    Issues after prime
    Beta Firmware
    6.3k
    • Heartleander81undefined
      Heartleander81 @Phaedrux
      @phaedrux
      Ok I change it to M83.
      Then I must write after every Extrude a M92 E0 ?
        Phaedrux Moderator @Heartleander81
        No need for M92 E0 when using relative extrusion. Make sure you've also changed the slicer to output relative extruder commands. It's not enough to just change M82 to M83 in the start gcode, though that must also be done.
        Heartleander81undefined 1 Reply Last reply Reply Quote 0
          @phaedrux
          I changed it in the slicer.
          when I enter the startcode (saved as "startGcode") on the Board not at slicer
          G32 G29 S1 P "hightmap.csv"
          G92 E0
          G1 X5 Y5 Z30 F6000.0
          G1 E40 F600
          G1 E40 F200
          G1 Y20 F2000
          G1 Y50 Z0.2 F2000
          G1 Y90 E20 F300
          G92 E0
          G1 Y120 F1200
          entries should that fit then? Because in the actual Gcode comes first one G92 E0.000 followed by G1 E-0.600
            @heartleander81 said in Isusses after prime:
            G1 E-0.600
            Is that not just a retraction being inserted by the slicer?
            Heartleander81undefined 2 Replies Last reply Reply Quote 0
              @phaedrux
              yes, but that makes my printer the problem. Ill test M83 later.
                @phaedrux
                I have change it.
                In Config.g is M83
                Slicer M83
                When I test the following startcode
                G32
                G29 S1 P"heightmap.csv"
                G1 E40 F600
                G1 E40 F200
                G1 Y20 F2000
                G1 Y50 Z0.2 F2000
                G1 Y90 E20 F300
                G1 Y120 F1200
                The Prime is good but I have the issuse how in the Youtube Video.
                Who is the fail?
                  Heartleander81
                  When I make the first G1 move slower then F4000 ore the first G1 E-0.6 slower then F300 ore i delet the first G1 E-0.6, I doun't have the problem.
                  All what I test the same issuse.
                  Is any on my toolboard Config wrong?
                    Heartleander81
                    I have install after 2 weeks the tool Board rev 1.1 with Accelerometer.
                    The first prints All good. Over night came this isusse. Then I make any test and then, why ever was all good but only for 2 prints and the issuse was back.
                      G31 P500 X22.775 Y-5.21 Z0.00
                      Your Z probe trigger height hasn't been measured yet.
                      https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                      Please post the results of M122 and M122 B121
                      Also send M98 P"config.g" and post the results.
                      Can you also share your homing files?
                        @phaedrux
                        Oh I have set it not to 0
                        But then I load M501 for the right trigger height.
                        Give me one Moment I Post it All.
                          Heartleander81
                          Config.g
                          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Aug 26 2020 16:14:58 GMT+0200 (Mitteleuropäische Sommerzeit)
                          G90        ; send absolute coordinates...
                          M83        ; ...but relativ extruder moves
                          M550 P"Duet3"                                                         ; set printer name
                          M912 P0 S-2                                                           ; setzt CPU Temp korrektur
                          M669 K1                                                               ;switch to core X/Y mode
                          G4 S2
                          M569 P0.1 S0 D2                                                         ; X physical drive 0.1 goes backwards
                          M569 P0.2 S0 D2                                                        ; Y physical drive 0.2 goes backwards
                          M569 P0.0 S1                                                          ; Z1 physical drive 0.0 goes forwards
                          M569 P0.4 S1                                                          ; Z2 physical drive 0.4 goes forwards
                          M569 P0.3 S1                                                          ; Z3 physical drive 0.3 goes forwards
                          M569 P0.5 S1                                                          ;    physical drive 0.5 goes forwards
                          M569 P20.0 S1 D2                                                    ; E physical drive 0.0 Driver0 tool goard goes forwards
                          M584 X0.1 Y0.2 Z0.0:0.4:0.3 E20.0                                      ; set drivers mapping
                          M350 X16 Y16 Z16 E16 I1                                               ; configure microstepping with interpolation
                          M92 X80.40 Y80.40 Z800.00 E717.97                                     ; set steps per mm
                          M566 X1250.00 Y1250.00 Z200.00 E1000.00                                 ; set maximum instantaneous speed changes (mm/min)
                          M203 X30000.00 Y30000.00 Z600.00 E16000.00                            ; set maximum speeds (mm/min)
                          M201 X3000.00 Y3000.00 Z200.00 E2000.00                               ; set accelerations (mm/s^2)
                          M906 X1150 Y1150 Z1050 E750 I50                                       ; set motor currents (mA) and motor idle factor in per cent
                          M84 S120                                                              ; Set idle timeout
                          M208 X0 Y0 Z-1 S1                                                     ; set axis minima
                          M208 X305 Y300 Z295 S0                                                ; set axis maxima
                          M574 X1 S1 P"20.io1.in"                                                ; configure active-high endstop for low end on X via pin 1.io1.in
                          M574 Y1 S1 P"io1.in"                                                  ; configure active-high endstop for low end on Y via pin io1.in
                          M574 Z1 S2
                          M950 S0 C"20.io0.out"                                                  ; create servo pin 1.io0.out for BLTouch
                          M558 P9 C"^20.io0.in" H3 A10 S0.005 F700 T6000                         ; set Z probe type to bltouch and the dive height + speeds old H5 F200 T4000
                          G31 P500 X22.775 Y-5.21 Z0.00                                         ; set Z probe trigger value, offset and trigger height
                          M557 X30:285 Y11:266 S25.5                                            ; define mesh grid
                          M671 X-21.018:155.191:331.4 Y-20.717:307.493:-20.717 S50              ; Z lift Point Position
                          M308 S0 A"Bett" P"temp0" Y"thermistor" T100000 B4138                  ; configure sensor 0 as thermistor on pin temp0
                          M950 H0 C"out0" T0                                                    ; create bed heater output on out0 and map it to sensor 0
                          M307 H0 B0 R0.139 C807.2 D40.94 S1.00 V24.8                           ; disable bang-bang mode for the bed heater and set PWM limit
                          M140 H0                                                               ; qmap heated bed to heater 0
                          M143 H0 S140                                                          ; set temperature limit for heater 0 to 120C
                          M308 S1 A"Vulcano" P"20.temp0" Y"thermistor" T100000 B4725 C7.060000e-8  ; configure sensor 1 as thermistor on pin temp1
                          M950 H1 C"20.out0" T1                                                    ; create nozzle heater output on 20.out0 and map it to sensor 1
                          M307 H1 B0 R2.775 C211.7:169.1 D3.87 S1.00 V24.7                      ; disable bang-bang mode for heater  and set PWM limit
                          M308 S2 A"Elektro" P"temp3" Y"thermistor" T100000 B4100               ; configure sensor 1 as thermistor on pin temp1
                          M308 S3 Y"mcu-temp" A"MCU"                                            ; configure sensor 4 as thermistor on pin e1temp
                          M308 S4 Y"drivers" A"Stepper"                                         ; configure sensor 3 as temperature warning and overheat flags on Duet
                          M308 S5 A"Raspi" P"temp2" Y"thermistor" T100000 B4138                 ; Raspi cooling Fan
                          M950 F1 C"20.out2" Q500                                                  ; create fan 1 on pin 20.out2 and set its frequency
                          M106 P1 C"Hotend" S1 H1 T50                                           ; set fan 1 name and value. Thermostatic control is turned on
                          M950 F0 C"out4" Q8000                                                 ; create fan 0 on pin out4 and set its frequency
                          M106 P0 C"Bauteil1" S0 H-1                                            ; set fan 0 name and value. Thermostatic control is turned off
                          M950 F2 C"out9" Q500
                          M106 P2 H5 T50:60                                  	                  ; create fan 2 on pin out8 and set its frequency
                          M950 F3 C"out8" Q500
                          M106 P3 H3:4 T45:60								                      ; set fan 3 value
                          M563 P0 S"Vulcano" D0 H1 F0                                           ; define tool 0
                          G10 P0 X0 Y0 Z0                                                       ; set tool 0 axis offsets
                          G10 P0 R0 S0                                                          ; set initial tool 0 active and standby temperatures to 0C
                          M955 P20.0 I10                                                       ;Accelerometer 20:0 type LIS3DH with orientation 10 samples at 1344Hz with 10-bit resolution
                          M564 S1 H0
                          M150 X1
                          M575 P1 S3 B115200                            ;57600 enable Display
                          M911 S21 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"                   ; set voltage thresholds and actions to run on power loss
                          M501        ; load saved parameters from non-volatile memory
                          Homeall.g
                          ; homeall
                          G91                       ; relative mode
                          G1 Z5 F600
                          G1 H1 Y-340 F6000         ; course home X
                          G1 Y4 F6000
                          G1 H1 Y-10 F600           ; fime home X
                          G1 Y100 F6000
                          G1 H1 X-340 F6000         ; course home Y
                          G1 X4 F5000            ; move away from the endstops
                          G1 H1 X-10 F600           ; fine home Y
                          G90                       ; back to absolute mode
                          ; The following code assumes you are using a Z probe to do Z homing.
                          ; Adjust the XY coordinates in the following to place the Z probe over a suitable spot,
                          ; preferably near the centre of the bed if your Z probe supports that
                          G1 X131.4 Y139.4 F6000
                          M401
                          G30
                          M122
                          RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (SBC mode)
                          Board ID: 08DJM-9P63L-DJ3T8-6J1DA-3SD6P-KV4H9
                          Used output buffers: 1 of 40 (11 max)
                          Static ram: 150904
                          Dynamic ram: 62268 of which 212 recycled
                          Never used RAM 140808, free system stack 184 words
                          Tasks: SBC(ready,16.0%,338) HEAT(delaying,0.0%,325) Move(notifyWait,0.1%,284) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,24.0%,59)
                          MAIN(running,59.8%,922) IDLE(ready,0.0%,29), total 100.0%
                          Owned mutexes: HTTP(MAIN)
                          Last reset 04:34:37 ago, cause: reset button
                          Last software reset at 2021-08-15 16:22, reason: User, none spinning, available RAM 137520, slot 1
                          Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0440f000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                          Error status: 0x00
                          Aux0 errors 0,0,0
                          Step timer max interval 166
                          MCU temperature: min 42.3, current 46.6, max 46.8
                          Supply voltage: min 25.0, current 25.0, max 25.1, under voltage events: 0, over voltage events: 0, power good: yes
                          12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
                          Driver 0: position 0, standstill, reads 33617, writes 19 timeouts 0, SG min/max 0/143
                          Driver 1: position 0, standstill, reads 33621, writes 15 timeouts 0, SG min/max 0/0
                          Driver 2: position 40000, standstill, reads 33621, writes 15 timeouts 0, SG min/max 0/0
                          Driver 3: position 0, standstill, reads 33618, writes 19 timeouts 0, SG min/max 0/153
                          Driver 4: position 0, standstill, reads 33618, writes 19 timeouts 0, SG min/max 0/158
                          Driver 5: position 0, standstill, reads 33626, writes 11 timeouts 0, SG min/max 0/0
                          Date/time: 2021-08-16 18:30:16
                          Slowest loop: 0.79ms; fastest: 0.04ms
                          === Storage ===
                          Free file entries: 10
                          DMs created 125, maxWait 89292ms, bed compensation in use: none, comp offset 0.000
                          === MainDDARing ===
                          Scheduled moves 2, completed moves 2, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
                          === AuxDDARing ===
                          Segments left: 0
                          Movement lock held by null
                          Telnet is idle in state(s) 0
                          File is idle in state(s) 0
                          USB is idle in state(s) 0
                          Aux is idle in state(s) 0
                          Queue is idle in state(s) 0
                          LCD is idle in state(s) 0
                          SBC is idle in state(s) 0
                          Daemon is idle in state(s) 0
                          Aux2 is idle in state(s) 0
                          Code queue is empty.
                          === CAN ===
                          Messages queued 148116, received 197133, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 176, free buffers 49 (min 48), ts 82389/82388/0
                          Tx timeouts 0,0,0,0,0,0
                          === SBC interface ===
                          State: 4, failed transfers: 1, checksum errors: 0
                          Last transfer: 0ms ago
                          RX/TX seq numbers: 64954/64954
                          SPI underruns 0, overruns 0
                          Disconnects: 0, timeouts: 0, IAP RAM available 0x2c810
                          Buffer RX/TX: 0/0-0
                          === Duet Control Server ===
                          Duet Control Server v3.3.0 Code buffer space: 4096 Configured SPI speed: 8000000Hz
                          Full transfers per second: 35.83, max wait times: 28.7ms/0.0ms
                          Codes per second: 0.01
                          Maximum length of RX/TX data transfers: 2568/808
                          M122 B20
                          M122 B20
                          Diagnostics for board 20:
                          Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58)
                          Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
                          Never used RAM 2680, free system stack 2789 words
                          Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.5%,107) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.1%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,8.6%,57)
                          MAIN(running,75.8%,352) IDLE(ready,0.0%,27) AIN(delaying,15.0%,142), total 100.0%
                          Last reset 04:44:52 ago, cause: software
                          Last software reset data not available
                          Driver 0: position 0, 718.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 71, reads 26324, writes 12, timeouts 6, DMA errors 0, failedOp 0x41, steps req 0 done 0
                          Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                          Peak sync jitter 0/6, peak Rx sync delay 217, resyncs 0/0, no step interrupt scheduled
                          VIN: 25.3V
                          MCU temperature: min 44.0C, current 44.7C, max 48.8C
                          Ticks since heat task active 126, ADC conversions started 17092120, completed 17092119, timed out 0, errs 0
                          Last sensors broadcast 0x00000002 found 1 130 ticks ago, loop time 0
                          CAN messages queued 203765, send timeouts 66, received 153030, lost 0, free buffers 37, min 37, error reg 100000 Last cancelled message type 4512 dest 127
                          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                          Accelerometer detected: yes, status: 00
                          I2C bus errors 0, naks 0, other errors 0
                          M98 P"config.g"
                          M98 P"config.g"
                          Accelerometer 20:0 with orientation 10 samples at 1344Hz with 10-bit resolution
                            Heartleander81
                            ; config-override.g file generated in response to M500 at 2021-01-25 11:01
                            G31 P500 Z4.35    ; for trigger height
                              @phaedrux
                              Ok I hope that is all what you need
                                What do you have in bed.g?
                                Have you tried with mesh compensation disabled?
                                  @phaedrux
                                  ; bed.g
                                  G29 S2 ; clear bed high map
                                  G28 ; home
                                  M401
                                  G30 P0 X25.159 Y16.257 Z-99999 ; probe near a leadscrew
                                  G30 P1 X25.159 Y266.257 Z-99999 ; new
                                  G30 P2 X285.159 Y266.257 Z-99999 ; x154.53 old
                                  G30 P3 X285.159 Y16.257 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
                                  G28Z
                                  M402
                                  If I edit the G-code that it does everything at z-height, say 5mm, then it's the same with the X-axis. runs on stops - extruder is doing something - X axis continues to run. As mentioned, if I delete or comment out the first Retract G1 E-0.6000 F1200 from the sliced ​​file, there are no problems with the X axis or the extruder
                                    This still very much sounds like it's in absolute extrusion mode and it's pausing while it's trying to move the extruder to undo all of the previous extrusion commands.
                                      Heartleander81
                                      I apologize if my sentences read clumsily or unkindly. I work with google translators because my english is very bad. I am very, very grateful for the help that I am getting because I am slowly becoming desperate.
                                        @phaedrux
                                        ok i understand that and is understandable. but why is he doing this? in the start code it runs great in the M83 and after that I no longer give an M82 command. I switched Simplify3D to M83 and the sliced ​​code also looks like it.
                                          M955 P20.0 I10
                                          Can you try commenting out the accelerometer command?
                                            @phaedrux
                                            Have I do yesterday. But with M82.
                                            I can try it in 30 min.
