    What is the best way to destroy the Duet2 motor driver?
    Using Duet Controllers
    8
    25
    1.6k
    • kotuoundefined
      kotuo @Phaedrux
      @phaedrux Thank you for your reply.
      I am getting the following error statement for all motors when I do a home-all.
      Warning: Motor phase A may be disconnected as reported by driver 2.
      Warning: Motor phase B may be disconnected as reported by driver 2.
      The extruder drivers (E0, E1) have not been checked.
      Results of M122 investigation
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
      Board ID: 0JD0M-9X6JA-JUNSN-6JKDJ-3S86N-TTRRU
      Used output buffers: 3 of 24 (11 max)
      Static ram: 23460
      Dynamic ram: 73360 of which 24 recycled
      Never used RAM 15236, free system stack 191 words
      Tasks: NETWORK(ready,173) HEAT(blocked,308) MAIN(running,467) IDLE(ready,20)
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:00:30 ago, cause: software
      Last software reset at 2021-06-12 12:40, reason: User, GCodes spinning, available RAM 15200, slot 1
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU temperature: min 35.4, current 36.1, max 36.5
      Supply voltage: min 23.8, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, SG min/max not available
      Driver 1: position 0, standstill, SG min/max not available
      Driver 2: position 0, standstill, SG min/max not available
      Driver 3: position 0, standstill, SG min/max not available
      Driver 4: position 0, standstill, SG min/max not available
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2021-06-12 12:40:32
      Cache data hit count 35451813
      Slowest loop: 4.01ms; fastest: 0.21ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 0.6ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 15.60ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      WiFi firmware version 1.25
      WiFi MAC address 3c:61:05:d2:7a:4f
      WiFi Vcc 3.39, reset reason Power up
      WiFi flash size 4194304, free heap 24600
      WiFi IP address 192.168.1.101
      WiFi signal strength -41dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      My config.g
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Jun 12 2021 11:49:21 GMT+0900 (日本標準時)
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"*****"                                ; set printer name
      M551 P"kotuo"                                  ; set password
      M552 S1                                        ; enable network
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S0                                     ; disable FTP
      M586 P2 S0                                     ; disable Telnet
      M569 P0 S1                                     ; physical drive 0 goes forwards
      M569 P1 S0                                     ; physical drive 1 goes backwards
      M569 P2 S0                                     ; physical drive 2 goes backwards
      M569 P3 S1                                     ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                               ; set drive mapping
      M350 X32 Y32 Z32 I0                            ; configure microstepping without interpolation
      M350 E16 I1                                    ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z8000.00 E369.00           ; set steps per mm
      M566 X600.00 Y600.00 Z60.00 E300.00            ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z300.00 E6000.00        ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E500.00           ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                   ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        ; Set idle timeout
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X300 Y300 Z300 S0                         ; set axis maxima
      M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
      M574 Y2 S1 P"ystop"                            ; configure active-high endstop for high end on Y via pin ystop
      M574 Z1 S1 P"zstop"                            ; configure active-high endstop for low end on Z via pin zstop
      M558 P0 H5 F120 T6000                          ; disable Z probe but set dive height, probe speed and travel speed
      M557 X10:220 Y10:220 S20                       ; define mesh grid
      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S260                                   ; set temperature limit for heater 1 to 260C
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0.8 H-1                               ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
      M563 P0 S"PLA" D0 H1 F0                        ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      M575 P1 S1 B57600                              ; enable support for PanelDue
      M501                                           ; load saved parameters from non-volatile memory
      T0                                             ; select first tool
      I have not set up any macros, so
      When I run M98P "config.g", I get an error.
      M98P "config.g"
      Warning: Macro file  "config.g" not found
      Maximum voltage of the motor
      Nidec [KV4239/KF4242] is not listed in the current datasheet, so I guessed from the latest version of the model number: 2A.
      C17HD2020, no datasheet found, probably: 2A
      dc42undefined BoAundefined Phaedruxundefined 3 Replies Last reply Reply Quote 0
        dc42 administrators @kotuo
        @kotuo please measure the resistance of each motor phase, also measure the length of the motors. From those figures we can estimate the motor characteristics by comparing them with other similar motors.
        Is this ab existing 3D printer than you have upgraded to Duet? If not, where did the motors come from?
        Are you using 12V or 24V power?
        kotuoundefined 1 Reply Last reply Reply Quote 0
        • kotuoundefined
          kotuo @dc42
          @dc42 Thank you for your reply.
          The motor I'm using is an existing motor.
          The power supply is 24v.
          Nidec : KV4239 A,0.64Ω B,0.64 Ω
          C17HD02 A, 0.63Ω B,0.63 Ω
          Nidec: KF4242 A,11.6Ω B,11.6Ω
            @kotuo thanks. What is the length of those motors, not counting the shaft?
            The Nidec KF4242 motor has a high per-phase resistance. It is either not suitable for use in a 3D printer, or it needs a low current. If connected to a Duet with the current set too high, the Duet might well give "phase may be disconnected" warnings for the driver it is connected to.
            • BoAundefined
              BoA @kotuo
              @kotuo I see disconnection reported only for driver 2 - which drives Z axis. Do You have jumpers on the second Z motor connector?
              • kotuoundefined
                kotuo @dc42
                Size of the motor
                KV4239
                Red line 42mm
                Blue line 42mm
                Green dot (length without shaft) 38mm
                C17
                Red line 42.4mm
                Blue line 42.4mm
                Green point (length excluding shaft) 39mm
                KF4242
                Red line 43mm
                Blue line 43mm
                Green line (length excluding shaft) 39mm
                • kotuoundefined
                  kotuo @BoA
                  @boa Thanks for your reply.
                  I have the jumper on the second Z-axis.
                    Phaedrux Moderator @kotuo
                    @kotuo said in What is the best way to destroy the Duet2 motor driver?:
                    M98P "config.g" Warning: Macro file "config.g" not found
                    You have the space in the wrong place, should be M98 P"config.g"
                    • kotuoundefined
                      kotuo @Phaedrux
                      @phaedrux Thank you very much.
                      It was a short sentence, so typing it by hand was a big mistake.
                      Here is the result
                      M98 P "config.g"
                      HTTP is enabled on port 80
                      FTP is disabled
                      TELNET is disabled
                      • Vetiundefined
                        Veti @kotuo
                        @kotuo
                        are you sure that red and green are one phase?
                        because normally red and blue are one phase
                        • kotuoundefined
                          kotuo @Veti
                          @veti Thank you for pointing this out.
                          I have no choice but to change the order of the cables because the cables I am using are twisted on the motor side and I do not have the terminals on the motor side.
                            Thanks, it's a 39mm Nema 17 motor then.
                            To get an idea of the characteristics, go to https://www.omc-stepperonline.com/nema-17-stepper-motor/. Set he unipolar/bipolar filter to Unipolar, the Body Length filter to a range that is close to the motor length e.g. 39 to 40mm, and set the Phase Resistance filter to a value that covers the 11.6 ohm resistance that you measured.
                            The closest one I found was this one https://www.omc-stepperonline.com/nema-17-stepper-motor/nema-17-bipolar-1-8deg-36ncm-51oz-in-0-85a-5-4v-42x42x39mm-4-wires. It has the same length but the phase resistance is 6.3 ohms.
                            To account for the different in phase resistance, we can assume that for the same motor size, inductance is proportional to phase resistance, rated current is inversely proportional to the square root of phase resistance, and phase voltage is proportional to the square root of phase resistance. This suggests the following approximate values for that motor:
                            Inductance 18.4mH
                            Phase voltage at rated current 7.3
                            Rated phase current 0.63A
                            EDIT: is that the Z motor? Is there just one Z motor, or are there two? If there are two, how have you connected them to the Duet?
                              There are at least two different phase pinouts used on stepper motors with 6-pin JST connectors. This means that if the cable was not supplied with the motor, the colours may well be wrong, as you have discovered.
                              • kotuoundefined
                                kotuo @dc42
                                I am using only one Z axis.
                                  @kotuo what motor current have you set for the Z axis in your M906 command in config.g? You will need to use 600mA or less with that motor. If you set a much higher current, then you can expect to see those "phase may be disconnected" warnings, because the drivers will be unable to provide the requested current to that high resistance motor.
                                  • kotuoundefined
                                    kotuo @dc42
                                    @dc42 Thank you for your reply!
                                    I will lower the motor current to 600 with RRF and upload the zip file to Duet.
