    Scara support ?
    16.4k
      There are pics of my SCARA printer at https://miscsolutions.wordpress.com/2017/08/09/testing-the-robotdigg-scara-arm-3d-printer/. It's a very cheap printer - Duet electronics are too good for it! But it's good enough for me to use it to test the SCARA support.
        My SCARA printer is now working properly. SCARA fixes are in the 1.19+4 bugfix test version - see separate thread.
        • frafaundefined
          frafa
          Hello
          IR sensor received 🙂
          I removed end-stop from the Z
          I connected "IR Sensor" to the end-stop of the Z
          I can not run correctly
          Can you give me an example for config.g and homeall.g? (hooming Z and auto-levelling bed.g on Scara ?)
          I put M558 P5 but I have error if i use G30 on homeall.g
          [c]G28
          Attempt to move the head of a Delta or SCARA printer before homing the towers
          Error: Z probe already triggered at start of probing move
          Error: Homing failed[/c]
          I get to operate without G30 in homeall.g in the meantime …
          [[language]]
          ;homeall.g
          ... Home x/y ok ...
          G91                ; relative movement
          G1 S1 Z-400 F250    ; ensure head is clear of the bed
          G1 S2 Z6          ; move Z by 6 mm
          G1 S1 Z-10 F100    ; move proximal joint slowly to the endstop switch again
          G90                ; absolute movement
          Scara with DuetWifi => Scarlette3D
          https://youtu.be/mBF5cO8vGhI
            The IR sensor should be connected as a Z probe, not an endstop switch. See https://duet3d.com/wiki/Connecting_a_Z_probe. You can keep the existing homing switch if you like and just use the Z probe to do mesh levelling or just to get a more accurate Z=0 position immediately before printing.
            • frafaundefined
              frafa
              ok 🙂
              Other problem impossible to move X / Y with G1 in scara if Z is not homing
              ; homeall.g
              ; called to home all axes
              ; File homeall.g
              ;G91 ; relative movement
              ;G1 Z4 F100 ; ensure head is clear of the bed
              ; Home proximal joint
              G91
              G1 S1 X-200 F2000 ; move proximal joint clockwise by up to 200 degrees until the endstop switch is triggered
              G1 S2 X5 ; move proximal joint anticlockwise by 10 degrees
              G1 S1 X-20 F300 ; move proximal joint slowly to the endstop switch again
              ;G1 S2 X0 F2000 ; move proximal joint to centre of range
              ; Home distal joint
              G1 S1 Y200 F2000 ; move distal joint clockwise by up to 200 degrees until the endstop switch is triggered
              G1 S2 Y-5 ; move distal joint anticlockwise by 10 degrees
              G1 S1 Y20 F300 ; move distal joint slowly to the endstop switch again
              ;ko
              G1 X150 Y150 F2000 ; move distal joint to centre of range
              ; Home Z
              ;ok
                In my homeall.g file, after homing the proximal and distal joints I use G90 then G0 S2 Xxxx Yyyy Ffff, where xxx and yyy are the angles that I want the proximal and distal joints to take up prior to Z homing. This gets round the issue of moves to XYZ coordinates not being allowed until all axes have been homed.
                • frafaundefined
                  frafa
                  ok ==> G0 S2 Xxxx Yyyy Ffff
                  It is not conceivable for the futur to RFF support connect IR Sensor to End-Stop Z ?
                  Would it be cleaner at the wiring level ?
                  (I do not want to keep Mechanical Z End-Stop)
                    No. The IR sensor produces a 4-level analogue output. This is so that the firmware can slow down the probing move when the trigger point is approaching.
                    You will need to change your homeall.g file, also homez.g if you are using one, to use a G30 probing move instead of a G1 S1 move. See https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_Z.
                    • frafaundefined
                      frafa
                      ok i change connect tomorrow …
                      Where connect "out" (3-pin IR Sense on duet-wifi)
                        Not on the expansion connector at all. Use the Z probe connector and see the link i posted earlier (6 posts back).
                        • frafaundefined
                          frafa
                          ok
                          out IR Sense (3-Pin) on ==> Z PROBE IN ?
                            Yes. Leave the Mod pin on the Z probe connector unconnected.
                            • frafaundefined
                              frafa
                              Hello
                              Sorry to solicit you again …
                              Z End-Stop removed
                              And "IR Sense" connect on "Z probe connector"
                              my config.g (End-stop only)
                              M574 X1 S0 ; Define (P) active low microswitches
                              M574 y2 S0 ; Define (D) active high microswitches
                              M574 Z0 S0 ; Define (Z) active low and unused microswitches
                              M558 P2 X0 Y0 Z1 H5 F120 T2000 ; Set Z probe type to modulated, the axes for which it is used and the probe + travel speeds
                              G31 P500 X30 Y30 Z2.5 ; Set Z probe trigger value, offset and trigger height
                              M557 X15:285 Y15:285 S20 ; Define mesh grid
                              my homeall.g (Z Only)
                              G30 ; Single Z-Probe
                              Z does not stop where is my error ?
                              • frafaundefined
                                frafa
                                Hummmm….
                                modified M558/G31/M574 Z
                                [[language]]
                                M574 Z0 S1 ; Define (Z) active low and unused microswitches
                                ;Z probe
                                M558 P1 I1 X0 Y0 Z1
                                G31 Z2.5 P500
                                [[language]]
                                16:04:09
                                16:04:05
                                G28
                                • frafaundefined
                                  frafa
                                  Found ! ok 🙂
                                  M558 P1 I0 X0 Y0 Z1
                                    The default for M558 is I0. Your mistake was to use P2, because P1 is correct as described at https://duet3d.com/wiki/Connecting_a_Z_probe#Mini_differential_IR_sensor_by_dc42
                                    • frafaundefined
                                      frafa
                                      It all starts to work really well 🙂
                                      Homing, auto-leveling …
                                      Another question: p
                                      How the heightmap.csv file is used
                                      In my gcode after G28 I add a G29 S1 to recharge it?
                                        G29 S0 (or G29 with no parameters) generates a height map, activates it, and also saves it. The default filename is heightmap.csv. You can load and activate a height map that you have previously generated using G29 S1.
                                        I've just released test firmware 1.19+3 which includes a code speedup of some of the SCARA calculations. I've also reduced the default segments/sec from 200 to 100, because 200 turned out to be too many - although that was before I implemented part of the code speedup.
                                        • frafaundefined
                                          frafa
                                          A small facelift for my 3D printer
                                          It remains to find a place to the electronics, surely at the top of the mat?
                                          Again thanks to you for your reactivity, I will talk about the Duet all around me 🙂
                                          https://youtu.be/yfZkDReH0pI
                                            Looking good!
                                            I guess there is no obvious place to put the electronics for a SCARA printer. On my SCARA printer almost the entire Z axis rotates, so the Duet is mounted on the Z axis to avoid a lot of rotating cables (just like the original electronics that was supplied with the printer). I haven't worked out a good place to put a Panel Due yet - having a touch screen that rotates is not a good option! I don't have a bed for my SCARA printer - I print on blue tape stuck to the desk. You do have a bed so you could put the Duet below that, but you would still need to find somewhere to put the touch screen.
                                            If you are happy with the way the Duet is running your SCARA printer, perhaps you would like to write a post about your machine at http://forums.reprap.org/list.php?185.
                                            In your initial post in this thread, you implied that you were using Smoothieware to run your printer. I'm a little surprised that you decided to risk purchasing a Duet for it, even though homing wasn't implemented in RepRapFirmware at that time. Can you explain your reasons?
                                            Let me know if there is anything else you feel is missing from the SCARA support. I'm still a SCARA novice and I probably have a lot to learn.
