    Z offset resets on every print or Homing and start gcode asking
    start gcode z offset babystepping gcode config homeall
    3.1k
    • peter247undefined
      peter247 @EEngineer
      @eengineer and the Z-offset changes back to some other value
      Does it show a different value on the screen or are you guessing ?
      in the air well above the bed and in DWC it says its on Z0.3 on first layer.
      Have you tried a homing paper test ?
      Which is in the centre of the bed , home and baby step down until a bit of paper grips the nozzle .
      if it doesn't grip the paper than you need the change the offset in G31
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
      EEngineerundefined 1 Reply Last reply Reply Quote 0
      • EEngineerundefined
        EEngineer @peter247
        @peter247
        It doesn't show value but I guess if after a G30 probing it stays well above the bed then the Z0 has changed.
        That's what I am doing in the Z-Offset macro yes. Babystepping down. Then it saves the Z0 until re-home or print start.
        peter247undefined 1 Reply Last reply Reply Quote 0
        • peter247undefined
          peter247 @EEngineer
          @eengineer What would do and how I do mine is :
          Change your G31 P25 X-29.75 Y-14.50 Z2.2 and reduces the Z offset by say 0.5mm ( or more ) Z 1.7 and babystep down until it grips the paper , which it should just touch at 0.1mm and grip hard at zero.
          Now if it grips the paper at 0.3mm just increase Z offset value by 0.2mm and try again.
          YOU NEED TO LOWER THE G31 Z value and reboot.
            EEngineer @peter247
            @peter247
            I have tried so many ways now. In the beginning it was Z0.0 in G31.
            I have to babystep down, usually it grips in -2.1.
            But I will have a try again..
            • peter247undefined
              peter247 @EEngineer
              @eengineer
              Have you any adjustment on the bltouch to move it down ?
              Wow -2.1mm that must mean that the nozzle is almost hitting the bed when the probe retracts ?
                EEngineer @peter247
                @peter247
                The Z offset between the nozzle and BLTouch is at about 3mm
                I don't know if it means this, but it is not near to hit the bed when it retracts
                peter247undefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                • peter247undefined
                  peter247 @EEngineer
                  @eengineer said in Z offset resets on every print or Homing and start gcode asking:
                  Not sure what you mean , is that on the screen or the distance between the nozzle and the bed which you have measured AND 3mm when ?
                  just thinking I'm wrong the probe to too few down !!!!
                    EEngineer @peter247
                    @peter247
                    About 3mm Between the tip of the nozzle and the tip of the BLtouch. Thats what you define in G31, isn't it? Thats why it is off with X-29.75 and Y-14.5. Z-probe position from the nozzle's point of view.
                    • fcwiltundefined
                      fcwilt @EEngineer
                      @peter247
                      Are you referring to some distance between the nozzle and the BLTouch?
                      If so, why are you concerned with that?
                      The only thing of importance is the BLTouch Z Trigger Height setting in G31.
                      How are you determining that value?
                      • peter247undefined
                        peter247 @EEngineer
                        @eengineer
                        if you set it to -2mm so it grip the paper how close is it to hitting the retracted probe ?
                        I can see now your bltouch is closer to the bed when it touches than mine, but your -2.1mm says not.
                        something is wrong I can't work it out !!!
                          EEngineer @fcwilt
                          @fcwilt
                          Now I set my Z Trigger height in G31 according to this:
                          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                          After that my print start has began on the right Z height.. Thanks for the advices. As I see now, that was my problem..
                          My other question is, what do you think, what should I include in my start or maybe end g-code on an idex.
                          Is there something special for RRF that I should include in these?
                          • fcwiltundefined
                            fcwilt @EEngineer
                            @fcwilt
                            I have no idea as I do not have a printer like that.
                            But someone here is sure to have ideas.
                              EEngineer @fcwilt
                              @fcwilt
                              I think I read somewhere that I should use relative extrusion. is it right? Then I should include in the start g-code
                              peter247undefined fcwiltundefined 2 Replies Last reply Reply Quote 1
                              • peter247undefined
                                peter247 @EEngineer
                                @eengineer it should be in your config.g file
                                G90 ; send absolute coordinates.
                                M83 ; but relative extruder moves.
                                but you have to tell the slicer to use relative extruder too.
                                in cura it is in special modes
                                • fcwiltundefined
                                  fcwilt @EEngineer
                                  @fcwilt
                                  I make use of the slicer feature where you can enter you own code for print start and print end.
                                  I only enter M98 P"print_being.g" and M98 P"print_end.g"
                                  Everything I want to do is in those files BUT the slicer generates a bit of it's own code and the relationship of that code to the call to my code varies with the slicer and the slicer configuration.
                                  Here is some relevant info:
                                  ; S3D inserts the following before the call to print_beg.g
                                  ;G90                    ; absolute XYZ moves
                                  ;M83                    ; relative E   moves
                                  ;M106 S0                ; fan on to 0 (correct way to do fan off)
                                  ;M140 S60		; set bed      temp but don't wait
                                  ;M104 S190 T0		; set extruder temp but don't wait
                                  ;M98 P"print_begin.g"
                                  ; Cura (Repetier flavor - no temps) inserts the following around the call to print_beg.g
                                  ;M109 S0                        ; set extruder temp and wait (no wait with S0)
                                  ;M82                            ; absolute E moves
                                  ;G92 E0                         ; set E position
                                  ;G92 E0                         ; set E position again (have no idea why)
                                  ;G1 F1800 E-1                   ; do initial retract
                                  ; PrusaSlicer (RepRapflavor - no temps) inserts the following around the call to print_beg.g
                                  ;M107                           ; fan off (should be M106 S0)
                                  ;G21                            ; set units to millimeters
                                    EEngineer @fcwilt
                                    @fcwilt
                                    This is very convenient, thank you for the tip.
                                    I had a few succesful print since I made the Z-offset correctly.
