Solved duet exp3hc lost connection with main board
Can you post some photos of the wiring and damage?
Attached photo,
The exp3hc is not conect now to main board /power
I used the exp3hc only for X axis and extruder '
Can you show a closer photo of the circled area with more light?
What LEDs are lit on the expansion board if any when it is connected?
Can you describe for us how and what you had connected to the expansion board at the time it failed?
-power from main board (+-) as shown in the photo
-X stepper was conect to driver 1
-extruder stepper was conect to driver 2
-RJ11 cable was conect to can in from main board
nothing else was connect to that boardI did use for cables connectors that I got with the board
The connections sound pretty standard. This may be a case of premature component failure.
When and where did you purchase the board? It may be covered by warranty.
I bought it from "Rav Meimad"
The Israeli reseller on 22.7.21 -
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
HI,
Can I we posts together in this thread? -
@danny777 Let's stick to your other thread.
