HELP! Duet 2 WiFi Configuration and DWC Upload???
Duet Web Control
13.3k
    You've got the board connected via usb to the PC, right?
    The USB cable must carry data, not just power.
    When you plug it in, does the board light up the 5v LED?
    Does windows detect a device has been connected?
    Try different cables/usb ports
    undefined 1 Reply Last reply 9 Jun 2021, 22:46 Reply Quote 0
      PCNoobNeedsMajorHelp @Phaedrux
      @phaedrux
      OK, I got it working and this was the output
        Ok, so SD card and wifi appear to be working, at least at that moment.
        But still no DWC?
        What is in the /www/ folder on the SD card?
        Is the config.g file still in the /sys/ folder?
        undefined 1 Reply Last reply 9 Jun 2021, 23:15 Reply Quote 0
          @phaedrux
          Just out of curiosity I tried out a few IP Addresses, and somehow the IP was changed. I don't know how, but its working under a different IP now. But it is working.
          yeah config.g and www are both on the card
            Well if the IP address is DHCP from the router there is a chance it could change occasionally. The best thing to do would be to set up a IP reservation in the router config so that it doesn't change.
            undefined 1 Reply Last reply 9 Jun 2021, 23:17 Reply Quote 0
              @phaedrux
              How do I do that?
                That will depend entirely on your router.
                undefined 2 Replies Last reply 9 Jun 2021, 23:27 Reply Quote 0
                  @phaedrux
                  ok I'll look into it
                    @phaedrux
                    Thanks
                      If you can find a manual it would probably be found under "DHCP reservation".
                        @phaedrux
                        So I'm testing some new filaments, and on the technical data sheet it says for the print bed to be at 140°c. I'm almost positive mine maxes out at 110, which means i need to upgrade. Do you have any suggestions.
                        I was thinking these (one generic, one brand)
                        https://www.amazon.com/gp/product/B07GJGCBNP/ref=ox_sc_act_title_1?smid=AJUKUXZVPYM6H&psc=1
                        https://keenovo.store/products/keenovo-silicone-heater-235mm-x-235mm-for-ender-3-3d-printer-build-plate-heatbed-heating-upgrade
                        What's your take on it?
                        Thanks,
                        -Carson
                          Keenovo has a good reputation and I wouldn't bother with anything else.
                          There are lots of places to be cheap, but power supplies and heaters aren't one of them.
                          undefined 1 Reply Last reply 29 Dec 2022, 22:03 Reply Quote 0
                            @Phaedrux
                            (I decided to reply to this thread so you'd remember me)
                            Hey...It's been a while. After a very busy year I'm finally ready to install my Keenovo Heated bed upgrade. I think I got the wrong heated bed though. I have a 24v 350w Keenovo, and I have a 24v 350w power supply as well as an SSR. I was reading up on the stock heated bed for the Ender 5 and it's a 24v 350w bed as well (facepalm). I'm realizing now that I should have gotten a 110v 500w heated pad for higher temperatures for my bed plate where I would be pulling power from the Mains on my PSU rather than the 24 volts it supplies to the rest of the Duet. Am I correct in my thinking?
                            Thanks in advance for any guidance
                            undefined 1 Reply Last reply 29 Dec 2022, 22:08 Reply Quote 0
                              droftarts administrators @PCNoobNeedsMajorHelp
                              @PCNoobNeedsMajorHelp Please start a new thread for a new subject; this thread is already 200 posts long! You can always reference this original thread from the new one.
                              undefined 1 Reply Last reply 29 Dec 2022, 22:09 Reply Quote 0
                                PCNoobNeedsMajorHelp @droftarts
                                @droftarts
                                Do you want me to post another one for this question or just for next time?
                                undefined 1 Reply Last reply 29 Dec 2022, 22:11 Reply Quote 0
                                  @PCNoobNeedsMajorHelp Make a new thread for this question. Make the title specific for greater visibility and more useful responses.
