    Software bundle 3.4.0beta2 now available
    Beta Firmware
    8
    17
    1.6k
    • nurooundefined
      nuroo
      I cant wait for the DWC tuning plugin 🙂
      Did you give any thought to having firmware identify sensor orientation compared to printers axis and config itself accordingly?
      CCS86undefined 1 Reply Last reply Reply Quote 0
      • CCS86undefined
        CCS86 @nuroo
        @nuroo said in Software bundle 3.4.0beta2 now available:
        That sounds like a lot of effort for something that is really easy to configure manually.
          @ccs86 said in Software bundle 3.4.0beta2 now available:
          Exactly. It would be nice to have and we may implement it in the plugin eventually, but it's not a priority.
          nurooundefined 1 Reply Last reply Reply Quote 0
          • nurooundefined
            nuroo @dc42
            no problem.
            I appreciate the reponse. Just had a hell of a time picking the right orientation. Ultimately I never did pick the correct orientation and someone here had to help me.
            • manpowreundefined
              manpowre
              I upgraded my duet3d wifi 2 with the 3.4 beta 2 today for my Flsun QQ-S delta. I was excited about a few things, input shaping possibility, the fix for loosing z0 position of bed when homing (if I understood it correctly), and the negative z value fix where it was z0 and didnt go negative z ( I dont have this issue but a friend of mine does).
              all working as it should.. I did a test print - flawless. I will try input shaping once I can get hand of a accelerometer.
              I had 3.3 beta2 before. (skipped 3.3 release since beta2 was working just fine).
              • petriheinoundefined
                petriheino
                Updated from 3.2 to 3.4.0beta2.
                Duet 2 Wifi, everything seems work fine or similar to 3.2 (ran 20pcs prints).
                Noticed there is some pressure advance bug fixes in the Github (1.8.2021), those were probably included in this beta2 release?
                It made a small improvement in cylinder test but doenst still fix retraction related problems.
                Are there plans to solving retraction PA effect?
                  dc42 administrators @petriheino
                  @petriheino please explain what you mean by "retraction PA effect" - preferably by linking to another thread,
                  petriheinoundefined 1 Reply Last reply Reply Quote 0
                    petriheino @dc42
                    @dc42 If PA is enabled, and a retraction (or G10) is performed, the next unretraction (or G11) will cause a defect in the next connected movements (or ring of segments).
                    From such connected segments, first moves are missing material and the last moves have too much material
                    Summary of problem:
                    Settings that affect the amount of PA retraction error:
                    • retraction distance
                    • retraction speed
                    • retraction z hop distance and speed
                    • travel distance between parts
                    • Amount of PA value
                    This causes random print quality errors in different parts where there is retractions and travel moves and is not possible to correct by setting calibrations or configuration changes.
                    To be able to print any parts, extremely small retraction distances and speeds has to be used as to minimize error, that are linked to PA value and travel distances between parts (for example for PLA with Pa 0.04):
                    • retraction distance 0.2mm - 0.4mm
                    • retraction speed 900mm/min - 1200mm/min
                    • z hop 0.1mm - 0.4mm
                    • possibly also extra unrectraction distances of 0.03-0.1mm to hide error
                    Some links:
                    PA tuning
                    Enhancing pressure advance
                    PA tuning Disparencies
                      dc42 administrators @CCS86
                      Looking forward to testing the Maestro IS build!
                      My original plan was to implement the new motion system in integer maths for the Maestro. That turned out to be complicated, so I decided to try using the same floating point code that the other processors use. I was concerned that the maximum step rate would be greatly reduced when using floating point maths in the step ISR on a processor without FPU. However, I managed to almost double the speed of floating point square root calculations on the Maestro, by adapting our own integer square root function to work on floating point values. Consequently, the reduction in maximum step rate is modest, perhaps 10% to 20%.
                      I have put a preview of RRF with input shaping for the Maestro at https://www.dropbox.com/sh/cq7q3g8coymo9s3/AABtPYEzV1_unETpKEMPInSia?dl=0. Use it with care because it has had very limited testing.
                      CCS86undefined 1 Reply Last reply Reply Quote 1
                      • CCS86undefined
                        CCS86 @dc42
                        @dc42 said in Software bundle 3.4.0beta2 now available:
                        Well, that is an exciting turn!
                        I'll give it a try. Let me know if you would like feedback on anything specific.
                        Thank you for the effort!
                        • that guy Eundefined
                          that guy E
                          @dc42 Are there any plans to allow independent X an Y frequencies on a Duet2. I believe I read somewhere that RAM may become an issue.
                          On my CoreXY I saw ghosting nearly eliminated on the Y axis with the latest Beta, but still present on the X. I used the lower of the 2 values when I initially calculated the frequencies.
                            dc42 administrators @that guy E
                            @that-guy-e said in Software bundle 3.4.0beta2 now available:
                            Yes for Cartesian machines. For CoreXY machines, using separate input shaping for X and Y is a lot more complicated.
