    error start printing
    Firmware installation
    463
    • duttiundefined
      dutti @dutti
      @barbarossa-cologne
      • duttiundefined
        dutti
        cura start g code
        M82 ; Absolute extrusion mode
        G28 ; Home
        M140 S{material_bed_temperature} ; Set bed temperature
        G10 P0 S{material_print_temperature} ; Set tool 0 active temperature
        T0 ; Tool 0
        M98 P"/macros/tpre0" ;tpre0
        M116 ; Wait for temperatures
        • Nxt-1undefined
          Nxt-1
          @dutti My expecience with tool changers is very limited but I believe there should be tool change macro's on your system that handle the actual C axis movements. Could you post these too please, my guess is that something in there could be causing your axis to become unhomed.
          Duet3D and delta printer enthousiast. Buildlog
          Looking for Duet3D configuration support, check out Nxt-3D
          duttiundefined 1 Reply Last reply Reply Quote 0
          • duttiundefined
            dutti @Nxt-1
            • jens55undefined
              jens55
              If you are using a tool changer such as the Jubilee, there is a problem with using Cura. Cura will insert a few commands prior to running the start script. In particular, it will insert a T0 command that plays havoc with the Jubilee since it can't home with a tool installed.
              What actually happens is that Cura calls for T0 and then you try to home in your start script and that is where the printer gets screwed up.
              One of the ways to work around the issue is to edit the Cura generated gcode file to remove the initial tool selection. Another workaround is to insert a T-1 as your first line in your start script. The third work around is to remove any homing from your start script and make sure that you manually home the printer before you run the Cura generated gcode.
              While I haven't tested all the workarounds listed, I am sure at least one will get you going.
                Phaedrux Moderator @jens55
                @jens55 said in error start printing:
                The easiest way to do this would be to use a start.g macro in the system folder. It gets called at the start of a job and gets executed before the sliced gcode file. So you can do all of your print prep there before the cura code takes over.
                • jens55undefined
                  jens55 @Phaedrux
                  @phaedrux, it took me a bit before I fully understood what you were saying but I think this is an excellent idea. Basically you pull a 'Cura' on Cura by executing code before Cura can execute the code the precedes the start script of Cura ... LOL
                  While I haven't tried it out, I think this is in fact the most elegant solution to this mess. Execute the homing before Cura can call for the first extruder!
                  Thank you!
                    The majority of my "start" gcode lives in start.g right now. It also has the benefit of being slicer agnostic. All the slicer is in charge of now is final temp setting and calling a purge line macro.
                    • jens55undefined
                      jens55 @Phaedrux
                      @phaedrux said in error start printing:
                      Is 'stop.g' the last executed file after a print is finished? Do you use it instead of the ending script in the slicer ?
                      BTW, your solution with using 'start.g' works a treat !
                        Stop.g gets called by M0. So I have M0 as the end gcode in my slicers.
                        jens55undefined duttiundefined 2 Replies Last reply Reply Quote 0
                        • jens55undefined
                          jens55 @Phaedrux
                          @phaedrux , thanks !
                          • duttiundefined
                            dutti @Phaedrux
                            @phaedrux
                            sorry I was in vacation..
                            and yes that works really good. thanks for this idea!
