    Phone Accelerometer data and Input Shaping
    Using Duet Controllers
    592
    • CNCModellerundefined
      CNCModeller
      Hi All,
      I've found an droid app called Resonance, it records vibration data and then provides analysis.
      I've put my phone on my bed and these are the results
      Screenshot_2021-06-02-17-33-28-787_com.morganandwife.vibration.jpg Screenshot_2021-06-02-17-33-36-971_com.morganandwife.vibration.jpg Screenshot_2021-06-02-17-33-40-983_com.morganandwife.vibration.jpg
      I've plumped for 25Hz for my M593 F25, but I don't really know what I'm looking at.
      Edit. It's a polar printer so X and y are components of the bed rotation.
      Any thoughts?
      Many thanks
      Barry M
      Polar Duet3 Mini + 1HCL
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Wanhao D4S: Duet2
      https://forum.duet3d.com/post/296755
      K40 Laser, Duet2
      https://forum.duet3d.com/post/312082
      Wanhao D5S
      https://www.youtube.com/CNCModellerUK
      dc42undefined celulariundefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @CNCModeller
        Neat idea!
        As you are only measuring the bed movement, I find it odd that X and Y are so different. The "Unadjusted displacement profile" only show significant ringing in X, so I think the X ringing frequency centred on 20Hz is the one you should focus on.
        What movement command did you give it when you measured the acceleration?
        CNCModellerundefined 1 Reply Last reply Reply Quote 0
          CNCModeller @dc42
          @dc42 It was printing my latest test print,
          VID_20210602_175413.mp4
          Wanhao D4S: Duet2
          K40 Laser, Duet2
          Wanhao D5S
            @cncmodeller IMO it's better to to a deliberate sharp movement, longer than the period of any resonance. See https://duet3d.dozuki.com/Wiki/Accelerometers#Section_Using_accelerometers but in your case I suggest G1 H2 Y moves covering about 90 degrees in place of the G1 moves in that example.
            CNCModellerundefined 2 Replies Last reply Reply Quote 0
              CNCModeller @dc42
              @dc42 said in Phone Accelerometer data and Input Shaping:
              @cncmodeller IMO it's better to to a deliberate sharp movement, longer than the period of any resonance. See https://duet3d.dozuki.com/Wiki/Accelerometers#Section_Using_accelerometers but in your case I suggest a G1 H2 Yxxx move covering about 90 degrees.
              Thanks @dc42 , will do when this print has finished.
              Wanhao D4S: Duet2
              K40 Laser, Duet2
              Wanhao D5S
                CNCModeller @dc42
                Looks like 18Hz it is then...! 60deg bed rotation move triggered from my 12864 display 🙂
                Thanks for the insights @dc42 🙂
                Wanhao D4S: Duet2
                K40 Laser, Duet2
                Wanhao D5S
                • celulariundefined
                  celulari @CNCModeller
                  @cncmodeller Hi, nice find! can you share the link to the app? can't find it
                    CNCModeller @celulari
                    @celulari
                    This is the app, after an initial look I also upgraded to the paid version.
                    https://play.google.com/store/apps/details?id=com.morganandwife.vibration
                    Wanhao D4S: Duet2
                    K40 Laser, Duet2
                    Wanhao D5S
