    Cannot Connect to Duet 3 Web Control
    Duet Web Control
    3.6k
    • Frank 0undefined
      Frank 0 @Phaedrux
      @phaedrux No I am not. I realized the error with the network commands was because the SD card got loose. I am trying to get a wired network connection (ethernet) and access the web control page.
      https://duet3d.dozuki.com/Wiki/Setting_up_networking_on_Duet I have read and looked at this page as well.
        So with the SD card back in place are you having better luck?
        Frank 0undefined 1 Reply Last reply Reply Quote 0
        • Frank 0undefined
          Frank 0 @Phaedrux
          @phaedrux Better, but still not completely working. Is it possible to connect via just USB instead of using the ethernet/networking?
            How does it behave now? Are you able to connect to the web interface or not?
            Does the SD card have the correct files in the /www folder?
            You can stream gcode over USB from a sender program like octoprint or simplify3d or pronterface, but you lose a lot of features including speed and quality.
            • Frank 0undefined
              Frank 0 @Phaedrux
              @phaedrux When I try to set up the networking, I get this on YAT: 21268087-14c2-44a7-9c8d-ea10fe828c51-image.png. Visiting this address on a browser does not work. I just want to connect to the Web Control
              fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
              • fcwiltundefined
                fcwilt @Frank 0
                @frank-0
                You have to have on the SD card a basic config.g and the files for the web interface.
                Do you have those on the SD card?
                  Phaedrux Moderator @Frank 0
                  @frank-0 said in Cannot Connect to Duet 3 Web Control:
                  What do you actually see in the browser when you try to go to that address?
                  Are you able to ping that address from your computer?
                  What IP address does your computer have?
                  This will help us confirm if you're able to communicate with the Duet over the network.
                  Can you show us a screenshot of the contents of your SD card?
                  At minimum it should have a folder structure similar to what is shown here: https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
                  If the /www folder is missing or empty, you won't be able to connect to the web control even if the network connection is good. If it's missing or empty, you can replace the files using this zip file.
                  https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/DuetWebControl-SD.zip
                  Extract the contents of that zip file into the /www folder.
                  Frank 0undefined 2 Replies Last reply Reply Quote 0
                  • Frank 0undefined
                    Frank 0 @Phaedrux
                    @phaedrux The SD card contents look just like the link you sent. The www folder is there and has the stuff in the second link you sent. When I try to go to the address, I believe it either just says something along the lines of "cannot connect" or "no internet" (because I have no internet on the PC I am using-- only 1 ethernet cable).
                    • Frank 0undefined
                      Frank 0 @Phaedrux
                      @phaedrux f372b355-0b65-4023-af6d-c4d0da19ebf3-image.png YAT is not responding back to me anymore either?
                        Replug the USB cable and try to reconnect? If it still won't respond, what LEDs are lit up on the board?
                        • Frank 0undefined
                          Frank 0 @Phaedrux
                          @phaedrux There is 5 LEDs lit up. The USB one next to the micro USB. Blue next to V Fused, and 3 other lights for 12V, 5V, and 3.3V. (red lights and green). Right now, the YAT program will not even send a response back to me when I type in commands (see screenshot above). I tried re plugging the device in, undoing the drivers, reinstalling the drivers, etc.
                          SD Card contents: fc1a9ad2-5fac-4a95-8ecb-e21c3014bb94-image.png
                          sys folder: c70a06d4-342c-494c-9fd9-5fcc3ee748d6-image.png
                          www folder: b4ef1cda-0961-4a57-b3b2-b9de3fd8b4cf-image.png
                            The screen shot showing the SD card contents has a lot of additional files I'm not expecting to see. It looks like a linux partition.
                            Do you have a spare SD card you can test with? Format it as FAT32 and Copy over just the file folders.
                            When you connect the board via USB do you get a device detected chime from windows? Does anything show up in device manager?
                            • Frank 0undefined
                              Frank 0 @Phaedrux
                              @phaedrux Yes, it shows up as COM3 USB Serial Device. When I install the drivers to it, it changes to Bossa Program or something like that. Should I go into the config files and change the IP to what I plan to assign to the printer? (It shows up in device manager, but I dont get a windows notification of it connecting. could be a notification setting).
                              • Frank 0undefined
                                Frank 0
                                @phaedrux
                                Seems like this may be my issue. I have the Duet 3 6HC Mainboard. How can I get the right firmware again? The link appears to be for a different version of the board.
                                • Frank 0undefined
                                  Frank 0 @Phaedrux
                                  @phaedrux I reinstalled the firmware and YAT is responding. Im back to the old problem of not being able to connect to the web control.
                                  kb58undefined 1 Reply Last reply Reply Quote 0
                                    Ok, it seems like the firmware got wiped and you've got it back on, so that's good.
                                    In YAT, please send M115 to confirm what firmware version was installed. When we know the firmware version we can use the correct DWC files for that version.
                                    Once we have the correct DWC files for that version in place we can work on setting an IP address and connecting to the web interface.
                                    The easiest would be just letting the duet get a DHCP address from the router and then using http://duet3.local to connect to it, but you can also set a static IP in the config.g if you prefer as long as you're sure the static IP you choose is valid and free to use on the network and isn't likely to be assigned to another device at some point which would generate a conflict.
                                    • kb58undefined
                                      kb58 @Frank 0
                                      @frank-0 Do you have something like this at the start of your config.g file:
                                      M552 P192.168.2.2 S1 ; set hard address
                                      M553 P255.255.255.0 ; assign subnet address
                                      M586 P0 S1 ; enable HTTP
                                      M586 P1 S0 ; disable FTP
                                      M586 P2 S0 ; disable Telnet;
                                      Better yet, post up your config.g file
                                      Scratch-built 350mmx350mm coreXY, linear rails, ballscrews, 3 Z axis, Duet3 6HC, v3.3, Tool Board v1.1, BondTech LGX + Mosquito hot end
                                      • Frank 0undefined
                                        Frank 0
                                        @kb58 After using Bossa to reset my firmware, I cannot find the config.g file. The sys folder changed to this
                                        • Frank 0undefined
                                          Frank 0 @Phaedrux
                                          @phaedrux I do not think my SD card has everything on it properly. Is there a way I can fix/confirm my SD card is as should be? I will run the M115 command after or soon.
                                            I have never seen anything like that before.
                                            I suggest you get a clean new SD card, format it as FAT32, and then start fresh from there.
                                            Create the following folders
                                            sys
                                            macros
                                            www
                                            gcodes
                                            menu
                                            filaments
                                            Create a fresh config file set from here: https://configtool.reprapfirmware.org/Start
                                            Fill out the info to the best of your knowledge. We just want a starting point.
                                            What firmware bin file version did you use to flash with Bossa? 3.3?
                                            https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/DuetWebControl-SD.zip
                                            Download that zip file and extract it into the /www/ folder.
                                            That should get your SD card back to a working state.
                                            Frank 0undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
