    Extruder motor doesn't move
    2.1k
      Yes that is movement in millimeters.
        Add this
        T0
        M302 P1 ; Allow cold extrusion
        to the end of your config.g and see if you're able to activate the extruder then.
        If that doesn't work, Since this is a tool that will be using an external heater controller you could follow the advice in the cold extrusion wiki entry to define the tool without a heater associated at all.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M302_Allow_cold_extrudes
        Note: One limitation of M302 is that it requires a thermistor to be present for the temperature to be monitored. If your system does not have a thermistor or heater to be monitored, you can define your tool in M563 without a heater to disable cold extrusion protection on that tool. ex: M563 P0 S"Pump" D0 F0 Note the lack of H parameter.
        So in your case
        You would remove the H1 entirely.
        zfengundefined 1 Reply Last reply Reply Quote 0
        • zfengundefined
          zfeng @Phaedrux
          @phaedrux I want to send the temperature signal from PID to the Duet board, do I need adapters to do it? I saw online there's some kind of daughter board for thermocouple. I'm using Duet 2 ethernet, which daughter board should I purchase?
            Can you give more info on your external temperature controller?
            • zfengundefined
              zfeng @Phaedrux
              @phaedrux It's a very common Inkbird PID controller. The thermocouple from the extruder head is a K-type thermocouple.
                If the thermocouple is already going to the PID controller how do you hope to connect it to the Duet as well?
                Do you have a link for that unit?
                • zfengundefined
                  zfeng @Phaedrux
                  @phaedrux I plan to use a dual thermocouple connector to split the thermocouple signal, so that one goes to the PID and the other goes to the Duet board.
                    Phaedrux Moderator @zfeng
                    Ok, yes if you've got a dual thermocouple with two junctions with their own wires then yes, you could run one to the controller and one to the Duet. You would need the Duet Thermocouple Daughterboard to be able to read the temp.
                    https://duet3d.dozuki.com/Wiki/Thermocouple_daughter_board
                    https://duet3d.dozuki.com/Wiki/Connecting_thermocouples
                    • zfengundefined
                      zfeng
                      Hi, now the temperature is all set, but I have some problems with the extruder motor. I used the expansion portion (highlighted in the red square shown below) of the board for extruder signals. The channels I connected are E2, but I couldn't setup the config file to use the E2 motor because it isn't listed.
                        You'll need to alter the config manually to add non-standard mappings.
                        • zfengundefined
                          zfeng @Phaedrux
                          @phaedrux Could you please explain how to do that?
                            If you're using E2 that equates to driver 5 on the duex.
                            So in your M584 command, For the extruder drives you would list all the extruder that will be connected to the main Duet drivers and then add 5 for the expansion header.
                            M584 X0 Y1 Z2:3 E4:5 just as an example.
                            Have you seen this yet? https://duet3d.dozuki.com/Wiki/Using_external_stepper_motor_drivers
                            zfengundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                            • zfengundefined
                              zfeng @Phaedrux
                              @phaedrux Hi, my extruder motor needs 5V, while the Duet board output is 3.3V, I'm thinking of buying a breakout board like this:
                              https://duet3d.dozuki.com/Wiki/Duet_Expansion_Breakout_Board
                              Will it work?
                                @zfeng said in Extruder motor doesn't move:
                                I'm not sure what you mean by this. The stepper motor drivers are constant current drivers. The rated voltage on the motor isn't a requirement.
                                zfengundefined 2 Replies Last reply Reply Quote 0
                                • zfengundefined
                                  zfeng @Phaedrux
                                  @phaedrux I'm not using motor drive output, I'm using the expansion portion of the board, which is 3.3V output. But my extruder motor needs 5V.
                                  • zfengundefined
                                    zfeng @Phaedrux
                                    @phaedrux Since I'll use the E2 of the expansion to wire my extruder motor, how to modify the config code to use the E2? I won't use the E0 and E1.
                                    My config.g Driver code is below:
                                    M569 P0 S0 ; physical drive 0 goes backwards
                                    M584 X0 Y1 Z2 ; set drive mapping
                                    M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
                                    M92 X80.00 Y80.00 Z400.00 ; set steps per mm
                                    M566 X900.00 Y900.00 Z60.00 ; set maximum instantaneous speed changes (mm/min)
                                    M203 X6000.00 Y6000.00 Z180.00 ; set maximum speeds (mm/min)
                                    M201 X500.00 Y500.00 Z20.00 ; set accelerations (mm/s^2)
                                    M906 X800 Y800 Z800 I30 ; set motor currents (mA) and motor idle factor in per cent
                                    M84 S30 ; Set idle timeout
                                      Phaedrux Moderator @Phaedrux
                                      I already answered that I think.
                                      @phaedrux said in Extruder motor doesn't move:
                                      Do you mean your external driver needs 5v?
                                      • zfengundefined
                                        zfeng @Phaedrux
                                        @phaedrux Yes my external driver needs 5V, will this breakout board work for my case?
                                          Can you link to your external driver?
