    mesh bed compensation not compensating
    1.3k
    • fcwiltundefined
      fcwilt @Jayson
      @jayson
      Post your homing files, please.
      You can use the </> tag to create a scrollable section of code right in your post - like this
      this is line 1
      this is line 2
      this is line 3
      Jaysonundefined 1 Reply Last reply Reply Quote 0
      • Jaysonundefined
        Jayson @fcwilt
        @fcwilt look at that. I learnt something new today
        ; homeall.g
        ; called to home all axes
        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Oct 29 2020 12:06:14 GMT-0600 (Central Standard Time)
        G91                    ; relative positioning
        G1 H2 Z5 F6000         ; lift Z relative to current position
        G1 H1 X-593 Y616 F10000 ; move quickly to X or Y endstop and stop there (first pass)
        G1 H1 X-593            ; home X axis
        G1 H1 Y616             ; home Y axis
        G1 X5 Y-5 F10000        ; go back a few mm
        G1 H1 X-593 F1000      ; move slowly to X axis endstop once more (second pass)
        G1 H1 Y616             ; then move slowly to Y axis endstop
        G90                    ; absolute positioning
        G1 X5 Y5 F12000       ; go to first bed probe point and home Z
        G30                    ; home Z by probing the bed
        ; homex.g
        ; called to home the X axis
        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Oct 29 2020 18:46:36 GMT-0600 (Central Standard Time)
        G1 H1 X-593 F10000 ; move quickly to X axis endstop and stop there (first pass)
        G1 X5 F10000       ; go back a few mm
        G1 H2 Z-5 F6000   ; lower Z again
        ; homey.g
        ; called to home the Y axis
        G1 H1 Y616 F10000 ; move quickly to Y axis endstop and stop there (first pass)
        G1 Y-5 F10000      ; go back a few mm
        G1 H1 Y616 F1000  ; move slowly to Y axis endstop once more (second pass)
        ; homez.g
        ; called to home the Z axis
        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Oct 28 2020 15:43:06 GMT-0600 (Central Standard Time)
        G1 X5 Y5 F12000 ; go to first probe point
        • fcwiltundefined
          fcwilt @Jayson
          @jayson
          In your config.g file you have this:
          G31 P500 X0 Y0 Z0 ;
          What sort of probe do you have? The X, Y and Z values are rather unusual.
          Jaysonundefined 2 Replies Last reply Reply Quote 0
          • Jaysonundefined
            Jayson @fcwilt
            @fcwilt
            It's just a little micro switch.
            This is a tool changing machine so I gave the probe 0 offset and apply an individual offset to each tool.
            It's not all configured yet. I just have one nozzle printing now.
            • Jaysonundefined
              Jayson @fcwilt
              @fcwilt
              And I should be the one thanking you.
              I'm at a loss with this machine. Hopefully someone here can figure out how to make it dance for me
              • fcwiltundefined
                fcwilt @Jayson
                @jayson said in mesh bed compensation not compensating:
                @fcwilt
                So the probe actually triggers at exactly Z=0?
                • Jaysonundefined
                  Jayson @fcwilt
                  @fcwilt
                  The machine homes and probes without a hot end attached then when it starts printing it picks up a tool from the rack and uses that tools offsets.
                  The nozzle I currently have configured hangs about 11mm below the switch when mounted. So T1 has a -11 mm z offset.
                  I believe that the e3d tool changer uses a similar method
                    Phaedrux Moderator @Jayson
                    about 11mm
                    This is going to need to be quite exact otherwise the nozzle will never touch the bed where you expect. Same goes for the XY offset.
                    Can you post a photo of your heightmap image?
                    M376 H10
                    You might need to eliminate that for now until you get things working and know how quickly you can actually taper off the compensation.
                    Jaysonundefined 2 Replies Last reply Reply Quote 1
                    • Jaysonundefined
                      Jayson @Phaedrux
                      @phaedrux said in mesh bed compensation not compensating:
                      M376 H10
                      It set at 11.2 mm to make a good section of my bed useable.
                      I will take out that M376 and see if that helps.
                      thank you
                      • Jaysonundefined
                        Jayson @Phaedrux
                        @phaedrux
                        my bed is a little warped, needs some work but nothing bed compensation should handle it for now.
                        Number of points: 100
                        Probe area: 2397.1 cm²
                        Maximum deviations: -0.270 / 0.581 mm
                        Mean error: 0.252 mm
                        RMS error: 0.184 mm
                          For such a large bed you may need to increase the point density. 441 is the max number of points and you're only using 100. That can mean a large distance between points where interpolation has to guess what the bed height actually is. Combine that with XYZ offsets that aren't quite accurate and it's going to have a very hard time keeping the nozzle where it's supposed to be.
                          Jaysonundefined 1 Reply Last reply Reply Quote 1
                          • Jaysonundefined
                            Jayson @Phaedrux
                            @phaedrux I took out that m376 and now it's working 🎉 thank you so much!
                            Its not great but it is actually usable over my whole bed now.
                            Things are a bit temporary right now as I plan on changing most of this printer. as soon as it can print its own replacement parts I will rebuild it and maybe double my probing points.
                            I just don't want to wait that long for it to probe....
                              Well if the bed is stable and things don't shift around too much you can save a detailed heightmap and load it instead of probing before each print.
                              G29 S1 to load saved map.
                              • Jaysonundefined
                                Jayson @Phaedrux
                                @phaedrux I might try G29 S1 but I have a removable magnetic bed. so if I have to take it off I will probably need to re-probe.
                                Phaedruxundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                  Maybe, maybe not. If it registers pretty much the same each time it should be ok. Only one way to find out for sure.
                                  • fcwiltundefined
                                    fcwilt @Jayson
                                    I have the BuildTak system and I use the same height map.
                                    I do re-create it from time to time.
                                    • Jaysonundefined
                                      Jayson @fcwilt
                                      @fcwilt I have the buildtak system. Just have to try it
