    Start / Stop S3D SCRIPT / G-CODE
    2.5k
    • fcwiltundefined
      fcwilt @noblebran
      @noblebran
      Certainly post your files here.
      We all are glad to check them over and make suggestions.
      noblebranundefined 4 Replies Last reply Reply Quote 0
      • noblebranundefined
        noblebran @noblebran
        @noblebran Thank you sir! Be well!
        I own a Tevo Little Monster but there isn't much left of that except for the frame. Duet 2 Wifi + PanelDue 7i.
          noblebran @fcwilt
          @fcwilt said in Start / Stop S3D SCRIPT / G-CODE:
          @noblebran
          Here is my load filament file (not sure if its the most efficient but it works)
          M104 P1 S225
          M83
          M104 S230 T0
          M109 S230 T0
          G1 E300 F500       ; LOAD FILAMENT
          M104 P1 S0
            noblebran @fcwilt
            @noblebran
            UNLOAD
            M104 P1 S225
            M83
            M104 S230 T0
            M109 S230 T0
            G1 E15 F250          ;LOAD FILAMENT
            G1 E-600 F3500       ;UNLOAD FILAMENT
            M104 P1 S0
              noblebran @fcwilt
              @noblebran
              My start in my slicer:
              G28; HOME
              ;G32 (REMOVE SEMI IF YOU WANT TO REMAP)
              G29 S1; USE STORED MESH
              G92 E1; SET EXTRUDER TO 1
                noblebran @fcwilt
                @noblebran
                I kept most of your ending script:
                M291 R"Finishing Print" P"Please wait..." T0
                M83                                                  ; extruder relative
                G1 E-1 F3600                                  ; retract filament
                M106 P0 S0                                     ; turn part fan off
                G10 P0 S-999 R-999 ; turn extruder heater off (also sets temps to zero)
                T-1          	             ; deselect all tools
                M140 S0                ; set bed heater active temp to 0
                M140 S-999           ; turn bed heater off
                G91                       ; relative moves
                G1 Z100 F1200      ; move the nozzle out of the way - step 1
                G90                         ; absolute moves
                G1 X0 Y150 F3000   ; move the nozzle out of the way - step 2
                G28
                M118 L0 P4 S"FT5|Print Finished"
                M291 R"Print Finished" P"OK" T0
                • fcwiltundefined
                  fcwilt @noblebran
                  @noblebran said in Start / Stop S3D SCRIPT / G-CODE:
                  @noblebran
                  G28; HOME
                  Does your homing script set the Z=0 datum?
                  And why are you not waiting for temps to reach their set points?
                  noblebranundefined 1 Reply Last reply Reply Quote 0
                    noblebran @fcwilt
                    @noblebran
                    G28; HOME
                    When it comes z=515. 0 would right at the print surface. I have found on the deltas this is the correct way?
                    In the config.g it calls out for the temps to reach their set points.
                    • fcwiltundefined
                      fcwilt @noblebran
                      Don't know what you mean.
                      Config.g? You mean the main config.g?
                        noblebran @fcwilt
                        0 is the print surface, so when I home z=515 and when it prints itโ€™s .xxxx
                        Yes sir.
                        • fcwiltundefined
                          fcwilt @noblebran
                          Yes sir.
                          How can you be waiting for hotends/bed to reach temps when you cannot, as a practical matter, set them in config.g?
                          noblebranundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                            noblebran @fcwilt
                            Yes sir.
                            It must be done in the slicer? I choose the bed and temp setting, after I slice it in S3D, it has the code in the file (part GCODE file).
                            • fcwiltundefined
                              fcwilt @noblebran
                              No, it does not have to be done in the slicer.
                              I do it using the filament handling feature in the DWC.
                              I have entered in a number of different filaments that I use into the DWC.
                              For each filament entered there is a special config.g file created.
                              My start code is in a file named print_begin.g and is invoked from the slicer with M98 P"print_begin.g"
                              In that file I have (among other things) this:
                              T0							; select tool 0 so extruder commands below will work
                              M703							; configure selected filament (sets bed/extruder temps, extrusion multiplier)
                              ; some other unrelated commands
                              M116							; wait for temps to reach set points
                              That M703 command invokes the special config.g file for the currently selected filament and in that file I have any commands I want unique to that filament and in that file I set, at a minimum, the bed temp, the hotend temp and the extrusion multiplier.
                              I have found this to be an effective way to set my temps and I can use different slicers easily as the start code is on the Duet, not in the slicer.
                              But this is just my way. You should do it in whatever way suits you the best.
                                noblebran @fcwilt
                                Thank you sir, I find I like to 'master' one slicer and I guess I almost put all my eggs in one basket so to speak. I will certainly take advantage of the way you are doing it but I want to get successful at printing the way I am now. I can say my load and unload macros work, ha ha... baby steps ๐Ÿ™‚
                                Again thank you for helping!
                                  Phaedrux Moderator @fcwilt
                                  Well, you can set the nozzle and have it take effect with a G10 and T0 to select the tool you can get it to heat right at boot. Whether or not you SHOULD is another matter entirely.
                                  • fcwiltundefined
                                    fcwilt @Phaedrux
                                    @phaedrux said in Start / Stop S3D SCRIPT / G-CODE:
                                    Which is why I said practical. Editing config.g just to specify different temperatures is not what I would call practical.
                                    But that's just me.
                                      @fcwilt In that case, yes you're completely right. It's very impractical and ill advised.
                                      noblebranundefined 1 Reply Last reply Reply Quote 1
                                        noblebran @Phaedrux
                                        @phaedrux @fcwilt
                                        Thank you both!
                                        • fcwiltundefined
                                          fcwilt @noblebran
                                          @phaedrux @fcwilt
                                          Thank you both!
                                          Glad to help in anyway we can.
                                          And if we cannot help we will try our best not to mess things up too badly. ๐Ÿ˜‰
                                            noblebran @fcwilt
                                            @phaedrux @fcwilt
                                            Thank you both!
                                            ha ha thats all I can ask for!
                                            Now it is just fine tuning...
