    Extruder E1 not working
    735
    • jackd2282undefined
      jackd2282 @jackd2282
      @jackd2282 ; Configuration file for Duet WiFi (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Aug 02 2021 02:19:39 GMT-0500 (Central Daylight Time)
      M550 P"My Printer" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P3 R-1 ; disable drive 3 and stop monitoring
      M569 P2 S0 ; physical drive 2 goes backwards
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X1 Y0 Z2 E4 ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E98.00 ; set steps per mm
      M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
      M906 X950 Y950 Z950 E700 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X250 Y250 Z400 S0 ; set axis maxima
      M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M308 S1 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e1temp
      M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
      M563 P0 H1 F0 ; define tool 0
        If it was just the driver that failed, you didn't need to change the heater bindings as well, but if you want to, that's fine, just remember to move the actual cable connections also.
        Your tool definition is missing the D0 to tell it to use the first defined extruder. I thnk this is the main problem. You should have M563 P0 D0 H1 F1
        jackd2282undefined 1 Reply Last reply Reply Quote 0
          jackd2282 @Phaedrux
          @phaedrux when I do that the hotend disappears from the ui
            @jackd2282 also I did move the cables and heat works fine
              Can you send M122 and M98 P"config.g" in the Gcode console in DWC and post the results?
              Can you confirm what version of DWC you are using as well?
              jackd2282undefined 2 Replies Last reply Reply Quote 0
                jackd2282 @Phaedrux
                @phaedrux I am at work till morning but I will then
                • chrishammundefined
                  chrishamm administrators @jackd2282
                  @jackd2282 You don't assign the extruder to the first tool so that doesn't seem right. Change back to M563 P0 D0 H1 F0 ; define tool 0 and then rerun config.g as Phaedrux suggested.
                  Duet software engineer
                    jackd2282 @Phaedrux
                    @phaedrux on the expansion board if I can’t get this sorted is that an option instead of a new board?
                      jackd2282 @chrishamm
                      @chrishamm when I change to that it removes the hotend from the interface for some reason
                        @chrishamm also that line is from the repeal config tool where I put the extruder to E1 as well as the hotend
                          @jackd2282 reprap config
                            @jackd2282 With the M584 code from your config.g you map driver 4 to extruder drive 0, so it should be possible to use M563 P0 D0 H1 F0 as well. If no tool shows up, rerunning config.g with M98 P"config.g" as suggested by Phaedrux will show why it does not work.
                              @chrishamm said in Extruder E1 not working:
                              M98 P"config.g"
                              I tried M563 P0 D0 H1 F0 and M563 P0 D0 H1 F1 because both were mentioned and while the tool interface now stays on both for the hot end and M98 P"config.g" showsM98 P"config.g"
                              HTTP is enabled on port 80
                              FTP is disabled
                              TELNET is disabled
                              when I heat up the hotend to 195c to get both extrusion and retraction buttons to become available i get Warning: motor phase A may be disconnected reported by driver(s) 4
                              Warning: motor phase B may be disconnected reported by driver(s) 4 with multiple
                              with multiple stepper motors
                                Can you send M122 and provide the results?
                                How did you "burn" driver 3?
                                Can you provide some photos of the board? Especially close ups of the drivers?
                                  jackd2282 @Phaedrux
                                  @phaedruxM122
                                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
                                  Board ID: 08DLM-996RU-N85S4-7JKD2-3SN6K-1U97R
                                  Used output buffers: 3 of 24 (23 max)
                                  Static ram: 23876
                                  Dynamic ram: 75020 of which 24 recycled
                                  Never used RAM 15496, free system stack 184 words
                                  Tasks: NETWORK(ready,6.0%,246) HEAT(delaying,0.0%,314) Move(notifyWait,0.1%,364) MAIN(running,93.9%,441) IDLE(ready,0.0%,29), total 100.0%
                                  Owned mutexes: WiFi(NETWORK)
                                  Last reset 00:01:42 ago, cause: software
                                  Last software reset at 2021-08-03 14:09, reason: User, GCodes spinning, available RAM 15496, slot 2
                                  Error status: 0x00
                                  Step timer max interval 0
                                  MCU temperature: min 23.4, current 24.5, max 24.8
                                  Supply voltage: min 27.1, current 27.3, max 27.4, under voltage events: 0, over voltage events: 0, power good: yes
                                  Driver 0: position 0, standstill, SG min/max not available
                                  Driver 1: position 0, standstill, SG min/max not available
                                  Driver 2: position 0, standstill, SG min/max not available
                                  Driver 3: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
                                  Driver 4: position 0, standstill, SG min/max not available
                                  Driver 5: position 0
                                  Driver 6: position 0
                                  Driver 7: position 0
                                  Driver 8: position 0
                                  Driver 9: position 0
                                  Driver 10: position 0
                                  Driver 11: position 0
                                  Date/time: 2021-08-03 14:10:58
                                  Slowest loop: 7.65ms; fastest: 0.17ms
                                  === Storage ===
                                  Free file entries: 10
                                  SD card longest read time 2.0ms, write time 0.0ms, max retries 0
                                  === MainDDARing ===
                                  === AuxDDARing ===
                                  Segments left: 0
                                  Movement lock held by null
                                  HTTP is idle in state(s) 0
                                  Telnet is idle in state(s) 0
                                  File is idle in state(s) 0
                                  USB is idle in state(s) 0
                                  Aux is idle in state(s) 0
                                  Trigger is idle in state(s) 0
                                  Queue is idle in state(s) 0
                                  LCD is idle in state(s) 0
                                  Daemon is idle in state(s) 0
                                  Code queue is empty.
                                  === Network ===
                                  Slowest loop: 202.62ms; fastest: 0.08ms
                                  HTTP sessions: 1 of 8
                                  • WiFi -
                                    Network state is active
                                    Failed messages: pending 0, notready 0, noresp 1
                                    WiFi firmware version 1.26
                                    WiFi MAC address 8c:aa:b5:c2:16:2b
                                    WiFi Vcc 3.38, reset reason Turned on by main processor
                                    WiFi flash size 4194304, free heap 26952
                                    WiFi IP address 192.168.1.140
                                    WiFi signal strength -71dBm, mode 802.11n, reconnections 0, sleep mode modem
                                    Clock register 00002002
                                  jackd2282undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                    @jackd2282 I hooked up my new bondtech ddx and my guess is that the motor was wired wrong cause it got hot then the driver burned
                                      Phaedrux Moderator @jackd2282
                                      @jackd2282 said in Extruder E1 not working:
                                      Driver 3 is definitely damaged.
                                      And it sounds like you still have the motor wired incorrectly.
                                      Carefully identify the motors phase pairs first before wiring them up again.
                                      https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
                                        jackd2282 @Phaedrux
                                        @phaedrux I made sure the phases are right and tried all 4 combinations on the motor. No luck. Maybe E1 is also damaged?
                                          Possibly, or the damage to driver 3 is also preventing driver 4 from working.
                                          @phaedrux said in Extruder E1 not working:
                                          Do you notice any damage or pock marks?
                                            jackd2282 @Phaedrux
                                            @phaedrux it was physically burned and not dremeled out
