    What is the minimum wattage of PSU ?.
    431
      dc42 administrators @peter247
      @peter247 said in What is the minimum wattage of PSU ?.:
      Stepper motors: at full rated current, 1.68A * 5 * 24v = 201 watts add 50% 300 watts.
      That part is wrong. Read the page I linked to again.
      peter247undefined 1 Reply Last reply Reply Quote 0
      • peter247undefined
        peter247 @dc42
        @dc42 Stepper motors: at full rated current, the power needed for each motor is its rated current times its rated voltage (if no rated voltage is specified, use the square of the rated current times the phase resistance). This is the power at standstill. To allow for driver losses and the extra power needed to create acceleration, add 50%.
        Multiply by the number of stepper motors.
        The power needed for each motor is its rated current times its rated voltage 1.68A * 24 volt = 40.32 watts per motor.
        To allow for driver losses and the extra power needed to create acceleration, add 50%. 40 watts + 50% = 60 watts per motor
        Multiply by the number of stepper motors * 5 = 60 * 5 = 300 watts
        Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
          The rated voltage of those stepper motors is not 24V.
          • peter247undefined
            peter247 @dc42
            https://e3d-online.com/collections/motors/products/motors
            For I'm using the High Torque Motor which doesn't say a voltage I square the current and times the phase resistance.
            phase resistance = 1 ohm , but not idea what it is .
            motor current = 1.68 amps
            So 1.68 squared * phase resistance ( 2.8 * 1 ) + 50% * 5 motors ?
            That looks more sensible and not into 100s of watts .
            dc42undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
              Yes, that looks right.
                Phaedrux Moderator @peter247
                E3D used to provide much more detailed info on their motors with a model number and data sheet. Not sure why they changed it.
                • peter247undefined
                  peter247 @Phaedrux
                  @phaedrux Looking at your machine , MeanWell SE-200-24V passively cooled PSU.
                  What is the SE , can see people selling the Meanwell RSP-200-24 200W 24V Active PFC Enclosed Power Supply , but the SE look to be on aliexpress .
                    Check digikey or mouser for MeanWell supplies.
                    The particular PSU I'm using may be discontinued at this point I think, but likely replaced by something similar. Perhaps the RSP is that.
                    https://www.mouser.ca/ProductDetail/MEAN-WELL/SE-200-24?qs=erfQA2AIGbXP8MZzK7SQeA==
                    Yes it's marked obsolete, and have a replacement linked.
                    https://www.mouser.ca/ProductDetail/?qs=ah3jBNVE1PQukNhKX3jUsA%3D%3D
                    • peter247undefined
                      peter247 @Phaedrux
                      @phaedrux The LRS-200-24 looks to be a little cheaper than the rsp model , but I guess that depends who you get it from.
                      Thank you , I'll try to get a LRS-200-24 , who need a noisy fan when you can passively cool it.
                        Keep in mind that mouser and digikey usually have free shipping and a warranty, and you're sure to be getting what you pay for.
