    Strange highmap problem
    • S1lencerundefined
      S1lencer
      Hi i have a slight problem adjusting my bed via meshbedleveling. Out of some strange behavior my G29 responds with a highmap some 5 or 6mm too deep. Mean deviation is acceptable, but i don't now if this works for printing in Case of compensating.
      Here is a picture of the highmap:
      Here is my config:
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Mar 12 2021 17:14:12 GMT+0100 (Mitteleuropäische Normalzeit)
      G4 S1
      G90        ; send absolute coordinates...
      M83        ; ...but relative extruder moves
      M550 P"ToolChanger"                                                        ; set printer name
      M669 K1        ; select CoreXY mode
      M552 P192.168.178.111 S1                                                           ; enable network and acquire dynamic address via DHCP
      M586 P0 S1        ; enable HTTP
      M586 P1 S0        ; disable FTP
      M586 P2 S0        ; disable Telnet
      M569 P0.0 S1                                                               ; physical drive 0.0 goes forwards 				Drive 0 X
      M569 P0.1 S1                                                               ; physical drive 0.1 goes forwards 				Drive 1 Y
      M569 P0.2 S1                                                               ; physical drive 0.2 goes forwards 				Drive 2 Z
      M569 P121.0 S1                                                             ; physical drive 121.0 goes forwards 			Drive Toolboard 121 E0
      M569 P122.0 S1                                                             ; physical drive 122.0 goes forwards 			Drive Toolboard 120 E1
      M569 P0.3 S0                                                               ; physical drive 0.3 goes forwards 				Drive 3 E2
      M569 P0.4 S0                                                               ; physical drive 0.4 goes forwards 				Drive 4 E3
      M569 P0.5 S0                                                               ; physical drive 0.5 goes forwards 				Drive 5 Coupler
      M584 X0.0 Y0.1 Z0.2 C0.5 E121.0:122.0:0.3:0.4                              ; set drive mapping
      M350 C8 I0        ; configure microstepping without interpolation
      M350 X16 Y16 Z16 E16:16:16:16 I1                                           ; configure microstepping with interpolation
      M92 X80.14 Y80.14 Z1600.00 C100 E417.10:417.10:466.793:466.793             ; set steps per mm
      M566 X400 Y400 Z8.00 C2 E40:40:6000:6000                                       ; set maximum instantaneous speed changes (mm/min)
      M203 X35000 Y35000 Z1200 C5000 E6000:6000:6000:6000                        ; set maximum speeds (mm/min)
      M201 X6000.00 Y6000.00 Z400.00 C400 E1200.00:1200.00:6500.00:6500.00       ; set accelerations (mm/s^2)
      M906 X1800 Y1800 Z1330 C400 E1200:1200:1200:1200 I30                       ; set motor currents (mA) and motor idle factor in per cent
      M84 S120        ; Set idle timeout
      ;Stall Detection
      M915 C S5 F0 H200 	  												    	; Coupler
      ;Stall Detection
      M915 X Y S4 F0 H400 												     	; X / Y Axes
      M208 X-56.5 Y-57.5 Z-6 C0 S1                                               ; set axis minima
      M208 X353.5 Y360 Z308 C260 S0                                                ; set axis maxima
      M574 X1 S3        ; configure sensorless endstop for low end on X
      M574 Y1 S3        ; configure sensorless endstop for low end on Y
      M574 Z1 S2				                                                   ; configure active-high endstop for low end on Z via pin io2.in
      ;M558 P1 R1 C"!io3.in" H10 F2400 A4 S0.05 T6000                                      ; set Z probe type to effector and the dive height + speeds NORMALERWEISE S0.03
      M558 P1 R1.0 C"!io3.in" H7 F500 T10000                                      ; set Z probe type to effector and the dive height + speeds
      G31 P500 X0 Y0 Z0                                                         ; set Z probe trigger value, offset and trigger height
      M557 X5:295 Y5:295 S40                                                     ; define mesh grid
      ;Bed
      M308 S0 P"temp0" Y"pt1000"                                                 ; configure sensor 0 as PT1000 on pin temp0
      M950 H0 C"out0" T0                                                         ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                                           ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0        ; map heated bed to heater 0
      M143 H0 S125                                                               ; set temperature limit for heater 0 to 125C
      ;Extruder 0
      M308 S1 P"121.temp0" Y"pt1000"                                             ; configure sensor 1 as PT1000 on pin 121.temp0
      M950 H1 C"121.out0" T1                                                     ; create nozzle heater output on 121.out0 and map it to sensor 1
      M307 H1 B0 S1.00                                                           ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S350                                                               ; set temperature limit for heater 1 to 350C
      ;Extruder 1
      M308 S2 P"122.temp0" Y"pt1000"                                             ; configure sensor 2 as PT1000 on pin 122.temp0
      M950 H2 C"122.out0" T2                                                     ; create nozzle heater output on 122.out0 and map it to sensor 2
      M307 H2 B0 S1.00                                                           ; disable bang-bang mode for heater  and set PWM limit
      M143 H2 S350                                                               ; set temperature limit for heater 2 to 350C
      ;Extruder 2
      M308 S3 P"spi.cs0" Y"rtd-max31865"                                         ; configure sensor 3 as thermocouple via CS pin spi.cs0
      M950 H3 C"out1" T3                                                         ; create nozzle heater output on out1 and map it to sensor 3
      M307 H3 B0 S1.00                                                           ; disable bang-bang mode for heater  and set PWM limit
      M143 H3 S350                                                               ; set temperature limit for heater 3 to 350C
      ;Extruder 3
      M308 S4 P"spi.cs1" Y"rtd-max31865"                                         ; configure sensor 4 as thermocouple via CS pin spi.cs1
      M950 H4 C"out2" T4                                                         ; create nozzle heater output on out2 and map it to sensor 4
      M307 H4 B0 S1.00                                                           ; disable bang-bang mode for heater  and set PWM limit
      M143 H4 S350                                                               ; set temperature limit for heater 4 to 350C
      M950 F0 C"121.out2+out2.tach" Q2500                                        ; create fan 0 on pin 121.out1 and set its frequency
      M106 P0 C"Tool 1 Lüfter" S1 H1 T45                                         ; set fan 0 name and value. Thermostatic control is turned on
      M950 F1 C"122.out2+out2.tach" Q2500                                        ; create fan 1 on pin 121.out2 and set its frequency
      M106 P1 C"Tool 2 Lüfter" S1 H2 T45                                         ; set fan 1 name and value. Thermostatic control is turned on
      M950 F2 C"out9" Q500													   ; create fan 2 on pin out7 and set its frequency
      M106 P2 C"Bauteilkühlung 1" S0 H-1                                         ; set fan 2 name and value. Thermostatic control is turned off
      M950 F3 C"out5+out5.tach" Q500                                             ; create fan 3 on pin out8 and set its frequency
      M106 P3 C"Bauteilkühlung 2" S0 H-1                                         ; set fan 3 name and value. Thermostatic control is turned off
      M950 F4 C"out8" Q2500                                                      ; create fan 4 on pin out9 and set its frequency
      M106 P4 C"Tool 3 Lüfter" S1 H3 T45                                         ; set fan 4 name and value. Thermostatic control is turned on
      M950 F5 C"out7" Q2500                      		                           ; create fan 5 on pin out4 and set its frequency
      M106 P5 C"Tool 4 Lüfter" S1 H4 T45                                         ; set fan 5 name and value. Thermostatic control is turned on
      M950 F6 C"out4+out4.tach" Q25000                                           ; create fan 5 on pin out5 and set its frequency
      M106 P6 C"Boardkühlung 1" S1 H1:2:3:4 T45                                  ; set fan 6 name and value. Thermostatic control is turned on
      M950 F7 C"!out6+out6.tach" Q25000                                          ; create fan 6 on pin out6 and set its frequency
      M106 P7 C"Gehäusekühlung" S1 H1:2:3:4 T45                                  ; set fan 7 name and value. Thermostatic control is turned on
      M563 P0 D0 H1 F0:2:3                                                       ; define tool 0
      G10 P0 X0 Y0 Z0                                                            ; set tool 0 axis offsets
      G10 P0 R0 S0                                                               ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 D1 H2 F0:2:3                                                       ; define tool 1
      G10 P1 X0 Y0 Z0                                                            ; set tool 1 axis offsets
      G10 P1 R0 S0                                                               ; set initial tool 1 active and standby temperatures to 0C
      M563 P2 D2 H3 F0:2:3                                                       ; define tool 2
      G10 P2 X0 Y0 Z0                                                            ; set tool 2 axis offsets
      G10 P2 R0 S0                                                               ; set initial tool 2 active and standby temperatures to 0C
      M563 P3 D3 H4 F0:2:3                                                       ; define tool 3
      G10 P3 X0 Y0 Z0                                                            ; set tool 3 axis offsets
      G10 P3 R0 S0                                                               ; set initial tool 3 active and standby temperatures to 0C
      ; Custom settings
      M593 F50					                                               ; cancel ringing at 50Hz (https://forum.e3d-online.com/threads/accelerometer-and-resonance-measurements-of-the-motion-system.3445/)
      M376 H15					                                               ; bed compensation taper
      ;tool offsets
      G10 P0 X19.8 Y58 Z-3.275		                                           ; T0 Hemera 0.5mm Nozzle
      G10 P1 X18.8 Y58 Z-3.1				                                       ; T1 Hemera 0.4mm Nozzle
      G10 P2 X-9 Y39 Z-3.44				                                       ; T2 E3D V6 Bondtech 0.4mm Nozzle
      G10 P3 X-9 Y39 Z-5.39				                                       ; T3 Prometheus Bondtech 0.4mm Nozzle
      ; Deselect tools
      T-1
      ; Pressure Advance
      M572 D0 S0.05 					                                           ; pressure advance T0
      M572 D1 S0.05 					                                           ; pressure advance T1
      M572 D2 S0.2 					                                           ; pressure advance T2
      M572 D3 S0.2 					                                           ; pressure advance T3
      ; Heater model parameters
      M307 H0 B0 R0.162 C1661.3 D30.91 S1.00 V24.0
      M307 H1 B0 R2.147 C289.1:220.0 D5.22 S1.00 V23.7
      M307 H2 B0 R2.322 C197.6:173.7 D5.69 S1.00 V23.6
      M307 H3 R1.607 C273.7:225.8 D6.01 S1.00 V23.9
      M307 H4 R2.114 C239.508:194.630 D7.77 S1.00 V23.9 B0 I0
      M575 P1 S1 B57600                                                          ; enable support for PanelDue
      M501        ; load saved parameters from non-volatile memory
      M911 S20 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"                         ; set voltage thresholds and actions to run on power loss
      here is my bed.g:
      ; Bed Mesh Leveling
      G28 Z
      G1 S2 Z3 F500		; lift Z 3mm
      ;G31 P{sensors.probes[0].value[0] + 15}							;for analog reading of precision Piezo
      G29
      ;disable mesh leveling, needs to be enabled at the start of your print and disabled again when finished.
      G29 S2
      ; Park the head
      G1 X-20 Y0 F50000
      here is my homeall:
      ; homeall.g
      ; called to home all axes
      M98 Phomec.g			; Home C (ToolHead)
      M98 Phomey.g			; Home Y
      M98 Phomex.g			; Home X
      M98 Phomez.g			; Home Z
      G1 X-20 Y-0 Z5 F15000		; Park
      here is my homec:
      ; homec.g
      ; called to home the C axis (coupler)
      ;crashc
      G92 C260
      M913 C50			; C MOTOR TO 40% CURRENT
      G1 C-260 F2400  ; drive the C-axis to the stop
      M913 C100			; C MOTOR TO 100% CURRENT
      G1 C1 F50000
      G92 C0
      ;Open Coupler
      M98 P/macros/Coupler - Unlock
      here is my homex:
      ; homex.g
      ; called to home the x axis
      G91 			; use relative positioning
      G1 H2 X0.5 Y-0.5 F10000		; energise to avaoid false triggers during sensorless homing
      M400 			; make sure everything has stopped before we make changes
      G4 P100			; wait 100ms
      M913 X30 Y30 		; drop motor currents to 50%
      M915 H200 X Y S2 R0 F0 	; set X and Y to sensitivity 3, do nothing when stall, unfiltered
      G1 H2 Z3 F5000		; lift Z 3mm
      G1 H1 X-400 F3000 	; move left 400mm, stopping at the endstop
      G1 H1 X2 F2000 		; move away from end
      G1 H2 Z-3 F1200		; lower Z
      G90 			; back to absolute positioning
      M400 			; make sure everything has stopped before we reset the motor currents
      M913 X100 Y100 		; motor currents back to 100%
      here is my homey:
      ; homey.g
      ; called to home the Y axis
      M913 X30 Y30 		; drop motor currents to 20%
      G1 H1 Y-400 F3000 	; move to the front 400mm, stopping at the endstop
      G1 H1 Y2 F2000 		; move away from end
      here is my homez:
      ; homez.g
      ; called to home the Z axis
      T-1       ;just in case there is a tool coupled, go try to drop it at the dock
      M98 P/macros/Coupler - Unlock	;Open Coupler
      G91 				; Relative mode
      G1 H2 Z5 F5000			; Lower the bed
      G1 X150 Y150 F50000		; Position the endstop above the bed centre
      G91 				; Relative mode
      G4 P1000				; wait 500msec
      ;G30                     ; Probe the bed at the current XY position.
                              ; When the probe is triggered, set the Z coordinate
      						; to the probe trigger height.
      G1 Z-300 H1 F500		; Move Z down until the switch triggers (first pass)
      G4 P100				; wait 100msec
      G1 Z5 F2400			; Lift Z
      G4 P1000				; wait 100msec
      ;G31 P{sensors.probes[0].value[0] + 50}
      G1 Z-300 H1 F500		; Move Z down until the switch triggers (second pass)
      G1 Z5 F5000			; Drop the Bed
      G90				; Back to absolute positioning
      and here is for example my tool0 pre, post and free:
      ; tfree0.g
      ; called when tool 0 is freed
      ;Drop the bed
      G91
      G1 Z4 F1000
      G90
      ;mesh levelling off
      G29 S2
      ;Purge nozzle
      ;M98 Ppurge_r.g
      ;Move In
      G53 G1 X320.9 Y280 F50000
      G53 G1 Y307 F50000
      G53 G1 Y332.5 F5000
      ;Open Coupler
      ;fan off
      M106 P2 S0
      ;Move Out
      G53 G1 Y280 F50000
      ; tpost0.g
      ; called after tool 0 has been selected
      ;heatup
      M116 P0
      ;prime nozzle
      ;M98 Pprime_r.g
      ;mesh levelling on
      G29 S1
      ;PCF fan on
      M106 P2 R2
      ; tpre0.g
      ; called before tool 0 is selected
      ;Unlock Coupler
      ;Move to location
      G1 X320.5 Y280 F50000
      ;Move in
      G1 Y307 F50000
      ;Collect
      G1 Y332.5 F2500
      ;Close Coupler
      M98 P/macros/Coupler - Lock
      ;WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING!
      ;if you are using non-standard length hotends ensure the bed is lowered enough BEFORE undocking the tool!
      G91
      G1 Z10 F1000
      G90
      ;Move Out
      G1 Y280 F4000
      and last but not least here is my Highmap
      RepRapFirmware height map file v2, min error -6.153, max error -5.886, mean -6.000, deviation 0.056
      axis0,axis1,min0,max0,min1,max1,radius,spacing0,spacing1,num0,num1
      X,Y,5.00,295.00,5.00,295.00,-1.00,40.00,40.00,8,8
       -5.919, -5.969, -5.986, -5.986, -5.994, -6.052, -6.036, -5.969
       -5.911, -5.952, -5.961, -5.969, -5.986, -6.028, -6.028, -5.961
       -5.886, -5.952, -5.969, -5.977, -6.003, -6.028, -6.036, -5.961
       -5.894, -5.952, -5.969, -5.986, -5.986, -6.052, -6.036, -5.969
       -5.903, -5.961, -5.969, -5.961, -5.994, -6.028, -6.052, -5.977
       -5.903, -5.961, -5.969, -5.977, -5.994, -6.061, -6.077, -6.011
       -5.944, -6.003, -6.028, -6.011, -6.036, -6.094, -6.111, -6.036
       -6.003, -6.044, -6.069, -6.036, -6.077, -6.119, -6.153, -6.102
      My Question is, what did i do wrong here?
      My printer is a self build toolchanger. Has 4 tools and a build volume of 300mm³.
      Thx for the help.
      • jens55undefined
        jens55
        Looks like maybe you didn't set your z zero before you started the bed mapping routine ?
        This is just a quick guess without going through all your config files though.
          Your homez uses the z endstop to homez. The z min height is -6mm. There's your 6mm offset.
          You should use the probe to home z with a G30 before doing the mesh with G29 so that it has an accurate Z0 position that matches the probe offset.
          S1lencerundefined 1 Reply Last reply Reply Quote 0
          • S1lencerundefined
            S1lencer @Phaedrux
            @phaedrux said in Strange highmap problem:
            Thx fo the info will try that and report the results but it sounds plausible ;).
            Edit: Some 30min later, the Problem is solved, thank you very much.
