    Cannot Connect to Duet 3 Web Control
    Duet Web Control
    3.6k
    • Frank 0undefined
      Frank 0 @Phaedrux
      @phaedrux The SD card contents look just like the link you sent. The www folder is there and has the stuff in the second link you sent. When I try to go to the address, I believe it either just says something along the lines of "cannot connect" or "no internet" (because I have no internet on the PC I am using-- only 1 ethernet cable).
      • Frank 0undefined
        Frank 0 @Phaedrux
        @phaedrux f372b355-0b65-4023-af6d-c4d0da19ebf3-image.png YAT is not responding back to me anymore either?
          Replug the USB cable and try to reconnect? If it still won't respond, what LEDs are lit up on the board?
          Are you able to ping that address from your computer?
          What IP address does your computer have?
          Frank 0undefined 1 Reply Last reply Reply Quote 0
          • Frank 0undefined
            Frank 0 @Phaedrux
            @phaedrux There is 5 LEDs lit up. The USB one next to the micro USB. Blue next to V Fused, and 3 other lights for 12V, 5V, and 3.3V. (red lights and green). Right now, the YAT program will not even send a response back to me when I type in commands (see screenshot above). I tried re plugging the device in, undoing the drivers, reinstalling the drivers, etc.
            SD Card contents: fc1a9ad2-5fac-4a95-8ecb-e21c3014bb94-image.png
            sys folder: c70a06d4-342c-494c-9fd9-5fcc3ee748d6-image.png
            www folder: b4ef1cda-0961-4a57-b3b2-b9de3fd8b4cf-image.png
              The screen shot showing the SD card contents has a lot of additional files I'm not expecting to see. It looks like a linux partition.
              Do you have a spare SD card you can test with? Format it as FAT32 and Copy over just the file folders.
              When you connect the board via USB do you get a device detected chime from windows? Does anything show up in device manager?
              Frank 0undefined 2 Replies Last reply Reply Quote 0
              • Frank 0undefined
                Frank 0 @Phaedrux
                @phaedrux Yes, it shows up as COM3 USB Serial Device. When I install the drivers to it, it changes to Bossa Program or something like that. Should I go into the config files and change the IP to what I plan to assign to the printer? (It shows up in device manager, but I dont get a windows notification of it connecting. could be a notification setting).
                • Frank 0undefined
                  Frank 0
                  @phaedrux
                  Seems like this may be my issue. I have the Duet 3 6HC Mainboard. How can I get the right firmware again? The link appears to be for a different version of the board.
                  • Frank 0undefined
                    Frank 0 @Phaedrux
                    @phaedrux I reinstalled the firmware and YAT is responding. Im back to the old problem of not being able to connect to the web control.
                    kb58undefined 1 Reply Last reply Reply Quote 0
                      Ok, it seems like the firmware got wiped and you've got it back on, so that's good.
                      In YAT, please send M115 to confirm what firmware version was installed. When we know the firmware version we can use the correct DWC files for that version.
                      Once we have the correct DWC files for that version in place we can work on setting an IP address and connecting to the web interface.
                      The easiest would be just letting the duet get a DHCP address from the router and then using http://duet3.local to connect to it, but you can also set a static IP in the config.g if you prefer as long as you're sure the static IP you choose is valid and free to use on the network and isn't likely to be assigned to another device at some point which would generate a conflict.
                      • kb58undefined
                        kb58 @Frank 0
                        @frank-0 Do you have something like this at the start of your config.g file:
                        M552 P192.168.2.2 S1 ; set hard address
                        M553 P255.255.255.0 ; assign subnet address
                        M586 P0 S1 ; enable HTTP
                        M586 P1 S0 ; disable FTP
                        M586 P2 S0 ; disable Telnet;
                        Better yet, post up your config.g file
                        Scratch-built 350mmx350mm coreXY, linear rails, ballscrews, 3 Z axis, Duet3 6HC, v3.3, Tool Board v1.1, BondTech LGX + Mosquito hot end
                        • Frank 0undefined
                          Frank 0
                          @kb58 After using Bossa to reset my firmware, I cannot find the config.g file. The sys folder changed to this
                          • Frank 0undefined
                            Frank 0 @Phaedrux
                            @phaedrux I do not think my SD card has everything on it properly. Is there a way I can fix/confirm my SD card is as should be? I will run the M115 command after or soon.
                              Phaedrux Moderator @Frank 0
                              @frank-0 said in Cannot Connect to Duet 3 Web Control:
                              I have never seen anything like that before.
                              I suggest you get a clean new SD card, format it as FAT32, and then start fresh from there.
                              Create the following folders
                              sys
                              macros
                              www
                              gcodes
                              menu
                              filaments
                              Create a fresh config file set from here: https://configtool.reprapfirmware.org/Start
                              Fill out the info to the best of your knowledge. We just want a starting point.
                              What firmware bin file version did you use to flash with Bossa? 3.3?
                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/DuetWebControl-SD.zip
                              Download that zip file and extract it into the /www/ folder.
                              That should get your SD card back to a working state.
                              Frank 0undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                              • Frank 0undefined
                                Frank 0 @Phaedrux
                                @phaedrux Does using the config tool automatically generate a www folder? I used the tool and it had me download a sys and www folder
                                • Frank 0undefined
                                  Frank 0 @Frank 0
                                  @frank-0 cf85cbd4-660d-4f7f-a0d5-eb78da39d538-image.png I downloaded the third link here when using Bossa.
                                  https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                                  I followed fall back procedure #2
                                  • Frank 0undefined
                                    Frank 0 @Phaedrux
                                    @phaedrux FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.0beta1 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-07-10 16:20:28<LF>ok<LF>
                                    When running M115 Command
                                      It will if you have checked off the include latest firmware/Duet Web Control files.
                                      That's probably one step further than I would have recommended. I'd stick to the latest stable release while we're troubleshooting which is 3.3.
                                      https://github.com/Duet3D/RepRapFirmware/releases/tag/3.3
                                      Regardless, now that you have a firmware flashed and an SD card redone, are you able to get an IP address in YAT?
                                      • Frank 0undefined
                                        Frank 0 @Phaedrux
                                        @phaedrux Is the latest stable release not 3.3? What happens if the SD card has 3.3 and the board has 3.4?
                                        • Frank 0undefined
                                          Frank 0 @Phaedrux
                                          @phaedrux Made a new SD card and have this on it. 6650af5e-3a6a-4fce-9761-c51ba26c943e-image.png.
                                          Is this all I need?
                                            The SD card doesn't really hold firmware in any meaningful way other than it has the bin files available to be flashed to the board itself. We can go back to 3.3 once you have solid access to dwc again.
