    Duet2 connection interrupted: Let's get to the bottom of this
    Duet Web Control
    12
    33
    1.8k
      This may possibly be related to https://forum.duet3d.com/topic/23701/mini-5-wifi-connection-unstable/34?_=1625331363732 which is being investigated.
      Nxt-1undefined 1 Reply Last reply Reply Quote 0
      • Nxt-1undefined
        Nxt-1 @dc42
        @dc42 said in Duet2 connection interrupted: Let's get to the bottom of this:
        You might very well be right, at least the symptoms described seems quite similar if not the exact same.
        Duet3D and delta printer enthousiast. Buildlog
        Looking for Duet3D configuration support, check out Nxt-3D
        • jens55undefined
          jens55
          I have the same issue (had it ever since the first Duet). Things will go just fine for the longest time then all of a sudden I get repeated interruptions. Then just like it started, the issue magically goes away.
          I was unable to make heads or tails out of it and eventually gave up. Now, if things act up, I go do something else 😞
          It is not related to signal strength.
          Latest episode happened yesterday. For about 5 minutes I was unable to reach the printer consistently and then all was fine again. I did not reboot anything tp make things work.
            dc42 administrators @jens55
            @jens55 said in Duet2 connection interrupted: Let's get to the bottom of this:
            Was microwave oven turned on for those 5 minutes by any chance?
              Phaedrux Moderator @Nxt-1
              @nxt-1 Would you be able to collect a wireshark trace?
              Nxt-1undefined 2 Replies Last reply Reply Quote 0
              • Nxt-1undefined
                Nxt-1 @Phaedrux
                @phaedrux said in Duet2 connection interrupted: Let's get to the bottom of this:
                Sure, whenever another episode happens I will capture it. I assume a trace with a filter for just the Duet IP will suffice?
                • chrishammundefined
                  chrishamm administrators @Nxt-1
                  @nxt-1 Yes, the part where the DWC loses connection to the Duet should suffice. In other interest there is now v1.26 with extra debugging available. If you want to give it a try and a connection drop occurs, please send M111 P14 S1 followed by M122 and share the full output here. It may help us further to isolate the underlying problem.
                  Duet software engineer
                  • jens55undefined
                    jens55 @dc42
                    No
                    • Nxt-1undefined
                      Nxt-1 @Phaedrux
                      1.pcapng.c
                      2.pcapng.c
                      3FullDataset.pcapng.c
                      Here you go, the .c extension needs to be removed abviously, the forum doesn't allow from .pcapng files 🤷 The first two datasets were started when I notices warning popping up in dwc, so they are probabily missing the first pieces of vital information. The 3rd set contains everything from start to finish.
                      Note: all these traces were without the new v1.26 debug firmware as sugested by @chrishamm. I will install that now and report back.
                      • Nxt-1undefined
                        Nxt-1 @chrishamm
                        @chrishamm said in Duet2 connection interrupted: Let's get to the bottom of this:
                        As requested: as soon as a connection interupted warning poped, I did a M11 P14 S1 followed by M122.
                        7/30/2021, 11:16:00 AM	M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.0 or 1.01
                        Board ID: 08D6M-91AST-L23S4-7JTD0-3S86K-1NX1K
                        Used output buffers: 3 of 24 (24 max)
                        Static ram: 23876
                        Dynamic ram: 74668 of which 24 recycled
                        Never used RAM 15848, free system stack 94 words
                        Tasks: NETWORK(ready,91.8%,143) HEAT(delaying,0.9%,330) Move(notifyWait,2.4%,301) MAIN(running,4.5%,128) IDLE(ready,0.4%,29), total 100.0%
                        Owned mutexes: WiFi(NETWORK)
                        Last reset 116:49:31 ago, cause: power up
                        Last software reset at 2021-07-25 14:11, reason: User, GCodes spinning, available RAM 15848, slot 2
                        Error status: 0x14
                        Aux0 errors 0,0,0
                        Step timer max interval 0
                        MCU temperature: min 30.9, current 36.0, max 36.9
                        Supply voltage: min 24.1, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                        Driver 0: position 91505, standstill, SG min/max not available
                        Driver 1: position 73958, standstill, SG min/max not available
                        Driver 2: position 73795, standstill, SG min/max not available
                        Driver 3: position 0, standstill, SG min/max not available
                        Driver 4: position 0, standstill, SG min/max not available
                        Driver 5: position 0
                        Driver 6: position 0
                        Driver 7: position 0
                        Driver 8: position 0
                        Driver 9: position 0
                        Driver 10: position 0
                        Driver 11: position 0
                        Date/time: 2021-07-30 11:15:41
                        Slowest loop: 88.64ms; fastest: 0.15ms
                        === Storage ===
                        Free file entries: 10
                        SD card longest read time 1.5ms, write time 87.0ms, max retries 0
                        DMs created 83, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
                        === MainDDARing ===
                        Scheduled moves 68595, completed moves 68595, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                        === AuxDDARing ===
                        Segments left: 0
                        Movement lock held by null
                        HTTP is idle in state(s) 0
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Trigger is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Code queue is empty.
                        === Network ===
                        Slowest loop: 1927.81ms; fastest: 0.00ms
                        HTTP sessions: 1 of 8
                        - WiFi -
                        Network state is active
                        WiFi firmware version 1.26-D
                        WiFi MAC address a0:20:a6:16:ec:ed
                        WiFi Vcc 3.36, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 24360
                        WiFi IP address 192.168.178.30
                        WiFi signal strength -50dBm, mode 802.11n, reconnections 0, sleep mode modem
                        Clock register 00002002
                        7/30/2021, 11:15:47 AM	M111 P14 S1
                        Debugging enabled for modules: WiFi(14 - 0xffffffff)
                        Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15) LinuxInterface(16) CAN(17)
                        7/30/2021, 11:15:36 AM	Connection established
                        7/30/2021, 11:15:31 AM	Connection interrupted, attempting to reconnect...
                        HTTP request timed out
                        EDIT: After a few more disconnects, another M122 incase it is useful
                        M122
                        Static ram: 23876
                        Tasks: NETWORK(ready,13.8%,143) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,301) MAIN(running,86.1%,128) IDLE(ready,0.0%,29), total 100.0%
                        Last reset 117:01:45 ago, cause: power up
                        Error status: 0x14
                        Aux0 errors 0,0,0
                        MCU temperature: min 35.6, current 36.3, max 37.0
                        Date/time: 2021-07-30 11:27:55
                        Slowest loop: 5.81ms; fastest: 0.17ms
                        === Storage ===
                        SD card longest read time 1.3ms, write time 0.0ms, max retries 0
                        === MainDDARing ===
                        === AuxDDARing ===
                        Segments left: 0
                        === Network ===
                        Slowest loop: 203.84ms; fastest: 0.08ms
                        - WiFi -
                        Failed messages: pending 0, notready 0, noresp 1
                        WiFi signal strength -51dBm, mode 802.11n, reconnections 0, sleep mode modem
                        chrishammundefined 1 Reply Last reply Reply Quote 1
                          @nxt-1 I'm sorry I forgot to mention it but I'll need the M122 output from a USB console, else the useful stats from the debug build aren't printed. I'll have a look at your Wireshark dumps nevertheless.
                          PS: Your Wireshark dumps show that the WiFi module sometimes doesn't seem to receive incoming packets. I suspect we could confirm this by looking at the LWIP stats reported over USB.
                          • Nxt-1undefined
                            Nxt-1 @chrishamm
                            @chrishamm
                            Here you go, two more M122 dumps, taken from my laptop connected via USB.
                            M122<CR>
                            Used output buffers: 1 of 24 (20 max)
                            Static ram: 23876
                            Never used RAM 15848, free system stack 134 words
                            Tasks: NETWORK(ready,78.8%,244) HEAT(delaying,0.6%,330) Move(notifyWait,1.5%,303) MAIN(running,18.9%,443) IDLE(ready,0.2%,29), total 100.0%
                            Owned mutexes: WiFi(NETWORK) USB(MAIN)
                            Last reset 13:24:33 ago, cause: software
                            Last software reset at 2021-07-31 22:17, reason: User, GCodes spinning, available RAM 15848, slot 0
                            Error status: 0x00
                            Aux0 errors 0,0,0
                            MCU temperature: min 29.4, current 29.7, max 42.3
                            Supply voltage: min 23.8, current 24.2, max 25.0, under voltage events: 0, over voltage events: 0, power good: yes
                            Driver 0: position 195079, standstill, SG min/max 0/447
                            Driver 1: position 195010, standstill, SG min/max 0/464
                            Driver 2: position 194953, standstill, SG min/max not available
                            Driver 3: position 0, standstill, SG min/max 0/479
                            Date/time: 2021-08-01 11:41:44
                            Slowest loop: 6.87ms; fastest: 0.17ms
                            === Storage ===
                            DMs created 83, maxWait 44916359ms, bed compensation in use: none, comp offset 0.000
                            === MainDDARing ===
                            Scheduled moves 4, completed moves 4, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                            === AuxDDARing ===
                            Heater 1 is on, I-accum = 0.0
                            Segments left: 0
                            USB is ready with "M122" in state(s) 0
                            === Network ===
                            Slowest loop: 17.09ms; fastest: 0.00ms
                            - WiFi -
                            WiFi flash size 4194304, free heap 22944
                            WiFi signal strength -52dBm, mode 802.11n, reconnections 0, sleep mode modem
                            ok
                            WiFi: Conns: 0:closePending 80, 59705, 192.168.178.27, 1:free, 2:free, 3:free, 4:free, 5:free, 6:free, 7:free
                            WiFi: IP xmit: 44326 recv: 9906 fw: 0 drop: 848 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 0 opterr: 0 err: 0 cachehit: 0
                            WiFi: TCP xmit: 62257 recv: 24835 fw: 0 drop: 95 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 95 opterr: 0 err: 0 cachehit: 22789
                            WiFi: MEM UDP_PCB avail: 6 used: 4 max: 4 err: 0
                            WiFi: MEM TCP_PCB avail: 8 used: 1 max: 8 err: 0
                            WiFi: MEM TCP_PCB_LISTEN avail: 4 used: 1 max: 1 err: 0
                            WiFi: MEM TCP_SEG avail: 16 u<DEL>MEM PBUF_REF/ROM avail: 10 used: 0 max: 0 err: 0
                            WiFi: MEM PBUF_POOL avail: 4 used: 0 max: 0 err: 0
                            M122
                            Static ram: 23876
                            Tasks: NETWORK(ready,14.2%,243) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,303) MAIN(running,85.6%,423) IDLE(ready,0.0%,29), total 100.0%
                            Last reset 13:39:20 ago, cause: software
                            Error status: 0x00
                            Aux0 errors 0,0,0
                            MCU temperature: min 29.4, current 30.1, max 30.8
                            Driver 0: position 195079, standstill, SG min/max not available
                            Driver 1: position 195010, standstill, SG min/max not available
                            Date/time: 2021-08-01 11:56:31
                            Slowest loop: 14.32ms; fastest: 0.17ms
                            === Storage ===
                            === MainDDARing ===
                            === AuxDDARing ===
                            Segments left: 0
                            === Network ===
                            Slowest loop: 200.67ms; fastest: 0.08ms
                            - WiFi -
                            WiFi flash size 4194304, free heap 26096
                            WiFi signal strength -54dBm, mode 802.11n, reconnections 0, sleep mode modem
                            ok
                            WiFi: Conns: 0:free, 1:free, 2:free, 3:free, 4:free, 5:free, 6:free, 7:free
                            WiFi: IP xmit: 57117 recv: 25483 fw: 0 drop: 864 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 0 opterr: 0 err: 0 cachehit: 0
                            WiFi: TCP xmit: 7106 recv: 39465 fw: 0 drop: 95 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 95 opterr: 0 err: 0 cachehit: 36781
                            WiFi: MEM TCP_PCB avail: 8 used: 4 max: 8 err: 0
                            WiFi: MEM TCP_SEG avail: 16 used: 0 max: 14 err: 0
                            WiFi: MEM ARP_QUEU<DEL>MEM PBUF_REF/ROM avail: 10 used: 0 max: 0 err: 0
                            ajdtreydundefined 1 Reply Last reply Reply Quote 0
                            • ajdtreydundefined
                              ajdtreyd @Nxt-1
                              @Nxt-1
                              I wonder if this might be a DHCP issue. Is your Duet configured for DHCP or static IP address? If DHCP, try configuring it with a static IP (that is outside the DHCP lease list range). Aternatively, try changing the lease period expiration on the DHCP server (probably the router) to zero (or whatever = never).
                              • Nxt-1undefined
                                Nxt-1 @ajdtreyd
                                @ajdtreyd Man I would have never guessed to look in that direct, good thinking on your part. Although I must admit I have never known DHCP to cause intermittent issues. And I doubt it is the case here. My Duet is indeed in DHCP mode, with a preferred IP set at the DHCP-server (the router in my case), with a default lease time of 10 days. To give some perspective, the issues I described happend multiple times a day, variying amounts but I'd guestimate around 10-15 times/day.
                                I will try if setting a proper static ip will make any difference just to be sure.
                                • Nxt-1undefined
                                  Nxt-1 @ajdtreyd
                                  @ajdtreyd As promissed, I just tried with a static ip. No change sadly. One more thing to cross off the list I guess 🙂
                                  • jens55undefined
                                    jens55
                                    Another interesting and possibly related experience:
                                    Most of yesterday, I had substantial problems downloading files from Cura to my Duet2wifi. When you select to print via Cura, it asks you to confirm the file name and then you see a progress window for the download. Most of the time this goes very fast. Well, yesterday the progress would go in little chunks. Maybe 2% at a time, sometimes more, sometimes less, sometimes it would just sit there for a second or ten before moving again.
                                    To me this looks like interference of some kind but short of a spectrum analyser, I have no means of tracing the problem. I am 99.9999% sure this has nothing to do with anything in my household but I have no idea what kind of crap comes in from the outside. I am not sure how the neigborhood would react to me wrapping the house in aluminum foil but I suspect they would not be pleased.
                                    Today it is business as usual with a very fast file transfer.
                                    The funny thing is that the printer is in the basement, thick concrete walls and what not so presumably a substantial amount of reduction in any interfering signals. The network access point is about 30 feet away but I have had it sitting right next to the printer with no difference in the issue.
                                    Nxt-1undefined 1 Reply Last reply Reply Quote 1
                                    • Nxt-1undefined
                                      Nxt-1 @jens55
                                      @jens55 I feel you, I can't really justify one but I'd love to have capable spectrum analyzer as well. My 200MHz scope fft isn't going to cut it when looking for 2,4 GHz noise 🙂 . Although I must admit that I doubt this an interference issue, seeing how constant it is. My connection issues happen 24/7 for random lengths of time. Also, and I did have them before I moved as well, eliminating some HAM neighbour going wild on the spectrum 🙂
                                      @chrishamm or @Phaedrux Did you manage to figure out anything from the wireshark traces / debug dumps?
                                        I'm not sure if @chrishamm has had a chance to view your debug dumps yet.
                                        How handy are you with a soldering iron? Handy enough to replace the wifi module confidently?
                                        • Nxt-1undefined
                                          Nxt-1 @Phaedrux
                                          I do some sodering every now and then and do have a hot air station available as well. I believe I should be able to get it off.
                                          • ajdtreydundefined
                                            ajdtreyd @Nxt-1
                                            @nxt-1
                                            One more question/suggestion; Have you tried reflashing the wifi module ( M997 S1 )?
                                            Back when 3.3 was in pre-release I was doing a bit of version hopping and occasionally the wifi module would give me some erratic connection problems. Sometimes it would take a couple of poweroff/on-flash-poweroff/on cycles to get the wifi stable again, but this has worked for me. Dunno if that will do the trick, but it takes about 5min and no soldering skills to try.
