Height map makes my bed look warped…Why???
4.3k
    Aflac01
    When i run the mesh bed compensation I get the above heightmap.
    I know my bed does not actually look like that. I have even changed the bed and it give me the exact same thing, ive used both FSR underbed sensors and piezo in the hotend and they give the same result
    Thus I would think its something with the machine itself, but I am not sure what it would be. I use a all metal frame from trick laser and everything appears to be square and set up right, but i could use some assistance in what this could mean and where to look for the problem.
      number40fan
      What are your auto calibration results?
        Aflac01
        Calibrated 7 factors using 17 points, deviation before 1.540 after 1.047
          Aflac01
          so in the ball park of not good
            I guess it's a delta then. What M557 command do you use to define the grid? In the bed.g file that you use for auto calibration, are you using trigger height corrections on the G30 command?
              number40fan
              dc42, do you have your config, override and bed file posted anywhere? I have always wanted to take a look at them.
                Aflac01
                yes, its a Delta, that probably would have been good info to include in my original post, built using trick laser max metal frame.
                M557 R125 S20
                At one point when i was using fsr under beds i tried height corrections. Just looking at it i found that somehow i must have fat finged something in because one point had a 0.2 and one point had a 6 correction in it, all the rest where zero. fixed them all to zero and it changed it to this.
                Calibrated 7 factors using 17 points, deviation before 0.686 after 0.224
                  Aflac01
                  ok, cleared out my config override file and tried againl
                  things look better, but that height map still looks odd to me? am i getting into normal now or do i have something else going on?
                  Calibrated 6 factors using 17 points, deviation before 0.126 after 0.125
                    number40fan
                    Want to give 9 factors a shot?
                      Aflac01
                      i thought it only went to 7
                        number40fan
                        Nope, all the way to 9.
                          Forgvn77
                          I ran into more issues when I calibrated over 6 factors. Six ended up working great for me. More wasn't better in this case when I set up my delta. The trigger height corrections are what you'll need to establish and plug in. Once you get those nailed, you'll be off and running.
                          Velleman K8200, Geeetech G2S Pro (x2), Geeetech Rostock 301 retrofitted with Duet
                          Make A Difference!
                            Aflac01
                            9 factors is looking better for me
                            im using a piezo in the print head so i have no variation in trigger height
                            Calibrated 9 factors using 17 points, deviation before 0.159 after 0.034
                              number40fan
                              That's a lot better. What are your M665 and M666 changes?
                                Aflac01
                                config has
                                M665 R135.59 L330.77 B135.59 H235.444
                                M666 X0 Y0 Z0
                                after calibration i got
                                M665 Diagonal 344.383, delta radius 138.954, homed height 235.472, bed radius 135.6, X -0.050°, Y -0.359°, Z 0.000°
                                M666 Endstop adjustments X-0.20 Y0.13 Z0.07, tilt X-0.23% Y0.22%
                                  number40fan
                                  M500 will save that to override.g and if you have M501 at the end of your config.g, it'll use those settings.
                                    Aflac01
                                    so yes, 9 made the calibration look good, but it did not make it print good. back to 6 i guess
                                      number40fan
                                      What is wrong with the print?
                                        Aflac01
                                        Things where great near the center, but out near the edges it went right off the bed. I guess it
                                        changing the arm length by 14mm was not the best
                                          number40fan
                                          How big is your bed?
                                          5 out of 28
