    Z offset resets on every print or Homing and start gcode asking
    start gcode z offset babystepping gcode config homeall
    2.8k
    • EEngineerundefined
      EEngineer
      Hello all,
      I am familiar with marlin but I chose DUET and RRF for my newly built IDEX.
      I have a strange problem where I use a macro to set the Z offset. I set it easily and then the Z0 position is fine until I start a print or home my axes. No matter what it changes back to old Z0 and can't even babystep down to the proper position.
      G90                                                ; send absolute coordinates...
      M83                                                ; ...but relative extruder moves
      M550 P"Printer"                         ; set printer name
      M552 S1 								; IP HERE
      M586 P0 S1					   					   ; Enable HTTP
      M586 P1 S0				           				   ; Disable FTP
      M586 P2 S0					  					   ; Disable Telnet
      M569 P0.0 S0                                         ; physical drive 0.0 goes forwards E0
      M569 P0.1 S0                                         ; physical drive 0.1 goes forwards E1
      M569 P0.2 S0                                         ; physical drive 0.2 goes forwards  X1
      M569 P0.3 S0                                         ; physical drive 0.3 goes forwards X2 (U)
      M569 P0.4 S0                                         ; physical drive 0.4 goes forwards Y
      M569 P0.5 S1                                         ; physical drive 0.5 goes forwards Z
      M569 P0.6 S1                                         ; physical drive 0.6 goes forwards Z
      M584 X0.2 Y0.4 Z0.5:0.6 U0.3 E0.0:0.1                              ; set drive mapping
      M671 X-30:330 Y150:150 S2; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      M208 X0:235 Y0:300 ; X carriage moves from 0 to 235, Y bed goes from 0 to 300
      M350 X16 Y16 Z16 U16 E16 I1                        ; configure microstepping with interpolation
      M92 X80 Y80 Z400 U80 E415:415                         ; set steps per mm
      M203 X12000 Y12000 Z6000 U12000 E5600:5600             ; set maximum speeds (mm/min)
      M201 X900 Y750 Z100 U900 E10000:10000                    ; set accelerations (mm/s^2)
      M566 X800 Y650 Z60 U8000 E1300:1300                     ; set maximum instantaneous speed changes (mm/min)
      M906 X1000 Y1000 Z800 U1000 E850:850 I50              ; set motor currents (mA) and motor idle factor in per cent
      M84 E0.0:0.1 X0.2 Y0.4 U0.3 S30                                            ; Set idle timeout
      M208 X0 Y0 Z-2.50 U65 S1  ; set axis lower limits
      M208 X235 Y310 Z300 U300 S0   ; set axis upper limits
      M574 X1 P"!io0.in" S1		  				       ; active-low endstop for low end on X via pin io0.in
      M574 Y1 P"!io1.in" S1		  					   ; active-low endstop for low end on Y via pin io1.in
      M574 U2 P"!io2.in" S1							   ; Use an endstop on U, stop at high end
      ; Z-Probe BLTouch
      M950 S0 C"io3.out"                           ; create servo pin 0 for BLTouch
      M558 P9 C"^io3.in" H10 F480 T12000 A5         ; set Z probe type to bltouch and the dive height + speeds
      G31 P25 X-29.75 Y-14.50 Z2.2                ; set Z probe trigger value, offset and trigger height
      M557 X40:180 Y40:260 S40 ; probe from X=10 to 190, Y=10 to 190mm with a mesh spacing of 20mm
      M308 S0 P"temp2" Y"thermistor" A"Bed" T100000 B3950             ; configure sensor 0 as thermistor on pin temp2
      M950 H0 C"out0" T0                                 				; create bed heater output on out0 and map it to sensor 0
      M140 H0   														; map heated bed to heater 0
      M143 H0 S120
      M307 H0 S1.00 B0                                       				; set temperature limit for heater 0 to 120C
      M307 H0 A124.0 C184.6 D2.5 S1.00 B0						; disable bang-bang mode for heater
      M308 S1 P"temp0" Y"thermistor" A"Hotend" T100000 B4450 C7.06e-8         ; configure sensor 1 as thermistor on pin temp0
      M950 H1 C"out1" T1                                 							  ; create nozzle heater output on out1 and map it to sensor 1
      M143 H1 S290
      M307 H1 S1.00 B0                                      		 					  ; set temperature limit for heater 1 to 290C
      M307 H1 A286.0 C164.4 D2.9 S1.00 V24.0 B0		         					  ; disable bang-bang mode for heater  and set PWM limit
      M308 S2 P"temp1" Y"thermistor" A"Hotend2" T100000 B4450 C7.06e-8            ; configure sensor 1 as thermistor on pin temp1
      M950 H2 C"out2" T2                                 							  ; create nozzle heater output on out3 and map it to sensor 2
      M143 H2 S290
      M307 H2 S1.00 B0                                      		 					  ; set temperature limit for heater 1 to 290C
      M307 H2 A286.0 C164.4 D2.9 S1.00 V24.0 B0		         					  ; disable bang-bang mode for heater  and set PWM limit
      M950 F0 C"out3" Q500                               ; create fan 0 on pin out3 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out4" Q500                               ; create fan 1 on pin out4 and set its frequency
      M106 P1 S0 H1 T50                                ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"out5" Q500                               ; create fan 2 on pin out5 and set its frequency
      M106 P2 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F3 C"out6" Q500                               ; create fan 1 on pin out6 and set its frequency
      M106 P3 S0 H2 T50                                  ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1 X0.2 F0 S"X"						; Tool0 uses Extruder0, Heater1 and Fan0
      G10 P0 X0 Y0 Z0 R0 S0								; Set Tool0 axis offsets and temperatures
      M563 P1 D1 H2 X0.3 F2 S"U"						; Tool1 uses Extruder1, Heater2 and Fan2. X-axis is mapped to U
      G10 P1 X0 Y0 Z0 R0 S0								; Set Tool1 axis offsets and temperatures
      ;  Create a tool that prints 2 copies of the object using both carriages
      M563 P2 D0:1 H1:2 X0.2:0.3 F0:2 S"copy" ; tool 2 uses both extruders, hot end heaters and fans, and maps X to both X and U
      G10 P2 X107 Y0 U-77 S0 R0 ; set tool offsets and temperatures G10 P2 X115 Y0 U-80 S0 R0///G10 P2 X100 Y0 U-100 S0 R0
      M567 P2 E1:1 ; set mix ratio 100% on both extruders
      M563 P3 D0:1 H1:2 X0.2:0.3 F0:2 S"mirror" ; tool 2 uses both extruders, hot end heaters and fans, and maps X to both X and U
      G10 P3 X107 Y0 U-30 S0 R0 ; set tool offsets and temperatures TO CONFIG
      M567 P3 E1:1 ; set mix ratio 100% on both extruders
      ; Miscellaneous - Power Down! RECOVERY
      M911 S23 R24 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"  ; set voltage thresholds and actions to run on power loss
      M404 N1.75											; Define filament diameter for print monitor
      M575 P1 S1 B57600
      M308 S20 Y"mcu-temp" A"CPU" 				; CPU temp sensor
      M308 S21 Y"drivers" A"Duet_drv" 			; drivers temp sensor
      M308 S4 Y"drivers" A"TMC Drivers"			; Define Sensor4 as the TMC overheat sensor
      T0											; Activate T0 by default
      ;M501
      ; homeall.g
      ; Called to home all axes
      ; BLTouch preperation
      M280 P0 S160												; Precautionary alarm release
      M280 P0 S90													; Ensure the pin is raised
      ; Home X, Y and U simultaneously
      G91															; Relative positioning
      G1 Z5 F4000 H2												; Lift Z relative to current position
      G1 X-999 Y-999 U999 F4000 H1								; Move Y-axis to the endstop and stop (first pass)
      G1 X5 Y5 U-5 F300											; Go back a few mm
      G1 X-999 Y-999 U999 F300 H1; Move Y-axis to the endstop once more (second pass)
      G90															; Absolute positioning
      ; Home Z using the Z-Probe
      T0 P0														; Ensure we are on Tool0 which carries the Z-Probe (P0 skips tool files)													; Reset baby-stepping to 0
      G1 X230.00 Y150.00 F4000									; Move T0 to probing point (X150, Y150), including probe offset
      G30															; Probe the bed and set Z to the probe offset
      G1 X100 Y100 Z50 F4000
      I am curious, what can it be..
      I also would like to ask for some specific things that what should I include in my starting G-code? Now its only consist of homing and some small movements, nothing special.
      Could someone help a newbie there?
      Thanks in advance.
      fcwiltundefined peter247undefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @EEngineer
        @eengineer
        You say you use a macro to set the Z offset.
        What Z offset are you talking about?
        How does the macro work?
        • peter247undefined
          peter247 @EEngineer
          @eengineer I'm a little lost what you are asking ?.
          You have a bltouch which should set the same z offset with a differing bed height etc , so if you rehome you should get the same offset from the nozzle to the bed.
          BUT you will find that using baby-stepping you can 't go lower that zero Z.
          Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
            EEngineer
            @fcwilt
            The Z-Offset between the nozzle and the bed which I would like to set with a BLtouch
            @peter247
            Sorry for the misunderstanding.
            Yes I have, and I can set it. Then I re-home, or start a print and the Z-offset changes back to some other value. Like it got a new Z0, thats why I cant babystep down more I think. So when I start a new print it only prints in the air well above the bed and in DWC it says its on Z0.3 on first layer.
            peter247undefined 1 Reply Last reply Reply Quote 0
            • peter247undefined
              peter247 @EEngineer
              @eengineer and the Z-offset changes back to some other value
              Does it show a different value on the screen or are you guessing ?
              Have you tried a homing paper test ?
              Which is in the centre of the bed , home and baby step down until a bit of paper grips the nozzle .
              if it doesn't grip the paper than you need the change the offset in G31
              EEngineerundefined 1 Reply Last reply Reply Quote 0
                EEngineer @peter247
                @peter247
                It doesn't show value but I guess if after a G30 probing it stays well above the bed then the Z0 has changed.
                That's what I am doing in the Z-Offset macro yes. Babystepping down. Then it saves the Z0 until re-home or print start.
                • peter247undefined
                  peter247 @EEngineer
                  @eengineer What would do and how I do mine is :
                  Change your G31 P25 X-29.75 Y-14.50 Z2.2 and reduces the Z offset by say 0.5mm ( or more ) Z 1.7 and babystep down until it grips the paper , which it should just touch at 0.1mm and grip hard at zero.
                  Now if it grips the paper at 0.3mm just increase Z offset value by 0.2mm and try again.
                  YOU NEED TO LOWER THE G31 Z value and reboot.
                    EEngineer @peter247
                    @peter247
                    I have tried so many ways now. In the beginning it was Z0.0 in G31.
                    I have to babystep down, usually it grips in -2.1.
                    But I will have a try again..
                    • peter247undefined
                      peter247 @EEngineer
                      @eengineer
                      Have you any adjustment on the bltouch to move it down ?
                      Wow -2.1mm that must mean that the nozzle is almost hitting the bed when the probe retracts ?
                        EEngineer @peter247
                        @peter247
                        The Z offset between the nozzle and BLTouch is at about 3mm
                        I don't know if it means this, but it is not near to hit the bed when it retracts
                        peter247undefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                        • peter247undefined
                          peter247 @EEngineer
                          @eengineer said in Z offset resets on every print or Homing and start gcode asking:
                          Not sure what you mean , is that on the screen or the distance between the nozzle and the bed which you have measured AND 3mm when ?
                          just thinking I'm wrong the probe to too few down !!!!
                            EEngineer @peter247
                            @peter247
                            About 3mm Between the tip of the nozzle and the tip of the BLtouch. Thats what you define in G31, isn't it? Thats why it is off with X-29.75 and Y-14.5. Z-probe position from the nozzle's point of view.
                            • fcwiltundefined
                              fcwilt @EEngineer
                              @peter247
                              Are you referring to some distance between the nozzle and the BLTouch?
                              If so, why are you concerned with that?
                              The only thing of importance is the BLTouch Z Trigger Height setting in G31.
                              How are you determining that value?
                              • peter247undefined
                                peter247 @EEngineer
                                @eengineer
                                if you set it to -2mm so it grip the paper how close is it to hitting the retracted probe ?
                                I can see now your bltouch is closer to the bed when it touches than mine, but your -2.1mm says not.
                                something is wrong I can't work it out !!!
                                  EEngineer @fcwilt
                                  @fcwilt
                                  Now I set my Z Trigger height in G31 according to this:
                                  https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                                  After that my print start has began on the right Z height.. Thanks for the advices. As I see now, that was my problem..
                                  My other question is, what do you think, what should I include in my start or maybe end g-code on an idex.
                                  Is there something special for RRF that I should include in these?
                                  • fcwiltundefined
                                    fcwilt @EEngineer
                                    @fcwilt
                                    I have no idea as I do not have a printer like that.
                                    But someone here is sure to have ideas.
                                      EEngineer @fcwilt
                                      @fcwilt
                                      I think I read somewhere that I should use relative extrusion. is it right? Then I should include in the start g-code
                                      peter247undefined fcwiltundefined 2 Replies Last reply Reply Quote 1
                                      • peter247undefined
                                        peter247 @EEngineer
                                        @eengineer it should be in your config.g file
                                        M83 ; but relative extruder moves.
                                        but you have to tell the slicer to use relative extruder too.
                                        in cura it is in special modes
                                        • fcwiltundefined
                                          fcwilt @EEngineer
                                          @fcwilt
                                          I make use of the slicer feature where you can enter you own code for print start and print end.
                                          I only enter M98 P"print_being.g" and M98 P"print_end.g"
                                          Everything I want to do is in those files BUT the slicer generates a bit of it's own code and the relationship of that code to the call to my code varies with the slicer and the slicer configuration.
                                          Here is some relevant info:
                                          ; S3D inserts the following before the call to print_beg.g
                                          ;G90                    ; absolute XYZ moves
                                          ;M83                    ; relative E   moves
                                          ;M106 S0                ; fan on to 0 (correct way to do fan off)
                                          ;M140 S60		; set bed      temp but don't wait
                                          ;M104 S190 T0		; set extruder temp but don't wait
                                          ;M98 P"print_begin.g"
                                          ; Cura (Repetier flavor - no temps) inserts the following around the call to print_beg.g
                                          ;M109 S0                        ; set extruder temp and wait (no wait with S0)
                                          ;M82                            ; absolute E moves
                                          ;G92 E0                         ; set E position
                                          ;G92 E0                         ; set E position again (have no idea why)
                                          ;G1 F1800 E-1                   ; do initial retract
                                          ; PrusaSlicer (RepRapflavor - no temps) inserts the following around the call to print_beg.g
                                          ;M107                           ; fan off (should be M106 S0)
                                          ;G21                            ; set units to millimeters
                                            EEngineer @fcwilt
                                            @fcwilt
                                            This is very convenient, thank you for the tip.
                                            I had a few succesful print since I made the Z-offset correctly.
