    Duet 3 wifi on Caribou
    1.2k
    • Revolutionundefined
      Revolution
      Hello, i have problems with mit Caribou upgraded to duet 3 wifi
      I am heating up to extrude some Filament and get this message:6AE17857-507A-4799-8DD3-3A9074FAB142.jpeg
        Can you post your config.g?
        Can you send M122 and M98 P"config.g" in the Gcode console in DWC and post the results?
        What axis do you have connected to driver 3?
        Revolutionundefined 1 Reply Last reply Reply Quote 0
          Revolution @Phaedrux
          @phaedrux
          Thx for your response
          3A315290-CC60-4B57-AA6C-5864C1435C67.png 1ACDAF3A-5DA0-4D6C-B394-4F3B10DEC921.png 6E594D3F-5F66-4D8C-95DC-FAA348B1090F.png
          I don‘t no wich is driver 3 on the Board?
          Sry its duet 2 wifi……
          Michael Hathawayundefined 1 Reply Last reply Reply Quote 0
          • Michael Hathawayundefined
            Michael Hathaway @Revolution
            @revolution I had this happen to me. One of my driver connector pins were not pushed all the way into the connector plug. Check all of your electrical connections from the stepper motors to the driver connectors.
            Cut me, I bleed Duet3D. 😳 And I love the people here. 😍😍😍
            www.MatterHackers.com - https://discord.gg/Ked7GREqux
            Revolutionundefined 1 Reply Last reply Reply Quote 1
              Revolution @Michael Hathaway
              @tinken
              Hi, you have it on an caribou too?
                There must be a space between M98 and the P"config.g"
                Also please copy and paste the text if possible rather than screen shots in future.
                And the contents of config.g please so we can see which driver is bound to which axis.
                Revolutionundefined 2 Replies Last reply Reply Quote 0
                  @phaedrux
                  27.6.2021, 12:51:42 M98 P"config.g"
                  HTTP is enabled on port 80
                  FTP is enabled on port 21
                  TELNET is disabled
                  Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                  config.g:
                  ; Configuration file for Duet WiFi (firmware version 3.2)
                  ; for 0.9° motors on xye
                  ; for Caribou220- E3d Thermistor - PINDA2
                  ; CariboDuetConfiguration Release : "1.2.0"
                  ; Build : 80
                  ; Copyright Caribou Research & Development 2021. Licensed under GPL3.
                  ; Source code and release notes are available on github: https://github.com/Caribou3d/CaribouDuet-Configuration-and-Macros
                  ; Network settings
                  M550 P"Caribou220-EP" ; set printer name
                  M552 S1 ; enable network
                  M586 P0 S1 ; enable HTTP
                  M586 P1 S1 ; enable FTP
                  M586 P2 S0 ; disable Telnet
                  M575 P1 S1 B57600 ; Enable support for PanelDue
                  M569 P0 S0 F11 ; physical drive 0 goes backwards - x-axis
                  M569 P1 S0 F8 Y3:2 ; physical drive 1 goes backwards - y-axis
                  M569 P2 S0 F10 ; physical drive 2 goes backwards - z - left
                  M569 P3 S1 F14 ; physical drive 3 goes forwards - Extruder
                  M569 P4 S0 F10 ; physical drive 4 goes backwards - z right
                  ; Motor Configuration
                  M584 X0 Y1 Z2:4 E3 ; set drive mapping
                  M671 X-36.5:293.5 Y0:0 S0.35 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                  ; set Microsteps and steps / mm
                  M92 X200.00 Y200.00 Z400.00 E830.00 ; set steps per mm
                  ; set motor currents
                  M906 X800 Y850 Z450 E550 I40 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S60 ; Set idle timeout
                  ; set speeds
                  M201 X500.00 Y500.00 Z100.00 E500.00 ; set accelerations (mm/s^2)
                  M203 X9000.00 Y9000.00 Z1000.00 E3600.00 ; set maximum speeds (mm/min)
                  M204 P500.0 T500.0 ; set print and travel accelerations (mm(s^2)
                  M566 X480.00 Y480.00 Z48.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                  M564 H0 ; Allow unhomed movement
                  M208 X-2 Y-7.5 Z0 S1 ; set axis minima
                  M208 X256.9 Y214 Z216.50 S0 ; set axis maxima
                  M574 X1 S3 ; configure sensorless endstop for low end on X
                  M574 Y1 S3 ; configure sensorless endstop for low end on Y
                  M574 Z2 S3 ; configure sensorless endstop for high end on Z
                  M591 D0 P2 C"e0_stop" S1 ; configure extruder endtstop (filament sensor)
                  ; PINDA2
                  M558 P5 C"zprobe.in" H1.5 F1000 T12000 A3 ; set Z probe to PINDA2
                  M308 S2 P"e1temp" A"Pinda V2" Y"thermistor" T100000 B3950 ; temperature of PINDA2
                  M557 X23:235 Y5:186 S30.25:30 ; define mesh grid
                  M574 Z1 S2 ; Set endstops controlled by probe
                  ; Stallguard Sensitivy
                  M915 X S2 F0 H400 R0 ; Set X axis Sensitivity
                  M915 Y S1 F0 H400 R0 ; Set Y axis Sensitivity
                  M915 Z S0 F0 H200 R0 ; Set Z axis Sensitivity
                  ; Heater & Fans
                  ; heated bed
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 R4700 A"Bed" ; configure sensor 0 as thermistor on pin bedtemp
                  M950 H0 C"bedheat" Q50 T0 ; create bed heater output on bedheat and map it to sensor 0
                  M143 H0 S110 ; set temperature limit for heater 0 to 110C
                  ; extruder
                  ; Hotend (Mosquito or Mosquito Magnum with E3d Thermistor)
                  M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700 A"Nozzle E1" ; E3d configure sensor 0 as thermistor on pin e0temp
                  M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 2
                  M308 S4 P"mcu-temp" Y"mcu-temp" A"MCU" ; set virtual heater for MCU
                  M308 S5 P"drivers" Y"drivers" A"Driver" ; set virtual heater for stepper drivers
                  ; extruder fan (temerature controlled)
                  M950 F1 C"fan1" Q500 ; create fan 1 on pin fan0 and set its frequency
                  M106 P1 H1 T45
                  ; radial fan
                  M950 F0 C"fan0" Q160 ; create fan 0 on pin fan1 and set its frequency
                  M302 S190 R190 ; allow extrusion starting from 190°C and retractions already from 190°C
                  ; other settings
                  M18 XYE ; release / unlock X, Y, and E axis
                  M501 ; use config-override (for Thermistor Parameters and other settings)
                  M83 ; ... but relative extruder moves
                  ; Offsets - place off-sets for x and y here. z-offsets are handled in the print sheet macros
                  G31 P1000 X23 Y5
                    @phaedrux
                    Hi, the extruder is now working
                    I have made the first layer calibration- came out very good
                    But when i will start a print came this message:
                    28.6.2021, 17:04:24 Warning: M73: Command is not supported
                    Maximum jerk rates (mm/sec): X: 8.0, Y: 8.0, Z: 0.4, E: 1.5
                    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.2 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-01-05
                      dc42 administrators @Revolution
                      @revolution, either ignore that warning; or configure your slicer not to generate M73 commands; or upgrade to firmware 3.3.
                        Revolution @dc42
                        Hi, now i have upgraded to 3.3
                        When i will print something i get this message
                        28.6.2021, 18:06:15 Cancelled printing file 0:/gcodes/gearr_0.2mm_PLA_MK3S_18m.gcode, print time was 0h 2m
                        Emergency Stop! Reset the controller to continue.
                        Error: Homing failed
                        Can i Post videos?
                          Yes you can post videos.
                          When do you get that error?
                          Please post your homing macros as well as your slicer start gcode so we can see what is going on when you start a print.
                            @phaedrux
                            Looks like this
                            https://vimeo.com/568524469
                            Start.g:
                            ; Executed before each print - BEFORE ANY SLICER CODE IS RAN
                            ; This also loads the heightmap
                            M122 ; Clear diagnostic data to cleanly capture print evolution statistics.
                            T0 ; Ensure the tool is selected
                            M572 D0 S0.0 ; Clear pressure advance.
                            M220 S100 ; Set speed factor back to 100% in case it was changed
                            M221 S100 ; Set extrusion factor back to 100% in case it was changed
                            M290 R0 S0 ; Clear any baby-stepping
                            M106 S0 ; Turn part cooling blower off if it is on
                            M703 ; Execute loaded filament's config.g
                            G32 ; execute bed.g (level gantry)
                            G29 S1 ; Load bed mesh for the system's set filament type
                            M400 ; Finish all moves, clear the buffer
                            G90 ; Absolute Positioning
                            M83 ; Extruder relative mode
                            M98 P"0:/sys/current-sense-normal.g" ; Ensure that motor currents and sense are set for printing
                            ; Slicer generated gcode takes it away from here ....
                              Phaedrux Moderator @Revolution
                              @revolution said in Duet 3 wifi on Caribou:
                              What do you have in bed.g and homeall.g?
                              Can you please also post the slicer start gcode section?
                              Can you describe what I'm seeing in that video?
                                @phaedrux
                                ; bed.g
                                G28 W ; home
                                G30 P0 X25 Y100 Z-99999 ; probe near a leadscrew, half way along Y axis
                                G30 P1 X235 Y100 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
                                G90 ; back to absolute mode
                                G1 H2 Z8 F2600 ; raise head 4mm to ensure it is above the Z probe trigger height
                                G1 X104 Y100 F6000 ; put head over the centre of the bed, or wherever you want to probe
                                G30 ; lower head, stop when probe triggered and set Z to trigger height
                                ; Home XYZ Axis
                                M98 P"homez.g" ; homeall is the same as homez
                                In the Video you see starting a Print, the leveling and Then the Print should starting but then the extruder goes only on the Home of x and nothing happens
                                I Hope you know what i mean?
                                  Ok, what's in homez.g then?
                                  It looks like you get through the leveling portion. Then the print should be starting, but it moves very slowly to the left. If that is from the sliced gcode section please share either the slicer start gcode section or share the first 50 lines or so of a sliced gcode file.
                                  Everything the printer is doing is just gcode commands. So being able to see what those commands are is important for understanding what's actually happening.
                                    @phaedrux
                                    homez.g:
                                    ; Home XYZ Axis
                                    G91 ; relative positioning
                                    M98 P"current-sense-homing.g" ; Ensure the current and sensitivity is set for homing routines.
                                    G1 H2 X0.5 Y-0.5 F10000 ; energise motors to ensure they are not stalled
                                    M400 ; wait for current moves to finish
                                    M913 X40 Y40 ; drop motor current to 40%/40%
                                    G4 P200 ; wait 200ms
                                    ; Home X Axis
                                    G1 H1 X5 F1000 ; move slowly away
                                    G1 H1 X-260 F3000 ; move quickly to X axis endstop and stop there (first pass)
                                    G1 H2 X5 F1000 ; go back a few mm
                                    G1 H1 X-10 F3000 ; move slowly to X axis endstop once more (second pass)
                                    ; Home Y Axis
                                    G1 H1 Y5 F1000 ; move slowly away
                                    G1 H1 Y-260 F3000 ; move quickly to X axis endstop and stop there (first pass)
                                    G1 H2 Y5 F1000 ; go back a few mm
                                    G1 H1 Y-10 F3000 ; move slowly to X axis endstop once more (second pass)
                                    M913 X100 Y100 ; return X & Y motor
                                    G90 ; absolute positioning
                                    ; Home Z Axis
                                    G1 X11.5 Y4.5 F6000 ; go to first probe point
                                    G1 Z0.15 F100 ; move Z to origin
                                    G1 Z1 F100 ; lift Z relative to current position
                                    M400 ; Wait for current moves to finish
                                    M98 P"current-sense-normal.g" ; Ensure the current and sensitivity is set for homing routines.
                                    Start G-code/ Prusaslicer from the object in the Video:
                                    M115 U3.9.3 ; tell printer latest fw version
                                    G90 ; use absolute coordinates
                                    M83 ; extruder relative mode
                                    M104 S[first_layer_temperature] ; set extruder temp
                                    M140 S[first_layer_bed_temperature] ; set bed temp
                                    M190 S[first_layer_bed_temperature] ; wait for bed temp
                                    M109 S[first_layer_temperature] ; wait for extruder temp
                                    G28 W ; home all without mesh bed level
                                    G80 ; mesh bed leveling
                                    G1 Y-3.0 F1000.0 ; go outside print area
                                    G92 E0.0
                                    G1 X60.0 E9.0 F1000.0 ; intro line
                                    G1 X100.0 E12.5 F1000.0 ; intro line
                                    G92 E0.0
                                    M221 S{if layer_height<0.075}100{else}95{endif}
                                      Would you say that the slow movement occurs here? F1000 is about 16mm/s so quite slow. F6000 would be more appropriate for a travel move.
                                      There are a few things in your slicer start gcode that aren't compatible with reprapfirmware. What gcode flavor do you have set for PrusaSlicer?
                                      M115 for instance just reports the current firmware version.
                                      G28 W would likely just run homeall.g with no changes.
                                      G80 isn't a supported gcode at all. To do mesh compensation in RRF you use G29.
                                      Can you post those two macros as well for full disclosure?
                                      Also, at what point in your video are you getting the short to ground error on driver 3? Driver 3 appears to be your extruder.
                                      Are you able to extrude into free air by heating the hotend and commanding extrusion from DWC or paneldue?
                                        @phaedrux
                                        Now i have solve the problem:
                                        i have changed in Prusaslicer the Firmware G-Code Typ to "RepRap/Sprinter"
                                        Then i add this customised Start G-code
                                        ; start script for PrusaSlicer for CaribouDuet
                                        G0 X60 Y-3 Z80 ; move extruder above bed, keep extruder in front for cleaning and checking
                                        M104 S160 T0 ; pre-heat extruder to 160°C
                                        M140 S[first_layer_bed_temperature] ; this will take the layer 1 temperature for bed 0
                                        G29 ; mesh bed leveling using defined mesh grid
                                        G0 X0 Y-3 Z0.6 ; go outside print area
                                        M104 S[first_layer_temperature] ; set extruder temperature
                                        M98 P"0:/sys/primeLine.g" ; execute primeline macro
                                        G92 E0.0 ; set extruder position
                                        M572 D0 S0.07 ; set pressure advance
                                        Now it works!
