds don't always think alike.
                                    Phaedrux Moderator @fcwilt
                                    @fcwilt
                                    ; cancel.g
                                    ; Run when the print is paused, and then canceled.
                                    G10 P0 R0 S0		; Set hotend temp to 0
                                    M140 S0			; Set bed temp to 0
                                    M106 S255 		; Fan at 100 to cool nozzle and bed
                                    M220 S100		; Set speed factor back to 100% in case it was changed
                                    M221 S100		; Set extrusion factor back to 100% in case it was changed
                                    M290 R0 S0 ; clear babystepping
                                    M204 P1000 T4000	; Set printing and travel accelerations
                                    M566 X900 Y900 Z30 	; Set maximum instantaneous speed changes (mm/min) (Jerk)
                                    G28 XY			; home XY
                                    M98 P"0:/sys/CurrentsNormal.g" ; return motor currents to normal
                                    M98 P"0:/sys/ZSpeedsNormal.g" ; return Z axis speeds to normal
                                    M84			; turn off steppers
                                    G4 S60			; wait 1 minute for nozzle to cool
                                    M107			; turn off the fan
                                    M98 P"0:/macros/Musical Tunes/TwoBits.g" ; play a tune
                                    I suppose now with conditional gcode the homing at the start of a print could easily be made optional, so the logic of turning off the motors since I need to re-home anyway isn't as valid.
