Scara support ?
I'm sorry, when I refactored the kinematics code I forgot to change the SCARA code to apply the usual limits to all axes other than X and Y. I'll fix this in the next release. There will probably be a 1.19.1 release to tidy up issues such as this one.
I've been testing the SCARA support on my new SCARA printer. There is a bug in the forward kinematics calculations. No wonder you were having problems! I will have a fix soon (and it will include the Z axis limits too).
Hehe cool
I look forward to sensor IR sense
The French post office is slow at the moment …
Thanks in advancePossible to see your scara : p
I'm curious to see a business model -
There are pics of my SCARA printer at https://miscsolutions.wordpress.com/2017/08/09/testing-the-robotdigg-scara-arm-3d-printer/. It's a very cheap printer - Duet electronics are too good for it! But it's good enough for me to use it to test the SCARA support.
My SCARA printer is now working properly. SCARA fixes are in the 1.19+4 bugfix test version - see separate thread.
Hello
IR sensor received
I removed end-stop from the Z
I connected "IR Sensor" to the end-stop of the Z
I can not run correctly
Can you give me an example for config.g and homeall.g? (hooming Z and auto-levelling bed.g on Scara ?)I put M558 P5 but I have error if i use G30 on homeall.g
[c]G28
Attempt to move the head of a Delta or SCARA printer before homing the towers
Error: Z probe already triggered at start of probing move
Error: Homing failed[/c]I get to operate without G30 in homeall.g in the meantime …
[[language]] ;homeall.g ... Home x/y ok ... G91 ; relative movement G1 S1 Z-400 F250 ; ensure head is clear of the bed G1 S2 Z6 ; move Z by 6 mm G1 S1 Z-10 F100 ; move proximal joint slowly to the endstop switch again G90 ; absolute movement
The IR sensor should be connected as a Z probe, not an endstop switch. See https://duet3d.com/wiki/Connecting_a_Z_probe. You can keep the existing homing switch if you like and just use the Z probe to do mesh levelling or just to get a more accurate Z=0 position immediately before printing.
ok
Other problem impossible to move X / Y with G1 in scara if Z is not homing
; homeall.g
; called to home all axes
; File homeall.g
;G91 ; relative movement
;G1 Z4 F100 ; ensure head is clear of the bed; Home proximal joint
G91
G1 S1 X-200 F2000 ; move proximal joint clockwise by up to 200 degrees until the endstop switch is triggered
G1 S2 X5 ; move proximal joint anticlockwise by 10 degrees
G1 S1 X-20 F300 ; move proximal joint slowly to the endstop switch again
;G1 S2 X0 F2000 ; move proximal joint to centre of range; Home distal joint
G1 S1 Y200 F2000 ; move distal joint clockwise by up to 200 degrees until the endstop switch is triggered
G1 S2 Y-5 ; move distal joint anticlockwise by 10 degrees
G1 S1 Y20 F300 ; move distal joint slowly to the endstop switch again
;ko
G1 X150 Y150 F2000 ; move distal joint to centre of range; Home Z
G90 ; absolute movement;ok
G1 X150 Y150 F2000 ; move distal joint to centre of range -
In my homeall.g file, after homing the proximal and distal joints I use G90 then G0 S2 Xxxx Yyyy Ffff, where xxx and yyy are the angles that I want the proximal and distal joints to take up prior to Z homing. This gets round the issue of moves to XYZ coordinates not being allowed until all axes have been homed.
ok ==> G0 S2 Xxxx Yyyy Ffff
It is not conceivable for the futur to RFF support connect IR Sensor to End-Stop Z ?
Would it be cleaner at the wiring level ?
(I do not want to keep Mechanical Z End-Stop) -
No. The IR sensor produces a 4-level analogue output. This is so that the firmware can slow down the probing move when the trigger point is approaching.
You will need to change your homeall.g file, also homez.g if you are using one, to use a G30 probing move instead of a G1 S1 move. See https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_Z.
ok i change connect tomorrow …
Where connect "out" (3-pin IR Sense on duet-wifi)
Not on the expansion connector at all. Use the Z probe connector and see the link i posted earlier (6 posts back).
ok
out IR Sense (3-Pin) on ==> Z PROBE IN ? -
Yes. Leave the Mod pin on the Z probe connector unconnected.
Hello
Sorry to solicit you again …Z End-Stop removed
And "IR Sense" connect on "Z probe connector"my config.g (End-stop only)
M574 X1 S0 ; Define (P) active low microswitches
M574 y2 S0 ; Define (D) active high microswitches
M574 Z0 S0 ; Define (Z) active low and unused microswitches
M558 P2 X0 Y0 Z1 H5 F120 T2000 ; Set Z probe type to modulated, the axes for which it is used and the probe + travel speeds
G31 P500 X30 Y30 Z2.5 ; Set Z probe trigger value, offset and trigger height
M557 X15:285 Y15:285 S20 ; Define mesh gridmy homeall.g (Z Only)
G30 ; Single Z-ProbeZ does not stop where is my error ?
Hummmm….
modified M558/G31/M574 Z[[language]] ; Endstops M574 X1 S0 ; Define (P) active low microswitches M574 y2 S0 ; Define (D) active high microswitches M574 Z0 S1 ; Define (Z) active low and unused microswitches ;Z probe M558 P1 I1 X0 Y0 Z1 G31 Z2.5 P500
[[language]] 16:04:09 Attempt to move the head of a Delta or SCARA printer before homing the towers 16:04:05 G28 Error: Z probe already triggered at start of probing move Attempt to move the head of a Delta or SCARA printer before homing the towers Error: Z probe already triggered at start of probing move Error: Homing failed
Found ! ok
M558 P1 I0 X0 Y0 Z1 -
The default for M558 is I0. Your mistake was to use P2, because P1 is correct as described at https://duet3d.com/wiki/Connecting_a_Z_probe#Mini_differential_IR_sensor_by_dc42
It all starts to work really well
Homing, auto-leveling …Another question: p
How the heightmap.csv file is used
In my gcode after G28 I add a G29 S1 to recharge it?
