    mesh bed compensation not compensating
    1.3k
    • Jaysonundefined
      Jayson
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Oct 29 2020 18:46:36 GMT-0600 (Central Standard Time)
      M550 P"Jayson" ; set printer name
      M669 K1 ; select CoreXY mode
      M551 P"13thpassword" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M569 P2 S0 ; physical drive 2 goes backwards
      M569 P4 S1 ; physical drive 4 goes forwards
      M569 P5 S1 ; physical drive 5 goes forwards
      M569 P6 S1 ; physical drive 6 goes forwards
      M584 X0 Y1 Z2 E3:4:5:6 ; set drive mapping
      M350 E16:16:16:16 I1 ; configure microstepping with interpolation
      M350 X16 Y16 Z16 I1
      M92 X80 Y80 Z900 E420.00:1888.21:420.00:420.00 ; set steps per mm
      M566 X500.00 Y500.00 Z3.00 E120.00:40.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X24000.00 Y24000.00 Z600.00 E1200.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z80.00 E250.00:250.00:250.00:250.00 ; set accelerations (mm/s^2)
      M906 X1500 Y1500 Z750 E800:800:800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S120 ; Set idle timeout
      M208 X-41.1 Y0 Z0 S1 ; set axis minima
      M208 X588 Y567 Z660 S0 ; set axis maxima
      M574 X1 S1 P"xstop" ; configure sensorless endstop for low end on X (changed to switch)
      M574 Y2 S1 p"ystop" ; configure sensorless endstop for high end on Y (changed to switch)
      ;M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
      M558 P8 C"^zprobe.in" H4 F900 T24000 ; set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
      M557 X5:495 Y5:495 S54.4 ; define mesh grid
      M376 H10
      M308 S7 P"duex.e4temp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin duex.e4temp
      M950 H6 C"duex.fan4" T7 ; create chamber heater output on duex.fan4 and map it to sensor 0
      M307 H6 B1 S1.00 D60 ; enable bang-bang mode for the chamber heater and set PWM limit
      M141 H6 ; map chamber to heater 6
      M143 H6 S150 ; set temperature limit for heater 6 to 150C
      M308 S0 P"bedtemp" Y"thermistor" T108500 B4092 A"Bedmat" ; configure sensor 0 as thermistor on pin bedtemp
      M308 S6 P"duex.e5temp" Y"thermistor" T100000 B4725 C7.06e-8 A"Bedplate"
      M950 H0 C"e0heat" T6 ; create bed heater output on e0heat and map it to sensor 6
      M143 H0 S135 ; set temperature limit for heater 0 to 135C
      M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
      M950 H1 C"bedheat" T1 ; create nozzle heater output on bedheat and map it to sensor 1
      M308 S2 P"spi.cs2" Y"rtd-max31865" ; configure sensor 2 as thermocouple via CS pin spi.cs2
      M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
      M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M308 S3 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 3 as thermistor on pin e0temp
      M950 H3 C"duex.e2heat" T3 ; create nozzle heater output on duex.e2heat and map it to sensor 3
      M307 H3 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M308 S4 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 4 as thermistor on pin e1temp
      M950 H4 C"duex.e3heat" T4 ; create nozzle heater output on duex.e3heat and map it to sensor 4
      M307 H4 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M143 H2 S400 ; set max heater temp heater 2
      M308 S5 P"duex.e6temp" Y"thermistor" T10200 A"WATER TEMP" ;water temp sensor
      M106 P0 S0 H-1 L1.0 ; set fan 0 value. Thermostatic control is turned off
      M106 P1 S1 H0:2:6 L1.0 T45 ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan2" T5 Q500 ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H5 L1.0 T30 ; set fan 2 value. Thermostatic control is turned on
      M950 F3 C"duex.fan1" Q500 ; create fan 3 on pin duex.fan3 and set its frequency
      M106 P3 S1 H7 L1.0 T30 ; set fan 2 value. Thermostatic control is turned on
      M563 P0 S"Super volcano" D0 H1 F0 ; define tool 0
      M563 P1 S"V6" D1 H2 F0 ; define tool 1
      G10 P1 X0 Y-60 Z-11.05 ; set tool 1 axis offsets
      M563 P2 S"Cyclops" D2 H3 F0 ; define tool 2
      G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
      G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
      M143 H0 P1 T0 A2 S130 C0 ; Regulate (A2) bed heater (H0) to have pad sensor (T0) below 130°C. Use Heater monitor 1 for it
      M911 S22 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      M501 ; USE CONFIG OVERRIDE VALUES
      ; PS_ON relay triggers
      M570 H0 P60 T10 S0 ; Allow a heat bed anomaly to persist for 10 seconds (P10)
      ; on the before raising a heater fault. Allow a 10C
      ; deviation from set point (T10) After 0 minutes of heater
      ; fault cancel the build (S0).
      M570 H1 P20 T10 S0 ; Allow a hot end anomaly to persist for 10 seconds (P10)
      ; 10C deviation from set point (T10) After 0
      ; minute of heater fault cancel the build (S0).
      M80 ;power on relay
      ;tool change servo
      M950 S0 C"duex.pwm5" Q50
      M572 D1 S0.01
      • Jaysonundefined
        Jayson
        here is a sample of my start gcode
        ;Generated with Cura_SteamEngine 4.8.0
        T1
        M190 S70
        M104 S240
        M109 S240
        M82 ;absolute extrusion mode
        G28 ;Home
        G29 S0 ; mesh bed compinsation
        G1 Z15.0 F6000 ;Move the platform down 15mm
        ;Prime the extruder
        G92 E0
        G1 F200 E3
        G92 E0
        M141 S0
        M83 ;relative extrusion mode
        G1 F1500 E-0.5
        ;LAYER_COUNT:89
        ;LAYER:-7
        M107
        G0 F18000 X69.373 Y337.319 Z0.36
        ;TYPE:SUPPORT-INTERFACE
        G1 F1500 E0.5
        G3 X98.183 Y344.153 I6.806 J35.452 E5.47936 F675
        • fcwiltundefined
          fcwilt @Jayson
          @jayson
          Post your homing files, please.
          You can use the </> tag to create a scrollable section of code right in your post - like this
          this is line 1
          this is line 2
          this is line 3
          Jaysonundefined 1 Reply Last reply Reply Quote 0
          • Jaysonundefined
            Jayson @fcwilt
            @fcwilt look at that. I learnt something new today
            ; homeall.g
            ; called to home all axes
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Oct 29 2020 12:06:14 GMT-0600 (Central Standard Time)
            G91                    ; relative positioning
            G1 H2 Z5 F6000         ; lift Z relative to current position
            G1 H1 X-593 Y616 F10000 ; move quickly to X or Y endstop and stop there (first pass)
            G1 H1 X-593            ; home X axis
            G1 H1 Y616             ; home Y axis
            G1 X5 Y-5 F10000        ; go back a few mm
            G1 H1 X-593 F1000      ; move slowly to X axis endstop once more (second pass)
            G1 H1 Y616             ; then move slowly to Y axis endstop
            G90                    ; absolute positioning
            G1 X5 Y5 F12000       ; go to first bed probe point and home Z
            G30                    ; home Z by probing the bed
            ; homex.g
            ; called to home the X axis
            G1 H1 X-593 F10000 ; move quickly to X axis endstop and stop there (first pass)
            G1 X5 F10000       ; go back a few mm
            G1 H2 Z-5 F6000   ; lower Z again
            ; homey.g
            ; called to home the Y axis
            G1 H1 Y616 F10000 ; move quickly to Y axis endstop and stop there (first pass)
            G1 Y-5 F10000      ; go back a few mm
            G1 H1 Y616 F1000  ; move slowly to Y axis endstop once more (second pass)
            ; homez.g
            ; called to home the Z axis
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Oct 28 2020 15:43:06 GMT-0600 (Central Standard Time)
            G1 X5 Y5 F12000 ; go to first probe point
            • fcwiltundefined
              fcwilt @Jayson
              @jayson
              In your config.g file you have this:
              G31 P500 X0 Y0 Z0 ;
              What sort of probe do you have? The X, Y and Z values are rather unusual.
              Jaysonundefined 2 Replies Last reply Reply Quote 0
              • Jaysonundefined
                Jayson @fcwilt
                @fcwilt
                It's just a little micro switch.
                This is a tool changing machine so I gave the probe 0 offset and apply an individual offset to each tool.
                It's not all configured yet. I just have one nozzle printing now.
                • Jaysonundefined
                  Jayson @fcwilt
                  @fcwilt
                  And I should be the one thanking you.
                  I'm at a loss with this machine. Hopefully someone here can figure out how to make it dance for me
                  • fcwiltundefined
                    fcwilt @Jayson
                    @jayson said in mesh bed compensation not compensating:
                    @fcwilt
                    So the probe actually triggers at exactly Z=0?
                    • Jaysonundefined
                      Jayson @fcwilt
                      @fcwilt
                      The machine homes and probes without a hot end attached then when it starts printing it picks up a tool from the rack and uses that tools offsets.
                      The nozzle I currently have configured hangs about 11mm below the switch when mounted. So T1 has a -11 mm z offset.
                      I believe that the e3d tool changer uses a similar method
                        Phaedrux Moderator @Jayson
                        about 11mm
                        This is going to need to be quite exact otherwise the nozzle will never touch the bed where you expect. Same goes for the XY offset.
                        Can you post a photo of your heightmap image?
                        M376 H10
                        You might need to eliminate that for now until you get things working and know how quickly you can actually taper off the compensation.
                        Jaysonundefined 2 Replies Last reply Reply Quote 1
                        • Jaysonundefined
                          Jayson @Phaedrux
                          @phaedrux said in mesh bed compensation not compensating:
                          M376 H10
                          It set at 11.2 mm to make a good section of my bed useable.
                          I will take out that M376 and see if that helps.
                          thank you
                          • Jaysonundefined
                            Jayson @Phaedrux
                            @phaedrux
                            my bed is a little warped, needs some work but nothing bed compensation should handle it for now.
                            Number of points: 100
                            Probe area: 2397.1 cm²
                            Maximum deviations: -0.270 / 0.581 mm
                            Mean error: 0.252 mm
                            RMS error: 0.184 mm
                              For such a large bed you may need to increase the point density. 441 is the max number of points and you're only using 100. That can mean a large distance between points where interpolation has to guess what the bed height actually is. Combine that with XYZ offsets that aren't quite accurate and it's going to have a very hard time keeping the nozzle where it's supposed to be.
                              Jaysonundefined 1 Reply Last reply Reply Quote 1
                              • Jaysonundefined
                                Jayson @Phaedrux
                                @phaedrux I took out that m376 and now it's working 🎉 thank you so much!
                                Its not great but it is actually usable over my whole bed now.
                                Things are a bit temporary right now as I plan on changing most of this printer. as soon as it can print its own replacement parts I will rebuild it and maybe double my probing points.
                                I just don't want to wait that long for it to probe....
                                  Well if the bed is stable and things don't shift around too much you can save a detailed heightmap and load it instead of probing before each print.
                                  G29 S1 to load saved map.
                                  • Jaysonundefined
                                    Jayson @Phaedrux
                                    @phaedrux I might try G29 S1 but I have a removable magnetic bed. so if I have to take it off I will probably need to re-probe.
                                    Phaedruxundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                      Maybe, maybe not. If it registers pretty much the same each time it should be ok. Only one way to find out for sure.
                                      • fcwiltundefined
                                        fcwilt @Jayson
                                        I have the BuildTak system and I use the same height map.
                                        I do re-create it from time to time.
                                        • Jaysonundefined
                                          Jayson @fcwilt
                                          @fcwilt I have the buildtak system. Just have to try it
