    Duet 2 Wifi + Bltouch
    Firmware installation
    398
    • Btjundefined
      Btj
      Hi I have a problem with Bltouchen I can not get it to work!
      Uses heater 3
      Has an Ender 5 Plus with Micro swiss direct drive and bltouch X-50 Y-11.02 Z0
      Anyone that can help me ?
      min Confi fil
      ; generated by RepRapFirmware Configuration Tool v3.2.2 on Wed Feb 03 2021 12:12:49 GMT-0500 (Eastern Standard Time)
      M550 P"Ender 5 Plus" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P2 S0 ; physical drive 2 goes backwards
      M92 X80.00 Y80.00 Z800.00 E156.47 ; set steps per mm
      M566 X900.00 Y900.00 Z80.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z30.00 E250.00 ; set accelerations (mm/s^2)
      M84 S30 ; Set idle timeout
      M208 X350 Y350 Z400 S0 ; set axis maxima
      M574 X1 Y1 S1 ; X home to min. Y home to max. NC microswitches.
      M574 Z1 S2 ; Define Z to use Probe. Home to Min.
      M558 P9 C"^zprobe.in" H5 F100 T2000
      G31 X0 Y0 Z 0 P25
      M307 H3 A-1 C-1 D-1
      M558 P9 C"^zprobe.in" H5 F120 T7200
      G31 P500 X35 Y4 Z2.1
      M950 S0 C"duex.pwm1" ; disable Z probe but set dive height, probe speed and travel speed
      G31 X0 Y0 Z0 P25
      M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
      • chrishammundefined
        chrishamm administrators @Btj
        @btj Try something like this:
        config.g
        M950 S0 C"duex.pwm1"                         ; create servo pin 0 for BLTouch
        M558 P9 C"^zprobe.in" H5 F120 T12000           ; set Z probe type to bltouch and the dive height + speeds
        G31 P500 X-50 Y-11.02                     ; set Z probe trigger value, offset and trigger height
        deployprobe.g
        M280 P0 S10 ; deploy BLTouch
        retractprobe.g
        M280 P0 S90 ; retract BLTouch
        If anything else isn't right, please explain what does not work.
        Duet software engineer
        Btjundefined 1 Reply Last reply Reply Quote 0
        • Btjundefined
          Btj @chrishamm
          @chrishamm
          Gets this Wrong message
          M280 P0 S10
          Error: M280: Invalid servo index 0 in M280 command
            @btj What do you get when you run M950 S0 C"duex.pwm1"?
            • Btjundefined
              Btj @chrishamm
              @chrishamm said in Duet 2 Wifi + Bltouch:
              M950 S0 C"duex.pwm1
              M950 S0 C"duex.pwm1
              Warning: M950 command is not supported
              chrishammundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                @btj It sounds like you are still using RRF2, so it may be a good idea to upgrade to RRF3. If you don't want to upgrade, see https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_Duet_2_WiFi_Ethernet_running_RepRapFirmware_Num_2 for further instructions.
                  droftarts administrators @Btj
                  @btj Your config.g is a mix of commands for RepRapFirmware 2 and RepRapFirmware 3. Please send M115 and post response, so we can see what firmware version you are running. Then we can best advise you on the correct commands.
                  • Btjundefined
                    Btj @droftarts
                    @droftarts
                    M115
                    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
                      @btj said in Duet 2 Wifi + Bltouch:
                      If you're not planning on updating the firmware to the current version (v3.3, but see update instructions here: https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_from_RRF_2_x_to_3_x ), then it will be easiest to regenerate your configuration files using the Configuration tool https://configtool.reprapfirmware.org/Start
                      This is because you have generated a configuration for RRF 3, see first line of your config.g:
                      I expect currently none of your temperature responses will be correct, fans won't work, and there will be no tool, as well as the probe not working. All the lines in config.g that have C or P parameter with "[something in quotes]" will need to change, so it's easier to regenerate the files with the correct firmware version selected. On the https://configtool.reprapfirmware.org/General page, under "Firmware version:" make sure you select "2.03 to 2.05".
                      If you want to update to RRF v3.3, your existing config should work, but you need to tidy up your Z-probe configuration. See @chrishamm's post earlier.
                      • Btjundefined
                        Btj @droftarts
                        @droftarts
                        M115
                        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-01-03b3
                          Now update to RRF v3.3. https://github.com/Duet3D/RepRapFirmware/releases/tag/3.3
                          • Btjundefined
                            Btj @droftarts
                            @droftarts
                            M115
                            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-06-15 21:45:03
                              @btj Have you made any changes to your config.g? If so, please post your current config.g.
                              From your earlier config.g, you will need to change your Endstop and Z-Probe sections. They should look something like this:
                              M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
                              M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
                              M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
                              M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
                              G31 P500 X0 Y0 Z2.5                            ; set Z probe trigger value, offset and trigger height
                              Remove these lines:
                              M574 Z[anything]
                              M307 H3 A-1 C-1 D-1
                              Any other M950, M558 and G31 lines
                              Then post your config.g so we can check it.
                              • Btjundefined
                                Btj @droftarts
                                @droftarts
                                M574 X1 S1 P"xstop" ; X min active high endstop switch
                                M574 Y1 S1 P"ystop" ; Y min active high endstop switch
                                M574 Z1 S1 P"zstop" ; Z min active high endstop switch
                                M574 U2 S1 P"e0stop" ; U max active high endstop switch
                                G31 X0 Y0 Z 0 P25
                                Z-Probe
                                M307 H3 A-1 C-1 D-1
                                G31 X-50 Y-11.02 Z 0 P25
                                  G31 X0 Y0 Z 0 P25
                                  Z-Probe
                                  M307 H3 A-1 C-1 D-1
                                  Remove:
                                  G31 X0 Y0 Z 0 P25
                                  M307 H3 A-1 C-1 D-1
