    Webcontrol and filament sensor
    Duet Web Control
    657
    • Deluxe 600undefined
      Deluxe 600
      Hi, I wanted to set up a filament sensor using a Prusa MINi fil sensor just because i had one.
      But when i tried to test it to see if the printer detects it, i noticed that the tab "machine properties" had vanished.Im using Webcontrol 3.2.0 and duet 2 ethernet FW 3.0 .
      The second thing is that i dont know how to set up the fil sensor properly
      Sensor is just an optical gate so i guess its like a regular switch. Its pluged into the E0 endstop and all i want is for it to pause the print when it detects a run out.
      Here is the config
      ;Filament Runout Sensor
      M950 J0 C"!^e0Stop" ; create switch pin
      M581 P0:1 T2 S1 R1 ; run trigger2.g to pause if filament has run out during SD card printing
      Thank you and have a great day.
        The machine properties tab has been moved to a plugin and I think will be included with the 3.3 release. Otherwise it can be found here: https://github.com/Duet3D/DSF-Plugins/tree/master/EndstopsMonitor
        In the meantime you can still check endstop status with M119.
        For a filament sensor you'd want to use M591 instead of M581.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing
        Deluxe 600undefined 1 Reply Last reply Reply Quote 0
          Deluxe 600 @Phaedrux
          @phaedrux Thank you for the reply.
          But so far i was unsucesful.
          I have tried to install the plugin but for some reason it does not want to work.
          I have exported the "Monitor Plugin" to the src/plugin folder and even modified "Index.js" as instructed, but it still doesnt show up in the "plugins" folder in webcontroll.
          Meanwhile i also tried to setup the fil sensor but that too didnt manage to get it working i will send the config file also if you could please take a look if i have it setup corectly.
          Thank you very much.
          M350 Z8 X16 Y16 I1 ; Configure microstepping with interpolation
          M350 E32 I0 ; Configure microstepping without interpolation
          M92 X50 Y50 Z400 E280 ; Set steps per mm
          M566 X480 Y480 Z2 E270 ; Set maximum instantaneous speed changes (mm/min)
          M203 X12000 Y12000 Z720 E7200 ; Set maximum speeds (mm/min)
          M201 X1000 Y1000 Z125 E5000 ; Set accelerations (mm/s^2)
          M906 X1500 Y1500 Z2000 E700 I1 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S5 ; Set idle timeout
          M208 X0 Y0 Z0 S0 ; Set axis minima
          M208 X545 Y545 Z700 S0 ; Set axis maxima
          M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
          M574 Y2 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
          ;M574 Z1 S2 ; configure Z-probe endstop for low end on Z
          M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
          M558 P9 C"^zprobe.in" A5 H4 F100 T6000 ; set Z probe type to bltouch and the dive height + speeds
          G31 X0 Y0 Z0.9 ; set Z probe trigger value, offset and trigger height
          M557 X0:500 Y40:500 S100:100 ; define mesh grid
          M950 J0 C"!e0stop" ; create switch pin
          M591 P2 C"e0stop" S1 D0 ; filament monitor connected to E0 endstop
          M143 H0 S100 ; set temperature limit for heater 0 to 100C
          M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
          M106 P1 S0.5 H1 T60 ; set fan 1 value. Thermostatic control is turned on
          M950 F2 C"fan2" Q500 ; create fan 2 (bed) on pin fan2 and set its frequency
          M106 P2 S1 H0 T50
          M563 P0 D0 H1 ; Define tool 0
          G10 P0 R20 S0 ; Set initial tool 0 active and standby temperatures to 0C
          ;LED control
          M950 P5 C"e1heat" ;set e1heat as a GPIO output pin
          M501
          M107
          Phaedruxundefined MintyTreborundefined 2 Replies Last reply Reply Quote 0
            Phaedrux Moderator @Deluxe 600
            @deluxe-600 said in Webcontrol and filament sensor:
            I don't think you need the M950 here and that may be your problem.
            Can you send M98 P"config.g" and see if it shows any syntax errors.
            • MintyTreborundefined
              MintyTrebor @Deluxe 600
              @deluxe-600 I maybe wrong, but I get the impression from your post that you did not compile the endstops plugin before you attempted to install it. Copying the files as you describe will not typically work. Unless you have a dev environment already setup / or are willing to set one up, then I think you have 2 options:
              1: Enable the object model browser built-in plugin and use it to check if the sensor is working as expected (you will have to refresh it each time you want to check status).
              2: Use BtnCmd to make your own endstops monitor in the browser.
              Option 1 would be the easiest as its already available with no additional work, and unless you want a permanent endstop monitor, it will probably work OK. You could also be cheeky and ask if anyone on the forum has a pre-compiled zip of the endstops monitor @Phaedrux linked to. Or just install the pre-compiled version I completely missed as @jay_s_uk says below. (even better!!)
              NodeDSF - Native Node-Red integration with Duet boards.
              BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
              ReleaseMgr - Duet update info inside DWC.
              Repo
              jay_s_ukundefined 1 Reply Last reply Reply Quote 2
                jay_s_uk @MintyTrebor
                There is a release available here https://github.com/Duet3D/DSF-Plugins/releases
                Phaedruxundefined Deluxe 600undefined 2 Replies Last reply Reply Quote 1
                  Phaedrux Moderator @jay_s_uk
                  @jay_s_uk Thanks. I should be using that link instead.
                  Deluxe 600undefined 2 Replies Last reply Reply Quote 0
                    @phaedrux And it works 🙂 . Thank you guys. Now only to solve the filament sensor, working on it right now. Im trying to use the sensor from Prusa MINI but it seems to need 5V power. So i conected the power pin one the sensor to the always on FAN that has 5V.
                      Deluxe 600 @jay_s_uk
                      @jay_s_uk It works! Thank you 🙂 . But the filament sensor doesnt show up, thats strange isnt it? I just have X,Y,Z endstops in the "ENDSTOPS" page
                        jay_s_uk @Deluxe 600
                        @deluxe-600 filament sensors are different to endstops and that's why they don't show up
                          @phaedrux Never mind i figured it out.
                          For anyone wondering the gcode that worked is M591 P1 C"e0stop" S1 D0
                          Thank you all for the help, you are the best 🙂
                            Sending M591 by itself will report info on the sensor.
