    v1.1 tool board extruder + filament sensor?
    377
    • kb58undefined
      kb58
      This was asked by someone but it wasn't answered, and I have the same question. If a v1.1 tool board is controlling an extruder, must the filament sensor also be connected to the tool board, or does it not matter and it can be connected to the 6HC board?
      Scratch-built 350mmx350mm coreXY, linear rails, ballscrews, 3 Z axis, Duet3 6HC, v3.3, Tool Board v1.1, BondTech LGX + Mosquito hot end
      Alex.crundefined 1 Reply Last reply Reply Quote 0
      • Alex.crundefined
        Alex.cr @kb58
        @kb58
        The filament sensor must be connected to whatever board has the extruder connected. In you case I would assume your toolboard controls your extruder. So yes, this would be required.
        It would be super convenient if this was not a limitation but its understandable. I believe @dc42 has stated in the past that this is required due to pulse timing and checking in the firmware.
        The only way around this is if you are using just a regular filament runout switch. You could configure it as trigger and have it run pause.g or any other macro.
        Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
        kb58undefined 1 Reply Last reply Reply Quote 0
        • kb58undefined
          kb58 @Alex.cr
          @alex-cr Thanks. The filament sensor is IR, but the output is just a logic level, so maybe it could be used on other boards. I think in this case, though, I'll place it above the extruder and run it to the tool board.
            https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations
            Filament monitors must be connected to the same board as the corresponding extruder motor. This use so that the firmware can correlate the measured filament movement and the commanded extruder movement in real time.
            What kind of filament sensor is it? Does it track filament motion, or is it just a simple presence detection?
            • kb58undefined
              kb58 @Phaedrux
              @phaedrux It's just a simple (probably open collector) IR sensor that is interrupted by the material. A long way of saying, yes, just a simple presence detector. For that reason, I suspect I could just treat it as a switch on the main board, but still haven't decided where it fits best.
                Yes if it's just a simple switch then the previously mentioned limitation doesn't really apply. It's just an endstop.
                  dc42 administrators @kb58
                  @kb58 currently any filament monitor or sensor configured using M591 must be attached to the same board as the extruder motor. We may make an exception in future firmware versions for simple filament presence detectors.
                  kb58undefined 1 Reply Last reply Reply Quote 1
                  • kb58undefined
                    kb58 @dc42
                    @dc42 Okay, thanks, question answered!
                      @kb58 you can connect it to the main board if instead of configuring it via M591 you configure it as a GpIn pin and set up a M581 trigger on it.
