    Script to control Wemos from gcode using DSF
    DSF Development
    718
      T3P3Tony administrators @oozeBot
      @oozeBot I forked this from the previous SBC topic as it stands alone as something useful.
      • PCRundefined
        PCR
        Would add that you need execonmcode installed!
        • CrazyCreatorundefined
          CrazyCreator @oozeBot
          Hello @oozebot
          I think I understand what your script is doing, but unfortunately I have absolutely no idea what I have to change to make it work with my Shelly.
          In my theory, I just want to call a web address. I don't actually need the different parameters.
          It should just be turned off stupidly.
          I think only the web call (http://192.168.1.47/relay/0?turn=off) would have to be stored in the wemo.sh.
          Unfortunately, I don't know whether I need the curl, content-type, charset etc either. i have no idea about these things
          http://www.crazycreatorcube.com
            CrazyCreator
            anybody can help me with a hint
            oozeBotundefined 1 Reply Last reply Reply Quote 0
            • oozeBotundefined
              oozeBot @CrazyCreator
              @CrazyCreator - this is untested, but all you need is something like the following. Google curl for more info.
              #!/bin/sh
              curl -s 'http://192.168.1.47/relay/0?turn=off' > /dev/null
              CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
                @oozebot
                Well that sounds understandable even to me. ๐Ÿ˜‰
                But I still ask one more question:
                Where do you create the scripts folder where your wemo.sh is then located?
                  CrazyCreator @CrazyCreator
                  @oozeBot Can you give me a little tip where I should create the folder and then wemo.sh must go?
                  • oozeBotundefined
                    @crazycreator the script can go most anywhere in the file system. If you look close at the service script I provided above, youโ€™ll see we use a folder named โ€œscriptsโ€ off the root.
                    CrazyCreatorundefined 2 Replies Last reply Reply Quote 1
                      @oozebot
                      Many thanks for the answer .. now I can try ๐Ÿ™‚
                        @oozebot
                        I could kiss you right now ๐Ÿ˜‰
                        It works absolutely perfectly.
                        I now have a real physical switch on the printer to turn it on and off and can still switch it off automatically at the end of a print ๐Ÿ™‚ Love it
