    Extruder E1 not working
    736
    • chrishammundefined
      chrishamm administrators @jackd2282
      @jackd2282 You don't assign the extruder to the first tool so that doesn't seem right. Change back to M563 P0 D0 H1 F0 ; define tool 0 and then rerun config.g as Phaedrux suggested.
      Duet software engineer
      jackd2282undefined 2 Replies Last reply Reply Quote 0
      • jackd2282undefined
        jackd2282 @Phaedrux
        @phaedrux on the expansion board if I can’t get this sorted is that an option instead of a new board?
          jackd2282 @chrishamm
          @chrishamm when I change to that it removes the hotend from the interface for some reason
            @chrishamm also that line is from the repeal config tool where I put the extruder to E1 as well as the hotend
            jackd2282undefined 1 Reply Last reply Reply Quote 0
              jackd2282 @jackd2282
              @jackd2282 reprap config
                @jackd2282 With the M584 code from your config.g you map driver 4 to extruder drive 0, so it should be possible to use M563 P0 D0 H1 F0 as well. If no tool shows up, rerunning config.g with M98 P"config.g" as suggested by Phaedrux will show why it does not work.
                  @chrishamm said in Extruder E1 not working:
                  M98 P"config.g"
                  I tried M563 P0 D0 H1 F0 and M563 P0 D0 H1 F1 because both were mentioned and while the tool interface now stays on both for the hot end and M98 P"config.g" showsM98 P"config.g"
                  HTTP is enabled on port 80
                  FTP is disabled
                  TELNET is disabled
                  when I heat up the hotend to 195c to get both extrusion and retraction buttons to become available i get Warning: motor phase A may be disconnected reported by driver(s) 4
                  Warning: motor phase B may be disconnected reported by driver(s) 4 with multiple
                  with multiple stepper motors
                    Can you send M122 and provide the results?
                    How did you "burn" driver 3?
                    Can you provide some photos of the board? Especially close ups of the drivers?
                      jackd2282 @Phaedrux
                      @phaedruxM122
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
                      Board ID: 08DLM-996RU-N85S4-7JKD2-3SN6K-1U97R
                      Used output buffers: 3 of 24 (23 max)
                      Static ram: 23876
                      Dynamic ram: 75020 of which 24 recycled
                      Never used RAM 15496, free system stack 184 words
                      Tasks: NETWORK(ready,6.0%,246) HEAT(delaying,0.0%,314) Move(notifyWait,0.1%,364) MAIN(running,93.9%,441) IDLE(ready,0.0%,29), total 100.0%
                      Owned mutexes: WiFi(NETWORK)
                      Last reset 00:01:42 ago, cause: software
                      Last software reset at 2021-08-03 14:09, reason: User, GCodes spinning, available RAM 15496, slot 2
                      Error status: 0x00
                      Step timer max interval 0
                      MCU temperature: min 23.4, current 24.5, max 24.8
                      Supply voltage: min 27.1, current 27.3, max 27.4, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 0: position 0, standstill, SG min/max not available
                      Driver 1: position 0, standstill, SG min/max not available
                      Driver 2: position 0, standstill, SG min/max not available
                      Driver 3: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
                      Driver 4: position 0, standstill, SG min/max not available
                      Driver 5: position 0
                      Driver 6: position 0
                      Driver 7: position 0
                      Driver 8: position 0
                      Driver 9: position 0
                      Driver 10: position 0
                      Driver 11: position 0
                      Date/time: 2021-08-03 14:10:58
                      Slowest loop: 7.65ms; fastest: 0.17ms
                      === Storage ===
                      Free file entries: 10
                      SD card longest read time 2.0ms, write time 0.0ms, max retries 0
                      === MainDDARing ===
                      === AuxDDARing ===
                      Segments left: 0
                      Movement lock held by null
                      HTTP is idle in state(s) 0
                      Telnet is idle in state(s) 0
                      File is idle in state(s) 0
                      USB is idle in state(s) 0
                      Aux is idle in state(s) 0
                      Trigger is idle in state(s) 0
                      Queue is idle in state(s) 0
                      LCD is idle in state(s) 0
                      Daemon is idle in state(s) 0
                      Code queue is empty.
                      === Network ===
                      Slowest loop: 202.62ms; fastest: 0.08ms
                      HTTP sessions: 1 of 8
                      • WiFi -
                        Network state is active
                        Failed messages: pending 0, notready 0, noresp 1
                        WiFi firmware version 1.26
                        WiFi MAC address 8c:aa:b5:c2:16:2b
                        WiFi Vcc 3.38, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 26952
                        WiFi IP address 192.168.1.140
                        WiFi signal strength -71dBm, mode 802.11n, reconnections 0, sleep mode modem
                        Clock register 00002002
                      jackd2282undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                        @jackd2282 I hooked up my new bondtech ddx and my guess is that the motor was wired wrong cause it got hot then the driver burned
                          Phaedrux Moderator @jackd2282
                          @jackd2282 said in Extruder E1 not working:
                          Driver 3 is definitely damaged.
                          And it sounds like you still have the motor wired incorrectly.
                          Carefully identify the motors phase pairs first before wiring them up again.
                          https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
                            jackd2282 @Phaedrux
                            @phaedrux I made sure the phases are right and tried all 4 combinations on the motor. No luck. Maybe E1 is also damaged?
                              Possibly, or the damage to driver 3 is also preventing driver 4 from working.
                              @phaedrux said in Extruder E1 not working:
                              Do you notice any damage or pock marks?
                                jackd2282 @Phaedrux
                                @phaedrux it was physically burned and not dremeled out
                                  @jackd2282 I don’t know why driver 4 would be affected though. It wasn’t even hooked up when this happened but back to my question on the expansion boards, would that bypass this problem?
                                    Well yes, if you added an expansion board like a Duex or external driver expansion board you could use the drivers on that as replacements. Just map the extruders to the new drivers with M584.
                                    I'm not sure, but I think if the damage was bad enough it may have damaged the SPI bus which could cut communication to further drivers down the line.
                                      jackd2282 @Phaedrux
                                      @phaedrux that would make sense why my xyz still work
                                      jackd2282undefined Phaedruxundefined 3 Replies Last reply Reply Quote 0
                                        @jackd2282 ordered the expansion board so will see when it comes in
                                          @jackd2282 ok so I am thinking that the expansion board may not work. It’s not here yet but I was taking for granted that my other drivers worked because they did before all this. But that’s not the case. None of them do. Same problem phase a and b. I tried just the z and modified the config.g to only include that drive and nothing. My board may be shot and that sucks cause I just bought that expansion board with next day shipping for nothing. None of them get warm. No errors unless I try to move a motor. I tried resetting the firmware on the board and card to just start over but no luck.
                                            Did they work before but not anymore?
