Weird behaviour after first print
Just tried with M18 E0 but that doesn't change anything. Beside of that I observed the following after doing an emergency stop and moving the tool head up to deattach the probe:
https://drive.google.com/file/d/1xjToNHtGSHgUNfDPdsizFRtVbSMX8VJ_/view?usp=sharing
Very strange.
Just got "Error: Probe already triggered before probing move started" directly after switching off/on the printer. That was the first time.
@martinnyhc
Could get a bit tricky with a detached probe...then the cuircit is open.... -
I know t his is wokring for many many guys. And it already worked for me too
Hold on. Perhaps I've found the problem. DWC showed status 1000 when the probe is disconnected and 0 if connected. That should be the other way around. Changed C"^121.io0.in" to C"!^121.io0.in".
Since the change it goes to the probe points but not down to probe the bed at all.
I'm at my wits end.
That was bullsh****. All was properly installed. So I have no more ideas.
This is a detachable probe that must be docked, correct?
Yes, correct.
Maybe I found the problem. Just upgraded to 3.4-b2 to test input shaping and recognized that the accelerometer on the toolboard was not recognized. M122 B121 reported that no accelerometer could be found. Took the tool board from my other printer and it worked. Also currently it looks like the probe problems are gone. To be sure I'll test this a little bit more today.
Problem is still there
There is a new additional error message after the upgrade.
**Error: G32 has thrown an exception: [NullReferenceException] Object reference not set to an instance of an object.** Error: Probe already triggered at start of probing move
And with G29 I now get
@martinnyhc There must be an exception or cancelled code somewhere in your bed.g which is why you get that exception. I've got a fix ready that will be included in 3.4-b3. Also you seem to call G29 without S parameter in mesh.g, which will invoke mesh.g over and over again until you get a stack overflow.
Yep, already fixed that. I need to do some further testing regarding the probe. In the meantime if did a fresh SBC install.
OK, spent the day with doing a clean SBC install (RRF 3.3.0) and rewriting all config files and macros. The main issue I have still persists. Gantry and bed leveling works like charm if it is the first print. As soon as a print finished or where cancelled and I start a new print it fails.
Fails means for example: The first thing of course is homing. Second thing is gantry leveling.
; bed.g ; called to perform automatic bed compensation via G32 if !move.axes[0].homed && !move.axes[1].homed && !move.axes[2].homed G28 ; home M558 K0 H10 F400 ; set trigger height M561 ; clear any bed transform M98 P"0:/macros/sys/undock_klicky_probe.g" ; undock clicky probe while iterations <=1 ; first pass G30 P0 X20 Y25 Z-99999 F9000 ; probe Z left front G30 P1 X20 Y320 Z-99999 F9000 ; probe Z left rear G30 P2 X330 Y320 Z-99999 F9000 ; probe Z right rear G30 P3 X330 Y25 Z-99999 S4 F9000 ; probe Z right front G1 H2 Z12 F2600 ; raise head M400 ; finish move, clear buffer M558 K0 H2.5 F200 ; trigger height to 2.5mm after first run while move.calibration.initial.deviation >= 0.003 ; Perform additional leveling if previous deviation was over 0.03mm. G30 P0 X20 Y25 Z-99999 F9000 ; probe Z left front G30 P1 X20 Y320 Z-99999 F9000 ; probe Z left rear G30 P2 X330 Y320 Z-99999 F9000 ; probe Z right rear G30 P3 X330 Y25 Z-99999 S4 F9000 ; probe Z right front G1 H2 Z12 F2600 ; raise head M400 ; finish move, clear buffer echo "Gantry deviation of " ^ move.calibration.initial.deviation ^ "mm obtained." G1 Z12 ; Raise nozzle M98 P"0:/macros/sys/dock_klicky_probe.g" ; dock clicky probe G28 ; Homing again for accurate Z offset
It probes the four points for the first time, changes the probing height and probes for the second time. Suddenly it is just going to the probe points but don't lower Z to probe the bed.
Here's an archive of my complete config. I've spent so many days with this problem now and did everything which came to my mind, I'm definitely stuck and don't now what to do.
Help please!
Thanks in advance!
Are there example configs from other voron users that use this probe?
Have you tested in standalone mode as a control?
There are many many other users and I took over the config from them. And it already worked for multiple weeks.
Nope, not tested standalone. But as said I just did acomplete fresh SBC install.
Well I'd say either test your current config files in standalone mode to eliminate the SBC for testing, or wait for chrishamms updated build.
Right now we're mixing 3 confounding factors, unproven macros, SBC mode, and beta firmware. When in doubt, try and roll it back to the most basic configuration and when it's working, start adding new things one at a time. -
@martinnyhc try
; bed.g ; called to perform automatic bed compensation via G32 if !move.axes[0].homed && !move.axes[1].homed && !move.axes[2].homed G28 ; home M558 K0 H10 F400 ; set trigger height M561 ; clear any bed transform M98 P"0:/macros/sys/undock_klicky_probe.g" ; undock clicky probe G30 P0 X20 Y25 Z-99999 F9000 ; probe Z left front G30 P1 X20 Y320 Z-99999 F9000 ; probe Z left rear G30 P2 X330 Y320 Z-99999 F9000 ; probe Z right rear G30 P3 X330 Y25 Z-99999 S4 F9000 ; probe Z right front G1 H2 Z12 F2600 ; raise head M400 ; finish move, clear buffer M558 K0 H2.5 F200 ; trigger height to 2.5mm after first run while move.calibration.initial.deviation >= 0.003 ; Perform additional leveling if previous deviation was over 0.03mm. if iterations = 5 abort "Too many auto tramming attempts" G30 P0 X20 Y25 Z-99999 F9000 ; probe Z left front G30 P1 X20 Y320 Z-99999 F9000 ; probe Z left rear G30 P2 X330 Y320 Z-99999 F9000 ; probe Z right rear G30 P3 X330 Y25 Z-99999 S4 F9000 ; probe Z right front G1 H2 Z12 F2600 ; raise head M400 ; finish move, clear buffer echo "BTC: " ^ iterations + 2 ^ " - Difference was " ^ move.calibration.initial.deviation ^ "mm" continue G1 Z12 ; Raise nozzle M98 P"0:/macros/sys/dock_klicky_probe.g" ; dock clicky probe G28
Did you solve your problem? I'm struggling with QGL and mesh with the klicky probe... My problem is, that I use the autoz calculation macro at first and then I try to perform a QGL... After the homing and autoZ macro, the Z0 is at the surface of the bed plate - as expected. But then my QGL fails...
