    M600 still problem?
    829
    • PetrKroupaundefined
      PetrKroupa
      I was trying to find some info about the M600 filament change. I found this, for example.
      link text
      Basically, the M600 will call filament-change.g but it will not be able to start printing again. The extruder moves to the correct position (resume.g) but printing not starts. He is still "paused". If he clicks "resume", filament-change.g will run again and again. When I deleted filament-change.g, I also couldn't restore printing.
      Separately (form LCD buton) pause and resume functions work without problems.
      I run duet3 6HC + 1LC with SBC Rpi4, duet ver 3.3
      Any ideas?
      pause.g
      M83            ; relative extruder moves
      G1 E-10 F3600  ; retract 10mm of filament
      G91            ; relative positioning
      G1 Z5 F360     ; lift Z by 5mm
      G90            ; absolute positioning
      G1 X50 Y50 F6000 ; go to X=0 Y=0
      resume.g
      G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
      G1 R1 X0 Y0          ; go back to the last print move
      G1 E10 F3600         ; extrude 10mm of filament
      filament-change.g
      G1 Z25 F360     ; lift Z by 5mm
      G1 E-20 F300 ; Retract 20mm of filament at 300mm/min
      G4 S5
      G1 E-150 F3000 ; Retract 480mm of filament at 3000mm/min
      M400 ; Wait for the moves to finish
      M291 P"remove old filament, load new filament and press OK" R"Filament has to be changed M600" S2 ; display message to change filament Filament has run out
      m122
      m122
      RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-9P63L-DJMSS-6J1F8-3S46N-9VFV8
      Used output buffers: 1 of 40 (10 max)
      Static ram: 150904
      Dynamic ram: 62116 of which 0 recycled
      Never used RAM 141172, free system stack 200 words
      Tasks: SBC(ready,5.0%,328) HEAT(delaying,0.0%,325) Move(notifyWait,0.0%,302) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,6.9%,93) MAIN(running,88.0%,1246) IDLE(ready,0.0%,29), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:16:28 ago, cause: power up
      Last software reset at 2021-08-06 15:28, reason: User, none spinning, available RAM 137924, slot 1
      Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x00
      Step timer max interval 130
      MCU temperature: min 20.5, current 24.4, max 32.6
      Supply voltage: min 0.1, current 28.1, max 28.2, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 0.1, current 12.1, max 12.1, under voltage events: 0
      Driver 0: position 0, standstill, reads 3767, writes 14 timeouts 0, SG min/max 0/0
      Driver 1: position 0, standstill, reads 3767, writes 14 timeouts 0, SG min/max 0/0
      Driver 2: position 0, standstill, reads 3767, writes 14 timeouts 0, SG min/max 0/0
      Driver 3: position 0, standstill, reads 3767, writes 14 timeouts 0, SG min/max 0/0
      Driver 4: position 0, standstill, reads 3767, writes 14 timeouts 0, SG min/max 0/0
      Driver 5: position 0, standstill, reads 3767, writes 14 timeouts 0, SG min/max 0/0
      Date/time: 2021-08-07 08:10:17
      Slowest loop: 0.45ms; fastest: 0.03ms
      === Storage ===
      Free file entries: 10
      DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Filament sensors ===
      Extruder 0: no data received
      === CAN ===
      Messages queued 8810, received 12052, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 57514, free buffers 49 (min 48), ts 4941/4818/0
      Tx timeouts 0,0,122,0,0,0 last cancelled message type 30 dest 127
      === SBC interface ===
      State: 4, failed transfers: 1, checksum errors: 0
      Last transfer: 2ms ago
      RX/TX seq numbers: 34693/34693
      SPI underruns 0, overruns 0
      Disconnects: 0, timeouts: 0, IAP RAM available 0x2c83c
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.3.0
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz
      Full transfers per second: 0.78, max wait times: 19.6ms/0.0ms
      Codes per second: 0.00
      Maximum length of RX/TX data transfers: 3084/900
      gcode
      ;WIPE_END
      G1 E-0.03500 F2100.000
      G1 Z15.300 F18000.000
      ;AFTER_LAYER_CHANGE
      ;15.05
      ; LAYER: 114
      ;COLOR_CHANGE,T0
      M600
      G1 E-0.70000 F2100.000
      G1 X213.238 Y262.401 F18000.000
      G1 X213.027 Y264.554
      G1 Z15.050
      G1 E0.70000 F2100.000
      BigOne:Duet3 6HC +1LC + Rpi5 +SSD, mosquito hotend, 400x400x420
      SmallOne : Duet3 6HC +1LC + Rpi5 +SSD, mosquito hotend, 210x250x210
      Petr
      fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @PetrKroupa
        @petrkroupa
        Perhaps it is because you are running with a SBC.
        SBC "mode" has been lagging behind SD "mode" (no SBC) in terms of features.
        Can you try running without the SBC?
        PetrKroupaundefined 1 Reply Last reply Reply Quote 0
          PetrKroupa @fcwilt
          @fcwilt - it is no so simply put SD card to 6HC board in my setup. So if it not absolutely necessary, he would like to avoid it. 🙂 However, it seems to be right.
          Is there any plan improvement? For now, I can change the filament manually, but it's annoying.
          Petr
          • fcwiltundefined
            fcwilt @PetrKroupa
            @petrkroupa said in M600 still problem?:
            I have one SD card for SBC mode and one SD card for SD mode.
            They are mostly the same with just a very few differences - one or two related to network settings, others related to global variables names.
            I haven't yet found any compelling reason to use SBC mode so I am staying with SD mode for now.
            I'm sure they programmers will eventually get SBC mode working the same as SD mode but who knows when that will be.
              PetrKroupa @fcwilt
              @fcwilt - For me is diference LCD. I have hdmi touch lcd on Pi. Whithout SBC i dont have lcd. I can install clear rasbian on Pi and use it just for Duet web but it is not clear solution for me. Maybe in ver 3.4 will M600 work. I can not try beta for now. I need print some parts.
              Petr
                Phaedrux Moderator @PetrKroupa
                Can you try without the M291 command? Does that prompt show up and does it clear correctly when you hit ok?
                  PetrKroupa @Phaedrux
                  @phaedrux - sure, I can. But even without filament-change.g same problem happend. And in pause.g is no M291.
                  Mesage show correct and can be confirm by OK.
                  Interesing is when send M600 by type command everiting went well.
                  Petr
                    This is all happening during a print from the SD card, correct?
                      @phaedrux - yes. Gcode is on SD card in Raspberry. And is preaty big. 40hours print.
                      Petr
                      • chrishammundefined
                        chrishamm administrators @PetrKroupa
                        @petrkroupa Thanks for reporting this, I've got fixes ready for this problem. It will be fixed in the next RRF version.
                        @fcwilt The upcoming v3.4 will support everything in SBC mode that is already supported in standalone mode. The overall performance will be significantly higher in v3.4, too.
                        Duet software engineer
                        fcwiltundefined PetrKroupaundefined 2 Replies Last reply Reply Quote 3
                        • fcwiltundefined
                          fcwilt @chrishamm
                          @chrishamm said in M600 still problem?:
                          That's good to know.
                            PetrKroupa @chrishamm
                            @chrishamm - Perfect! Many thanks for info! 👍
                            Petr
