Solved "custom" fan doesn't work
@the_dragonlord if you're out of heater and fan outputs on the main board, then you'll need to use the expansion header with a 5v step up. Easiest option is to get the expansion breakout board
https://www.duet3d.com/Expansion_BreakoutAlternatively go full Duex...
Or see if you can find a mosfet that works with 3.3v
@engikeneer said in "custom" fan doesn't work:
but isn't there any other pin that can be used without purchasing an expansion board wich is unuseful for my purpose? My only goal is to configure a pin (whatever pin) as a fan to command my Water Cooling Kit. I'm using a Mosfet because I don't want to overload the board. The pump has 10W of power and there's a 80mm fan too...
@the_dragonlord You can use a step up converter from 3.3v to 5v
@the_dragonlord is the PS_ON pin free? All the pins on the expansion connector have 3.3V signal levels.
@dc42 said in "custom" fan doesn't work:
yes it is
@the_dragonlord you can connect the mosfet switch control input between VIN and PSON then.
I can't find that pin in the pinout image...where is it located? But is it customizable to work as a fan? Looking for the usable pin names for the Duet 2WiFi I don't see PSON, it looks to be available only for the Duet 3, is it?
@the_dragonlord I confirm that "pson" is a supported pin name on Duet 2. It is not PWM-capable. You will find it on the external 5V connector.
Uh yes, found it! So can I use:
M950 F10 C"pson"
M106 P10 S1 H1:2 T50 ; set fan 1 value. Thermostatic control is turned onto make it work? is it pson or ps_on in case?
@the_dragonlord both "pson" and "ps_on" should work.
it works like a charm!!!!
Thanks a lot! @dc42
