    Homing sensors not working correctly with RRF3.3.0 stable
    Beta Firmware
    2.1k
      jay_s_uk @Marco Bona
      @marco-bona add G4 S5 in your config.g before any reference to the expansion board is made (so before M569)
      Marco Bonaundefined 1 Reply Last reply Reply Quote 0
      • Marco Bonaundefined
        Marco Bona @jay_s_uk
        @jay_s_uk, with delay before M569 I do not get anything different, same problem
          Phaedrux Moderator @Marco Bona
          @marco-bona said in Homing sensors not working correctly with RRF3.3.0 stable:
          it goes in the opposite direction for 5mm and stops, instead it should move slowly until the limit switch is activated.
          G1 H1 U-150 F2000 ; move U until the endstop is triggered G4 P100 ; delay 0.1 sec G1 U5 F1000 ; move U back 5mm G1 H1 U-15 F500 ; move U slowly towards the switch until it triggers
          that makes it sound like the endstop is triggered when it is not. What is the status of the endstop in M119 both when the switch is depressed and not depressed?
            Marco Bona @Phaedrux
            @phaedrux, The states of limit switches are correct, strange thing is that code runs correctly up to G1 H1 U-15 F500, then continues with the code as if the limit switch is active. I have another limit switch on the expansion card that has same problem. On DWC initial screen, axis states are reset after performing the reset. This behavior only affects sensors on expansion board
              Just to verify, can you go back to the last 3.3 RC you tried to see if the behaviour is resolved?
                @phaedrux, I can try, but I need a procedure having SBC connected, otherwise it is enough to replace files in system folder? Until before update it worked fine
                  This tool may be the easiest way to switch back to a specific version.
                  https://github.com/DanalEstes/DuetVersions
                  DuetRegress.
                  Though it likely hasn't been tested with 3.3 etc as Danal is unfortunately no longer with us.
                  Marco Bonaundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                    @phaedrux, sorry but procedure is not very clear, I may have some commands to insert in the SBC otherwise I cannot give you feedback.
                      jay_s_uk @Phaedrux
                      @phaedrux it still works. I use it to generate the scripts used by the LPC/STM port
                        To install it, you run this on your Pi console
                        git clone https://github.com/DanalEstes/DuetVersions
                        Then follow these instructions to install a older version
                        https://github.com/DanalEstes/DuetVersions#run-duetregresssh
                        Ex: ./DuetRegress.sh 3.2.2
                          @phaedrux, i tried but i was unsuccessful. Yesterday I forgot to tell you that with the latest update I also reinstalled latest version of DuetPi but I don't think it is related to problem.
                          If I remember correctly I had a similar problem with RRF3.3 RC3 + 7, but then I had not deepened as stable version was released. With RRF3.3RC3 + 6 I'm sure everything was correct
                            Marco Bona
                            @dc42, @chrishamm , I try to raise this question to you since I have no longer received an answer.
                            I think it came from an update between version 3.3rc3 + 6 and 3.3rc3 + 7, if I remember correctly there has been an update on the expansions as well. The stable version has the same problem.
                              If you were unable to downgrade the SBC version, can you try setting up in standalone mode to see if it's a firmware issue or SBC issue?
                              https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Running_in_standalone_mode
                              Once in standalone issue it would also be much easier to change firmware versions by simply uploading the zip file of the firmware version you want.
                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
                                Marco Bona
                                @Phaedrux , @dc42, @chrishamm, I tried in standalone mode, I have the same problem I have with SBC starting from version 3.3RC3 + 7(https://www.dropbox.com/sh/xfsvscbaab0dtzl/AACCcSeiTNINZL-xbs6IhC4Ja?dl=0). Latest release where limit switches work correctly is 3.3 RC3 + 6, if I am not mistaken, afterwards an update was also made on the expansion boards. I cannot provide you with a report in standalone mode because I do not have possibility to connect a network cable to modem, but I am still available for further tests.
                                Thank you
                                  Marco Bona
                                  @Phaedrux ,I wanted to know if there was any update or some solution to fix the problem. I would like to inform you that heater set on the expansion board also has problems with this release.
                                  Furthermore, when starting a print, this error also appeared
                                  Error: Failed to get macro response within 3000ms from SBC (channel File)
                                  I am now working in SBC mode, can anyone give me an answer?
                                  Thank you
                                  Marco
                                    @marco-bona I have added this to my list to investigate.
                                    User3Dundefined 1 Reply Last reply Reply Quote 1
                                    • User3Dundefined
                                      User3D @dc42
                                      @dc42 I have faced a similar issue , when upgraded from 3.3beta Feb1 release to to RRF 3.3.0.
                                      Axes X-Y are connected on EXP1XDs and I have end-limits on both the low and high ends. After upgrade, Axes started hitting the end-limits on the other(high) ends . I suppose It is the same issue as of @marco-bona & due to incorrect homing, axes hit the endstops.
                                      NOTE: After downgrading to previous release i.e. (3.3beta Feb1) , problem is gone.
                                      Do you concur the issues are similar?
                                        Marco Bona
                                        @dc42 , Thanks.
                                        @User3D , yesterday I did some tests and it seems that adding a G4 between moves gets around the problem. I haven't tried to print but homing works. I enclose an example, let me know if you solve.
                                        G1 H1 U-150 F2000
                                        G4 P100
                                        G1 U5 F1000
                                        G4 P100
                                        G1 H1 U-15 F500
                                        G4 P100
                                        With M400 it doesn't work, if you still have problems increase the delay
                                        User3Dundefined dc42undefined 2 Replies Last reply Reply Quote 1
                                        • User3Dundefined
                                          User3D @Marco Bona
                                          @marco-bona Thanks! Did you try printing? If yes then can you confirm that its not step skipping and homing issue only?
                                            Marco Bona @User3D
                                            @user3d, hello, I tried to make some prints but I can not give you a certain answer because on expansion board I have 2 axes that I do not usevery often during printing. From what I see I don't think there are any problems but I'm not entirely sure
