Duet 3 restarts during printing
RepRapFirmware for Duet 3 MB6HC version 3.2.2 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
Try to install on all boards (if you have some additional boards) with the latest beta RRF 3.3 rc3
@siam
It was installed and i downgraded. All modules were disconnected. -
@redflash This error which is now showing in your log should be fixed with rrf 3.3 rc2 if you have the same error with 3.3 rc 3 please post the result from m122 with the latest firmware
@siam
It was the same with 3.3rc3, but in the log there was „cause:watchdog“.I‘ll update again i take a new M122.
@redflash please install the latest 3.3RC3+ build from https://www.dropbox.com/sh/nmpsl9a3jfsumm5/AAA6adSjEcd1AM_j5_tVberGa?dl=0 and try again. If is still resets, post another M122 report.
It still resets.6.6.2021, 17:21:15 M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.3RC3 (2021-05-26 12:29:42) running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode) Board ID: 08DJM-956BA-NA3TJ-6J1FG-3S86S-TU9YS Used output buffers: 10 of 40 (24 max) === RTOS === Static ram: 150784 Dynamic ram: 92436 of which 380 recycled Never used RAM 110592, free system stack 192 words Tasks: NETWORK(ready,25.8%,232) ETHERNET(notifyWait,0.1%,117) HEAT(delaying,0.0%,295) Move(notifyWait,0.0%,302) CanReceiv(notifyWait,0.0%,945) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,333) TMC(notifyWait,7.9%,93) MAIN(running,65.5%,924) IDLE(ready,0.6%,29), total 100.0% Owned mutexes: === Platform === Last reset 00:00:17 ago, cause: watchdog Last software reset at 2021-06-06 15:22, reason: MemoryProtectionFault mmarValid daccViol, GCodes spinning, available RAM 115676, slot 1 Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00427804 BFAR 0x000000cd SP 0x2041fbe0 Task MAIN Freestk 1670 ok Stack: 00000000 00000000 00000000 00000000 00000081 00442ab5 004296c6 41030000 00000000 00000001 00000000 0046b1e7 2042b6e4 00000000 00000000 0046b535 00000000 0046b6e9 a5a5a5a5 ffffffff 2042b6e4 2041e168 2042ba7c ffffffff 00000000 00000003 2042ba78 Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 Step timer max interval 130 MCU temperature: min 39.3, current 40.2, max 40.4 Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0 Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: position 0, standstill, reads 33139, writes 15 timeouts 0, SG min/max 0/0 Driver 1: position 0, standstill, reads 33139, writes 15 timeouts 0, SG min/max 0/0 Driver 2: position 0, standstill, reads 33139, writes 15 timeouts 0, SG min/max 0/0 Driver 3: position 0, standstill, reads 33139, writes 15 timeouts 0, SG min/max 0/0 Driver 4: position 0, standstill, reads 33140, writes 15 timeouts 0, SG min/max 0/0 Driver 5: position 0, standstill, reads 33140, writes 15 timeouts 0, SG min/max 0/0 Date/time: 2021-06-06 17:21:14 Slowest loop: 4.16ms; fastest: 0.05ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 1.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 157, send timeouts 155, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 90/0/0 Last cancelled message type 30 dest 127 === Network === Slowest loop: 2.33ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 1 of 8 - Ethernet - State: active Error counts: 0 0 1 0 0 Socket states: 5 2 2 2 2 0 0 0 6.6.2021, 17:16:25 M32 "0:/gcodes/CFFFP_towel_holder.gcode" File 0:/gcodes/CFFFP_towel_holder.gcode selected for printing
@redflash that's not the firmware from the folder that I linked to.
Oh man. Didn`t see the +. Hold on.. -
6.6.2021, 17:42:42 M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.3RC3+4 (2021-06-05 16:20:17) running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode) Board ID: 08DJM-956BA-NA3TJ-6J1FG-3S86S-TU9YS Used output buffers: 1 of 40 (18 max) === RTOS === Static ram: 150896 Dynamic ram: 92432 of which 392 recycled Never used RAM 110472, free system stack 216 words Tasks: NETWORK(ready,27.8%,272) ETHERNET(notifyWait,0.1%,117) HEAT(delaying,0.0%,331) Move(notifyWait,0.0%,302) CanReceiv(notifyWait,0.0%,946) CanSender(notifyWait,0.0%,373) CanClock(delaying,0.0%,340) TMC(notifyWait,7.0%,93) MAIN(running,64.4%,924) IDLE(ready,0.6%,29), total 100.0% Owned mutexes: === Platform === Last reset 00:00:18 ago, cause: software Last software reset at 2021-06-06 17:42, reason: MemoryProtectionFault mmarValid daccViol, GCodes spinning, available RAM 107616, slot 0 Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00427804 BFAR 0x20028009 SP 0x2041b168 Task MAIN Freestk 1657 ok Stack: 00000000 00000001 00000001 00000000 00000000 0047a427 0047a426 61030000 00000000 0047a427 2042b7e8 00000000 00000000 0047a76f 00000000 20419408 00000000 00000000 198a2d17 a5a5a5a5 a5a5a5a5 2042d834 00000000 00000001 00000000 0047a427 2042d834 Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 125 MCU temperature: min 40.7, current 41.2, max 41.3 Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0 Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: position 0, standstill, reads 38456, writes 15 timeouts 0, SG min/max 0/0 Driver 1: position 0, standstill, reads 38456, writes 15 timeouts 0, SG min/max 0/0 Driver 2: position 0, standstill, reads 38456, writes 15 timeouts 0, SG min/max 0/0 Driver 3: position 0, standstill, reads 38456, writes 15 timeouts 0, SG min/max 0/0 Driver 4: position 0, standstill, reads 38456, writes 15 timeouts 0, SG min/max 0/0 Driver 5: position 0, standstill, reads 38457, writes 15 timeouts 0, SG min/max 0/0 Date/time: 2021-06-06 17:42:41 Slowest loop: 4.01ms; fastest: 0.05ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 1.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 164, send timeouts 162, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 94/0/0 Last cancelled message type 30 dest 127 === Network === Slowest loop: 2.47ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 1 of 8 - Ethernet - State: active Error counts: 0 0 1 0 0 Socket states: 5 2 2 2 2 0 0 0 6.6.2021, 17:34:44 M32 "0:/gcodes/CFFFP_towel_holder.gcode" File 0:/gcodes/CFFFP_towel_holder.gcode selected for printing
@redflash thanks, I am looking into it.
@redflash I suspect a hardware fault. When did you purchase the Duet 3? For how many weeks or months did the printer work properly?
It‘s a Fysetc clone from Ali, 5 month in use.
I will throw that crap away and get a real one.Thanks a lot for your help.
