Solved duet exp3hc lost connection with main board
Please keep your posts together in this thread.
Please connect the expansion board and send M122 and M122 B#, where # is the can bus address of the expansion board and copy and paste the resulting report here.
What LEDs are lit on the expansion board?
Can you post a photo of your wiring on the expansion board?
; Custom settings are not defined M997 S1
You probably shouldn't have this command in config.g Not sure why you would need or want to flash the wifi firmware at boot up, especially on a board that doesn't have a wifi module.
Unfortunately when I connected the
Exp3hc to the power and can, I saw Smoke from the endstop conectors area, (never used them),dont think its right to use it,
I did conect only red and black and the can cable,Any idea?
Can you post some photos of the wiring and damage?
Attached photo,
The exp3hc is not conect now to main board /power
I used the exp3hc only for X axis and extruder '
Can you show a closer photo of the circled area with more light?
What LEDs are lit on the expansion board if any when it is connected?
Can you describe for us how and what you had connected to the expansion board at the time it failed?
-power from main board (+-) as shown in the photo
-X stepper was conect to driver 1
-extruder stepper was conect to driver 2
-RJ11 cable was conect to can in from main board
nothing else was connect to that boardI did use for cables connectors that I got with the board
The connections sound pretty standard. This may be a case of premature component failure.
When and where did you purchase the board? It may be covered by warranty.
I bought it from "Rav Meimad"
The Israeli reseller on 22.7.21 -
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
HI,
Can I we posts together in this thread? -
@danny777 Let's stick to your other thread.
