    File to edit language in Duet 3D
    Duet Web Control
    1.3k
    • chrishammundefined
      chrishamm administrators @Chri55
      @chri55 Did you generate the actual DWC bundle with npm run build before uploading the file from the dist folder? If yes, try clearing the browser cache or reload DWC with Ctrl+Shift+R.
      Duet software engineer
      • Chri55undefined
        Chri55 @jay_s_uk
        @jay_s_uk I am trying to add a Polish language, letter identifier is "pl" which I used.
        To confirm which files should I upload? may be I am making a mistake not sending correct files.
        I uploaded zip with a directory named "i18n" that consists all language files like fr.js, en.js and new pl.js an corrected index.js.
        Should I upload something more?
        Where I can find those .json files?
          @chri55 You cannot simply change a source code file and upload it on the System page, it's required to rebuild DWC every time that's done. Can you share your pl translations file? Then I can build new DWC ZIPs for you and I can integrate your translations right away into the next DWC version.
          Chri55undefined 1 Reply Last reply Reply Quote 0
          • Chri55undefined
            Chri55 @chrishamm
            @chrishamm In what file extension should i send it because I con not sent .js file?
            And the translation is not 100% done but It needs a few corrections but to do that i need to see context when text is shown.
              @chri55 .txt should work.
              • Chri55undefined
                Chri55 @chrishamm
                @chrishamm pl.txt
                Here is the file.
                And I have a question if you can write the steps what should be done if I would like to do It myself (if it is not a big problem, and may be it will help some other people). It is a completely new thing for me and don't understand it 100 %.
                  @chri55 You've got to set up NodeJS first (there are countless tutorials for that on the web) and when you're done, just run two commands from a command-line prompt in the DWC directory:
                  npm install
                  npm run build
                  That will generate DuetWebControl-*.zip files in the dist directory. This procedure is already documented here.
                  I'm going to build new DWC versions for you in a moment.
                  • Chri55undefined
                    Chri55 @chrishamm
                    @chrishamm Ok. I need to watch some of those tutorials and educate myself. Thank you for the information. I never did stuff like that and it seemed like and easy task just to translate but it happened to be a bit over my abilities. Thank you again.
                      @chri55 Here you go:
                      • for standalone mode: https://pkg.duet3d.com/DuetWebControl-SD.zip
                      • for SBC mode: https://pkg.duet3d.com/DuetWebControl-SBC.zip
                      And the fixed pl.js - there were some malformed strings in it.
                      Chri55undefined 2 Replies Last reply Reply Quote 0
                      • Chri55undefined
                        Chri55 @chrishamm
                        @chrishamm Thank you very much, sorry that I did not reply earlier but I did not take my laptop with me for a weekend. The translation works well and seems to be translated correctly for a part that i checked for now. If I find some mistakes I will try correct them.
                        • Chri55undefined
                          Chri55 @chrishamm
                          @chrishamm
                          Hey, I am sending you a file with a few corrections that I found while checking the DWC and printing test models. There are still not translated words and phrases. I have no idea how to translate them to keep them short or I am missing the context and I am not sure which meaning I should use to be 100% correct. Maybe there are some other users from Poland and have better knowledge in that matter.
                          You could load this file with the next update of the program, just not to update all for the language corrections (when most people use English anyway).
                          pl with a few corrections.js
                          domka999undefined chrishammundefined 2 Replies Last reply Reply Quote 0
                          • domka999undefined
                            domka999 @Chri55
                            @chrishamm Hey, I wanted to remind ourselves in case you didn't see Chri55 post above!
                            Thanks in advance! 🙂
                              jay_s_uk @domka999
                              @domka999 why not issue a PR on github? It will probably get integrated much more quickly
                                @chri55 Thanks! I'll add your updated version to DWC 3.4-b2.
