I am near.... but
with the help of forum Staff and members, i am close to finish migration from FW 2.x to FW 3.4
one of the last things I am missing is the extruder, nothing appears in the DWC ...
I have these lines in the config.g. What am I missing? What have I overlooked?
;Extruder M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C
@peirof if your extruder mapped in M584?
e.g.M584 X0 Y1 Z2 E3
think can be this, now i am not in home.
Extruder stepper motor its connected to Shocket E0_MOTOR, this correspond to Drive 3. No?
but, now, i am not sure. Its possible that Extruder stepper its connected to Shocket E1_Motor, thar correspond to Drive 4....
Later check
@jay_s_uk said in I am near.... but:
M584 X0 Y1 Z2 E3
@jay_s_uk since NOW you are one of the my best friends..... solved. Now extruder appears in DWC.....Thx to all
