    Crimping PH pins (1LC) - what is the trick
    316
    • jens55undefined
      jens55
      I am having lots of crimps fail on the PH style (small) crimp pins that come with the 1LC. Is there a trick to crimping these?
      Using a Engineer PA-09 crimper, I am using the second smallest (1.4 mm) die for the wire crimp and one size larger (1.6 mm) for the insulation crimp.
      Do you cut the wings of the insulation by a slight bit crimp to crimp better ?
        dc42 administrators @jens55
        @jens55 I use a PA09 too and I haven't had any problems crimping the wires to connect to tool board 1.1. I guess that if the wires are extremely thin then you might need to put tape or heatshrink on them to thicken the insulation, or cut the wings short as you suggest; but I have only needed to do this when crimping JST VH connectors.
        • jens55undefined
          jens55 @dc42
          @dc42, funny, I can crimp reliable VH crimps all day long. They are a nice size to handle. The JST PH ones, the really tiny guys are what I am having difficulty with.
          dc42undefined LordofCheeseundefined 2 Replies Last reply Reply Quote 0
            TBH I can't remember whether I used the PA09 or the PA21 to crimp the JST PH pins. They have different profiles.
            • LordofCheeseundefined
              LordofCheese @jens55
              @jens55 same problem here. It's very difficult... the PH Crimps are way better
              It's a small board but maybe it would be better to use a slightly bigger board with bigger contacts...
              It will also be better for me and my big fingers...
              dc42undefined jens55undefined 2 Replies Last reply Reply Quote 0
                dc42 administrators @LordofCheese
                @lordofcheese said in Crimping PH pins (1LC) - what is the trick:
                There have been several complaints that the board is too large!
                • jens55undefined
                  jens55 @LordofCheese
                  Maybe I am getting my connectors mixed up .... I thought the VH connectors are the bigger ones for the power connector and the PH are the tiny ones for the stepper, fans, temp sensors etc etc .....
                  I haven't placed the order yet with DigiKey so please somebody confirm that the PH connector is the smaller of the two!
                  • jens55undefined
                    jens55 @dc42
                    @dc42 said in Crimping PH pins (1LC) - what is the trick:
                    Good God, how could you possibly make it smaller and still have room for connectors ?
                      @jens55 said in Crimping PH pins (1LC) - what is the trick:
                      Exactly! There is a smaller tool board (not Duet-compatible) designed by the Voron guys, but it has fewer connectors and no EMI management components.
                        T3P3Tony administrators @jens55
                        @jens55 on toolboard V1.1 the smaller crimps are JST PH compatible
                        • jens55undefined
                          jens55 @T3P3Tony
                          @t3p3tony, thanks for confirming !
