    New Build - Update Firwmate on Duet 2 Wifi
    Firmware installation
    295
    • alexusundefined
      alexus
      Hi, i just got my Duet 2 Wifi board and trying to do setup, I want to make sure im running latest firmware but wiki is bit confusing on even on whats the latest one is
      here is screen shot what i see on web interface.
      should this be updated? if so what files shroud i load? i tried loading v3 it too file looked like its loading but version did not change
      help is appreciated
        1.21 is a bit too old to go directly to RRF3.
        You'll have to decide if you want to try doing incremental updates to get to RRF3 or just use USB flash to load the latest firmware and then manually updating the DWC files on the SD card.
        If you want to do the incremental way, follow this post: https://forum.duet3d.com/topic/18962/firmware-not-updating/4?_=1623121773997
        If you want to do the USB flash method, follow this: https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_All_other_Duet_boards
        alexusundefined 1 Reply Last reply Reply Quote 0
        • alexusundefined
          alexus @Phaedrux
          @phaedrux
          direct USB firmware flash seams easier
          do i need to update Wifi?
            Phaedrux Moderator @alexus
            @alexus Yes the wifi server will also need to be updated. You can do that after flashing. Place the wifi server bin in the /sys folder and then use USB terminal to send M997 S1 to flash the wifi.
            Don't forget the DWC files in the /www folder.
            • alexusundefined
              alexus @Phaedrux
              @phaedrux
              where do i get latest ESP firmware? and which version is latest ? on that update page it its confusing (at least for me 🙂
                It will depend on which firmware version you are going to use, but it's usually included with the combined zip file for the particular firmware release. So for 3.2.2 it's part of that release as wifiserver.bin version 1.25.
                https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
                alexusundefined 2 Replies Last reply Reply Quote 0
                • alexusundefined
                  alexus @Phaedrux
                  @phaedrux
                  oh got it, yea im loading 3.2.2 for stability. just had storm and brown outs lucky update finished 1 min before we lost power. Now trying to figure out why wifi dows not start at all... (i did not update it yet though)
                  EDIT ok never mind had manually start wifi and some problem with SD card... lets try to update wifi
                  • alexusundefined
                    alexus @Phaedrux
                    @phaedrux
                    ok i got everything updated
                    thank you for helping!
                    now time to start connecting everything
