    Issues after prime
    Beta Firmware
    6.3k
    • Heartleander81undefined
      Heartleander81 @Phaedrux
      @phaedrux
      Any other Propeller use 50-70mm/s retract speed. There is my 20 very slow.
      Without filament I can speed the extruder high. With optimal print Temp and filament can I extrude ~20mm/s.
      I have this 20mm/s use the last 6-8 month without Problem.
      Any time I have step lost on X and Y
        Heartleander81
        https://youtu.be/h9OgIKBjpsM
        If you look at this video you can see how the car brakes hard by braking and starting again and then continues jerking, and the belts wobble a lot. Depending on how it vibrates, the motors lose steps and I no longer print in the middle. In the long run, the jerking is not healthy for the whole mechanics
          @phaedrux
          But the question is why run the extruder to 0 and back to 99.4 when M83 is Configured?
          When I All write to M82 and slice M82 is the same problem. At this one Point reset the firmware not the extruder.
            Heartleander81
            That Video is with a another Purge line.
            There is with step lost on X and Y. The print must start on the middle on x150 Y150 but is in the left back corner.
            https://youtu.be/UaVkC-F1cfM
              Have you tested in standalone mode yet without the SBC?
              https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Running_in_standalone_mode
              Heartleander81undefined 1 Reply Last reply Reply Quote 0
                @phaedrux no. I dount have standalone configured
                  As process of elimination it may help to know if the problem still presents in standalone mode.
                  You can copy your current config files onto a fresh SD card that has the folder structure and DWC files present and use that SD card in the Duet. That link describes in more detail.
                  Heartleander81undefined 2 Replies Last reply Reply Quote 0
                    @Phaedrux
                    Ok have I do.
                      @phaedrux
                      The same on standalone
                        Heartleander81
                        That came after 2 weeks after I have install the toolboard 1lc V1.1
                          Heartleander81
                          Should I reset the toolboard?
                          By pressing both buttons on the toolboard when starting.
                          Reload the board firmware and then test it again?
                          After install the Bus change to 20.
                            Thanks for testing in standalone mode. Before you do anything to the toolboard, let's let @dc42 have a look and see what he thinks.
                              @phaedrux
                              Ok.
                                dc42 administrators @Heartleander81
                                @heartleander81 said in Isusses after prime:
                                Please can you provide the start of the GCode file that you were printing when you recorded this video.
                                I suspect that a firmware issue is causing this behaviour.
                                  Heartleander81 @dc42
                                  Good Morning.
                                  G90
                                  M83
                                  M106 S0
                                  M140 S50
                                  M190 S50
                                  M104 S240 T0
                                  M109 S240 T0
                                  T0
                                  M98 P"startGcode"
                                  G92 E0.0
                                  ; process CR3D 0.4
                                  ; layer 1, Z = 0.200
                                  T0
                                  G1 E-0.6000 F1200
                                  ; feature skirt
                                  ; tool H0.200 W0.440
                                  G1 Z0.200 F600
                                  G1 X118.950 Y122.494 F12600
                                  ;G1 X19.489 Y53.567 F12600
                                  ;G1 E0.6000 F1200
                                  ;G1 X280.511 Y53.567 E8.9768 F1800
                                  ; layer end
                                  T0
                                  M98 P"endGcode"
                                  Unfortunately, I no longer have the file from the print. Do you mean the purge line in the startup code?
                                  Thanks for your Help.
                                    @heartleander81 thanks, to try to reproduce this I also need the contents of macros startGCode and endGcode. [Edit: I see that you have already provided startGcode, so I will try to reproduce it.
                                      startGcode
                                      M150 U255 P128 S60 ;LED gruen
                                      M150 R255 B235 U255 P128 S60 ;LED weiß
                                      G32
                                      G29 S1 P"heightmap.csv"
                                      M83
                                      G1 X5 Y5 Z30 F6000.0
                                      G1 E50 F500
                                      G1 E30 F200
                                      G1 Y20 F2000
                                      G1 Y50 Z0.2 F3000
                                      G1 Y90 E20 F300
                                      G1 Y120 F1200
                                      endGcode
                                      G10 P0 R0 S0		        ; Set hotend temp to 0
                                      M140 S0			            ; Set bed temp to 0
                                      G91
                                      G1 Z10
                                      G90
                                      G92 E0
                                      G1 E-1 F300
                                      G92 E0
                                      M106 S20 		            ; Fan to cool nozzle and bed
                                      M220 S100		            ; Set speed factor back to 100% in case it was changed
                                      M221 S100		            ; Set extrusion factor back to 100% in case it was changed
                                      M290 R0 S0
                                      G1 X25 Y300 F6000
                                      G1 E-9 F200
                                      G92 E0
                                      M300 S290 P1000
                                      G4 S60		            	; wait 1 minute for nozzle to cool
                                      M107			            ; turn off the fan
                                      G4 S30
                                      M98 P"/macros/LED/LED_Aus"
                                      M18
                                        @heartleander81 thanks! Do you have any tool change files on your system?
                                          @dc42 no I don't have tool change file. The tool Board 1lc 1v1 is direkt conected to the duet6 6hc Board.Screenshot_20210818-151636.jpg
                                            @dc42 in the last 2 file is only write M116 P0
